Home » Eclipse Projects » Eclipse Platform » Is there any utility which can return the line number where an IJavaElement occurs inside its source
Is there any utility which can return the line number where an IJavaElement occurs inside its source [message #296603] Tue, 27 December 2005 21:42 Go to next message
Originally posted by: varavamu.yahoo.com
hi,
I am writing a plugin and would like to find the line number in the
underlying source where a given IJavaElement is present. How can I infer
this? - either using a utility class (if there's one) or from the
IJavaElement itself?
thanks in advance,
Vijay
Re: Is there any utility which can return the line number where an IJavaElement occurs inside its [message #296607 is a reply to message #296603] Tue, 27 December 2005 23:04 Go to previous messageGo to next message
I came up with this, but it has a dependency on a 3.2 API:
private int getLineNumberInSource(IMember member) throws
JavaModelException {
if (member == null || !member.exists()) {
return -1;
ICompilationUnit compilationUnit = member.getCompilationUnit();
if (compilationUnit == null) {
return -1;
String fullSource = compilationUnit.getBuffer().getContents();
if (fullSource == null) {
return -1;
ISourceRange nameRange = member.getNameRange();
if (nameRange == null) {
return -1;
String string2 = fullSource.substring(0, nameRange.getOffset());
return
string2.split(compilationUnit.findRecommendedLineSeparator() ).length;
if there's some other way, or if this code has bugs (null checks
needed, etc.), I would really appreciate the heads-up.
thanks,
Vijay
Vijay Aravamudhan wrote:
> hi,
> infer this? - either using a utility class (if there's one) or from
> the IJavaElement itself?
> thanks in advance,
> Vijay
Re: Is there any utility which can return the line number where an IJavaElement occurs inside its [message #296609 is a reply to message #296607] Tue, 27 December 2005 23:51 Go to previous messageGo to next message
Originally posted by: automatic.javalobby.org
Try the following ..
public static int getLineNumber(IMember member) throws JavaModelException, BadLocationException
	ICompilationUnit compUnit = member.getCompilationUnit();
	Document document = new Document(compUnit.getBuffer().getContents());
	return document.getLineOfOffset(member.getSourceRange().getOffset());
I think it may be expensive to create Document, but do a trial run. I dont know whether it works or not.
~Venkat
Re: Is there any utility which can return the line number where an IJavaElement occurs inside its [message #296626 is a reply to message #296609] Wed, 28 December 2005 08:39 Go to previous messageGo to next message
hi Venkat,
Thanks for the tip - but I am not sure which Document class you are
referring to - the one in javax.text, or org.w3c.dom or something else?
Anyways - the solution that I found works for me - so I will probably
stick with that. but its nice to know...
thanks,
Vijay
>Thanks
>~Venkat
Re: Is there any utility which can return the line number where an [message #296627 is a reply to message #296626] Wed, 28 December 2005 09:49 Go to previous message
I was referring to org.eclipse.jface.text.Document which I think is extensively used in the implementation of JDT.
Previous Topic:Where's IPropertySource?
Next Topic:TableViewer for list display
Current Time: Sat Jul 19 13:58:47 EDT 2025
Powered by FUDForum. Page generated in 0.04795 seconds
