Home » Eclipse Projects » Eclipse Platform » 3.1RC1 pde build failing
3.1RC1 pde build failing [message #286075] Wed, 01 June 2005 17:03 Go to next message
I have an ant based headless build that I created from the pde-build scripts
using map definitions and such. It looks like the new configuration of plugins
as jars rather than directories is confusing it.
I get:
....pde-build/genericTargets.xml:64: org.eclipse.core.runtime.CoreException:
Unable to find plug-in: org.eclipse.update.configurator_3.0.0. Please check the
error log for more details.
I can't find anything referring to 3.0.0 specifically, though I do specify the
configurator plugin in a couple of places. Can anyone tell me what has changed?
Also, anybody have any updated docs for the 'right way' to do headless builds in
3.1?
Chris
Re: 3.1RC1 pde build failing [message #286077 is a reply to message #286075] Wed, 01 June 2005 18:20 Go to previous messageGo to next message
Usually this is an indication that either that plugin or one of that plugins
dependencies is missing from the plugin model.
Usually the missing plugins are listed at the top of the error log
HTH
Darins
"Chris Longfield" <clongfield@internap.com> wrote in message
news:d7l867$ga1$1@news.eclipse.org...
>scripts using map definitions and such. It looks like the new
>configuration of plugins as jars rather than directories is confusing it.
> I get:
> org.eclipse.core.runtime.CoreException: Unable to find plug-in:
> org.eclipse.update.configurator_3.0.0. Please check the error log for more
> details.
> the configurator plugin in a couple of places. Can anyone tell me what
> has changed?
> builds in 3.1?
> Chris
Re: 3.1RC1 pde build failing [message #286104 is a reply to message #286077] Thu, 02 June 2005 11:57 Go to previous messageGo to next message
Yeah, it's weird because that plugin, well, the 3.1 version, does exist
as a jar in the plugins directory. This is not some problem with it
being a jar, is it? Why might it think it needs 3.0.0 instead of the
3.1.0 that is there? Where does this error log get written when I am
running headless ( -Dbuilder=. )?
Chris
> HTH
> Darins
>>I get:
>>details.
>>has changed?
>>builds in 3.1?
>>Chris
Re: 3.1RC1 pde build failing [message #286108 is a reply to message #286104] Thu, 02 June 2005 12:59 Go to previous messageGo to next message
>> plugins dependencies is missing from the plugin model.
>> HTH
The extra details are that it is getting an InvocationTargetException
caused by its inablity to find the org.eclipse.update.configurator_3.0.0
plugin. I guess my question now is, how can I figure out who is asking
for this specific plugin (as opposed to the
org.eclipse.update.configurator_3.1.0 plugin which *is* there ) ?
I mean, I think the missing plugin reallly is the
org.eclipse.update.configurator_3.0.0 plugin. It just doesn't make
sense that it should be looking for this one.
Chris
stack:
!SESSION 2005-06-02 12:40:42.553
eclipse.buildId=I20050527-1300
java.version=1.4.2_01
BootLoader constants: OS=linux, ARCH=x86, WS=gtk, NL=en_US
Framework arguments: -application org.eclipse.ant.core.antRunner
-Dbuilder=. -Dbuild.compiler=modern
Command-line arguments: -application org.eclipse.ant.core.antRunner
-data workspace_data -Dbuilder=. -Dbuild.compiler=modern
!ENTRY org.eclipse.osgi 2005-06-02 12:40:52.156
!MESSAGE Application error
!STACK 1
at
at
at java.lang.reflect.Method.invoke(Method.java:324)
at org.eclipse.ant.core.AntRunner.run(AntRunner.java:494)
at
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:226)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:375)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:162)
at
at
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:334 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:278)
at org.eclipse.core.launcher.Main.run(Main.java:973)
at org.eclipse.core.launcher.Main.main(Main.java:948)
Caused by: /usr/opt/ws/miro/ui/pde-build/build.xml:22: The following
error occurred while executing this line:
/usr/opt/ws/miro/ui/pde-build/build.xml:76: The following error occurred
/usr/opt/ws/miro/ui/pde-build/customTargets.xml:10: The following error
/usr/opt/ws/miro/ui/pde-build/genericTargets.xml:64:
more details.
at
org.apache.tools.ant.ProjectHelper.addLocationToBuildExcepti on(ProjectHelper.java:539)
at org.apache.tools.ant.taskdefs.Ant.execute(Ant.java:384)
at
org.apache.tools.ant.taskdefs.CallTarget.execute(CallTarget. java:107)
at
org.apache.tools.ant.UnknownElement.execute(UnknownElement.j ava:275)
at org.apache.tools.ant.Task.perform(Task.java:364)
at org.apache.tools.ant.Target.execute(Target.java:341)
at org.apache.tools.ant.Target.performTasks(Target.java:369)
at
org.apache.tools.ant.Project.executeSortedTargets(Project.ja va:1216)
at org.apache.tools.ant.Project.executeTarget(Project.java:1185 )
at
org.apache.tools.ant.helper.DefaultExecutor.executeTargets(D efaultExecutor.java:40)
at
org.eclipse.ant.internal.core.ant.EclipseDefaultExecutor.exe cuteTargets(EclipseDefaultExecutor.java:32)
at org.apache.tools.ant.Project.executeTargets(Project.java:106 8)
at
org.eclipse.ant.internal.core.ant.InternalAntRunner.run(Inte rnalAntRunner.java:704)
at
org.eclipse.ant.internal.core.ant.InternalAntRunner.run(Inte rnalAntRunner.java:582)
... 16 more
Re: 3.1RC1 pde build failing [message #286113 is a reply to message #286108] Thu, 02 June 2005 13:22 Go to previous message
Aha:
my rcp helper feature.xml really DID ask for it:
....<plugin
id="org.eclipse.update.configurator"
download-size="0"
install-size="0"
version="3.0.0"/>...
instead of
....<plugin
download-size="0"
install-size="0"
version="0.0.0"/>...
like all my other plugins that I pull in.
Previous Topic:How does one get an Eclipse bug fixed when you have provided a solution in Bugzilla?
Next Topic:Key binding for terminate - works 3.0, not 3.1
Current Time: Sat Oct 25 06:54:54 EDT 2025
Powered by FUDForum. Page generated in 0.04354 seconds
