crosstab - dynamically hide dimension levels [message #261597] |
Sat, 17 November 2007 01:09 |
Originally posted by: s.meyer.s2neueinformatik.de
i want to alter the visibility of dimension levels based on report
parameters. For example, one report parameter is a date range (start and
end date). If the date range only includes a day or two I would like to
display the hour level of the time dimension hierachy - otherwise not.
It seems that this is possible by opening a report design handle. Then
you should be able to navigate to the corresponding levelhandle and hide it.
If so, what is the method to hide the level? Which event handler should
I use?
Still the data for those levels will be fetched and the performance will
be poor. Is it possble to modify the Cube itself? Which event handler
would that be?
Thanks a lot,
Stefan
FUDForum. Page generated in 0.05576 seconds
