Home » Eclipse Projects » Eclipse Platform » Editor Open Listener
Editor Open Listener [message #299491] Fri, 17 February 2006 19:06 Go to next message
Originally posted by: ian.ianbull.com
I am trying to write a plugin that will be notified every time an editor
is opened. So far I have implemented an IPartListener and on startup
(using the ui.startup extension point) I add the IPartListener to every
"page" in the workbench.
IWorkbenchWindow window =
PlatformUI.getWorkbench().getActiveWorkbenchWindow();
if (window != null) {
IWorkbenchPage[] pages = window.getPages();
for (int i = 0; i < pages.length; i++) {
IWorkbenchPage p = pages[i];
p.addPartListener(new MyPartListener());
this seem to work. However, editors that are already opened are missed.
Is there a way to get these editors added?
Ian
Re: Editor Open Listener [message #299492 is a reply to message #299491] Fri, 17 February 2006 19:24 Go to previous messageGo to next message
Let me clarify a bit... When I say "already opened" I mean the ones that
are opened from my previous run of eclipse. It seems that the early
startup runs after these editors are opened.
I could go through and look for currently opened editors, but I actually
want to change the way some of the data is loaded, so I need to get a
handle to the editor before it actually loads its contents.
- ian
> Ian
Re: Editor Open Listener [message #299494 is a reply to message #299492] Fri, 17 February 2006 21:38 Go to previous messageGo to next message
Have your class implement org.eclipse.ui.IPartListener. Then you get
notified when a workbench part (an IEditorPart, etc.) just got
opened/closed. You can actually filter out which parts you want to pay
attention to.
The tricky part (no pun intended) is to register the listener to workbench.
So, the first thing to do is get a valid IWorkbenchPage so that you can
call IWorkbenchPage.addPartListener(<your class that implements
IPartListener>).
Here is how to get a workbench page.
IWorkbenchPage page = null;
if (window != null)
page = window.getActivePage();
if (page == null)
// Look for a window and get the page off it!
IWorkbenchWindow[] windows =
PlatformUI.getWorkbench().getWorkbenchWindows();
for (int i = 0; i < windows.length; i++)
if (windows[i] != null)
window = windows[i];
page = windows[i].getActivePage();
if (page != null)
break;
> - ian
>> editor is opened. So far I have implemented an IPartListener and on
>> startup (using the ui.startup extension point) I add the IPartListener
>> to every "page" in the workbench.
>> missed. Is there a way to get these editors added?
>> Thanks,
>> Ian
Re: Editor Open Listener [message #299517 is a reply to message #299494] Mon, 20 February 2006 05:47 Go to previous message
Originally posted by: daniel.megert.eclipse.org
Even better: use IPartListener2.
Dani
> Then you get notified when a workbench part (an IEditorPart, etc.)
> just got opened/closed. You can actually filter out which parts you
> want to pay attention to.
> workbench.
> can call IWorkbenchPage.addPartListener(<your class that implements
> IPartListener>).
> if (window != null)
> if (page == null)
> if (page != null)
> break;
>> that are opened from my previous run of eclipse. It seems that the
>> early startup runs after these editors are opened.
>> actually want to change the way some of the data is loaded, so I need
>> to get a handle to the editor before it actually loads its contents.
>> - ian
>>> IPartListener to every "page" in the workbench.
>>> Thanks,
>>> Ian
Previous Topic:Reading the default preferences
Next Topic:Strange icons when using X11 and Mac Os
Current Time: Sat Jun 14 11:14:12 EDT 2025
Powered by FUDForum. Page generated in 0.19062 seconds
