| Problem with HP-UX installation [message #298221] |
Thu, 26 January 2006 13:11  |
Originally posted by: paterldl.westinghouse.com
Hello all -
I'm trying to install and run Eclipse 3.1.2 on an HP-UX workstation. I've
downloaded the code and unzipped the distribution into a clean directory.
When I try to run the code, I get errors (log file listed below). I'd
appreciate any help or pointers to information which could help me figure
out why I'm having this problem.
Thank.
Log file:
!SESSION 2006-01-26 12:03:02.224
eclipse.buildId=M20060118-1600
java.version=1.4.1.00
java.vendor=Hewlett-Packard Co.
BootLoader constants: OS=hpux, ARCH=PA_RISC, WS=motif, NL=en
Command-line arguments: -os hpux -ws motif -arch PA_RISC
!ENTRY
initial@reference:file:plugins/org.eclipse.update.configurator_3.1.0.jar/
0 0 2006-01-26 12:03:09.15
!MESSAGE FrameworkEvent.ERROR
!STACK 0
org.osgi.framework.BundleException: Exception in
org.eclipse.update.internal.configurator.ConfigurationActiva tor.start() of
bundle org.eclipse.update.configurator.
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:1013)
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:969)
at
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:316)
at
org.eclipse.osgi.framework.internal.core.AbstractBundle.resu me(AbstractBundle.java:337)
at
org.eclipse.osgi.framework.internal.core.Framework.resumeBun dle(Framework.java:1024)
at
org.eclipse.osgi.framework.internal.core.StartLevelManager.r esumeBundles(StartLevelManager.java:574)
at
org.eclipse.osgi.framework.internal.core.StartLevelManager.i ncFWSL(StartLevelManager.java:496)
at
org.eclipse.osgi.framework.internal.core.StartLevelManager.d oSetStartLevel(StartLevelManager.java:275)
at
org.eclipse.osgi.framework.internal.core.StartLevelManager.d ispatchEvent(StartLevelManager.java:456)
at
org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEve nt(EventManager.java:189)
at
org.eclipse.osgi.framework.eventmgr.EventManager$EventThread .run(EventManager.java:291)
Caused by: org.eclipse.core.runtime.CoreException: Cannot create
configuration in file:/a/users/paterldl/eclipse/configuration/
at
org.eclipse.update.internal.configurator.Utils.newCoreExcept ion(Utils.java:71)
at
org.eclipse.update.internal.configurator.ConfigurationActiva tor.initialize(ConfigurationActivator.java:106)
at
org.eclipse.update.internal.configurator.ConfigurationActiva tor.start(ConfigurationActivator.java:67)
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl$2 .run(BundleContextImpl.java:994)
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:988)
... 10 more
Root exception:
org.eclipse.core.runtime.CoreException: Cannot create configuration in
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
!ENTRY org.eclipse.osgi 2006-01-26 12:03:09.70
!MESSAGE Startup error
!STACK 1
java.lang.IllegalStateException: Bundle
[2] is not active.
at
org.eclipse.core.runtime.adaptor.EclipseStarter.ensureBundle sActive(EclipseStarter.java:410)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.startup(Ecli pseStarter.java:297)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:159)
at
at
at java.lang.reflect.Method.invoke(Method.java:324)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:334 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:278)
at org.eclipse.core.launcher.Main.run(Main.java:973)
at org.eclipse.core.launcher.Main.main(Main.java:948)
| Re: Problem with HP-UX installation [message #299414 is a reply to message #299327] |
Thu, 16 February 2006 10:21  |
I also notice that your jre version is 1.4.1, but the minimum required on
hpux is 1.4.2.07 (see
http://www.eclipse.org/eclipse/development/readme_eclipse_3. 1.2.html#TargetOperatingEnvironments )
.. I actually ran into a similar problem on linux and aix recently (
https://bugs.eclipse.org/bugs/show_bug.cgi?id=127728 ). Try upgrading your
jre.
Grant
"Grant Gayed" <grant_gayed@ca.ibm.com> wrote in message
news:dst50d$p1n$1@utils.eclipse.org...
> Hi David, sorry for the late reply,
> I haven't seen this error before, but it looks like it's attempting and
> failing to do some writing during startup. Are there possibly permission
> problems?
> Grant
> "David L. Paterline" <paterldl@westinghouse.com> wrote in message
> news:4dcbdec23eac7e6d38ee7e1a8dd3ffa3$1@www.eclipse.org...
> > Hello all -
I've
directory.
figure
> > Thank.
> > Log file:
> > !ENTRY
> > !STACK 0
of
> > at
> > at
> xtImpl.java:969)
> > at
> ava:316)
> > at
> e.java:337)
> > at
> va:1024)
> > at
> > at
> lManager.java:496)
> > at
> > at
> > at
> java:189)
> > at
> r.java:291)
> > at
> 1)
> > at
> > at
> > at
> xtImpl.java:994)
> > at java.security.AccessController.doPrivileged(Native Method)
> > at
> > ... 10 more
> > Root exception:
> > at
> 1)
> > at
> > at
> > at
> xtImpl.java:994)
> > at
> > at
> xtImpl.java:969)
> > at
> ava:316)
> > at
> e.java:337)
> > at
> va:1024)
> > at
> > at
> lManager.java:496)
> > at
> > at
> > at
> java:189)
> > at
> r.java:291)
> > !STACK 1
> > [2] is not active.
> > at
> tarter.java:410)
> > at
> 297)
> > at
> > at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
> > at
> > at
> .java:25)
FUDForum. Page generated in 0.14896 seconds
