Home » Archived » BIRT » Language packs and Web Viewer
Language packs and Web Viewer [message #256075] Mon, 24 September 2007 17:34 Go to next message
Originally posted by: dserodio.gmail.com
The documentation at http://download.eclipse.org/birt/downloads/lang.php
explains how to translate the Birt Report Designer.
How can I install Language Packs for the Web Viewer?
Thanks in advance,
Daniel Serodio
Re: Language packs and Web Viewer [message #256079 is a reply to message #256075] Mon, 24 September 2007 17:56 Go to previous messageGo to next message
Hi Daniel,
The Report Engine language pack should have what is neccessary for the Web
Viewer Example, however I have not tried this with 2.2 yet. Also, you can
tweak some of the display settings of the viewer in the Messages.properties
found in the viewservlets.jar
Rob
http://www.birt-exchange.com
"Daniel Serodio" <dserodio@gmail.com> wrote in message
news:fd9ahj$vor$1@build.eclipse.org...
> Thanks in advance,
> Daniel Serodio
Re: Language packs and Web Viewer [message #256115 is a reply to message #256079] Tue, 25 September 2007 10:41 Go to previous messageGo to next message
Rob, thanks for the tip.
I tried copying the contents of the NLpack1-birt-runtime-2_1_1.zip file
to the Birt Viewer's webapp, but it didn't work (I guess because of the
version mismatch, as I'm using the 2.2 viewer).
So I edited the Messages.properties in viewservlets.jar, but it feels
like a "hack".
I'd appreciate if someone could post proper instructions for translating
the 2.2 web viewer.
Daniel Serodio
rmurphy wrote:
> Hi Daniel,
> Web Viewer Example, however I have not tried this with 2.2 yet. Also,
> you can tweak some of the display settings of the viewer in the
> Messages.properties found in the viewservlets.jar
> Rob
>> Thanks in advance,
>> Daniel Serodio
Re: Language packs and Web Viewer [message #256141 is a reply to message #256115] Tue, 25 September 2007 12:16 Go to previous messageGo to next message
Originally posted by: jasonweathersby.alltel.net
Daniel,
I just tried this with the NL1 language pack and it worked for me.
Make sure you copy the plugins in the download to the
WEB-INF/platform/plugins directory. I am using 2.2.
You can test it by adding the following to the url when running a report.
&__locale=de_DE
Jason
> like a "hack".
> the 2.2 web viewer.
> Daniel Serodio
> rmurphy wrote:
>> Hi Daniel,
>> Rob
>>> Thanks in advance,
>>> Daniel Serodio
Re: Language packs and Web Viewer [message #256171 is a reply to message #256141] Tue, 25 September 2007 16:07 Go to previous messageGo to next message
Jason,
I just tried re-deploying the viewer with the NL1 language pack but it
still doesn't work.
Here's what I did (after cleaning up the previous deployment):
1) Unzipped birt-runtime-2_2_0.zip to c:\tmp
2) Unzipped c:\tmp\birt-runtime-2_2_0\birt.war to $TOMCAT_HOME\webapps\birt
3) Unzipped NLpack1-birt-runtime-2_1_1.zip to c:\tmp
4) Copied the contents of c:\tmp\birt-runtime-2_1_1\WebViewerExample to
For clarification, step 4) copied all the files in the NL pack's WEB-INF
dir to the Birt viewer's WEB-INF .
Did you do anything differently?
Thanks for your help,
Daniel Serodio
Jason Weathersby wrote:
> Daniel,
> &__locale=de_DE
> Jason
>> like a "hack".
>> the 2.2 web viewer.
>> Thanks,
>> Daniel Serodio
>> rmurphy wrote:
>>> Hi Daniel,
>>> Rob
>>>> Thanks in advance,
>>>> Daniel Serodio
Re: Language packs and Web Viewer [message #256352 is a reply to message #256171] Wed, 26 September 2007 14:04 Go to previous messageGo to next message
I did not use the war file. The war file is just the WebViewerExample
directory.
2) copy c:\tmp\birt-runtime-2_2_0\birt-runtime-2_2_0\WebViewerExampl e to
$TOMCAT_HOME\webapps\ ( you can rename to birt)
4) I copied the jar from here
\NLpack1-birt-runtime-2_1_1\birt-runtime-2_1_1\WebViewerExam ple\WEB-INF\lib
to my WebViewer\WEB-INF\lib directory and all of the plugins in
NLpack1-birt-runtime-2_1_1\birt-runtime-2_1_1\WebViewerExamp le\WEB-INF\platform\plugins
to my WebViewer\WEB-INF\Platform\Plugins direcory
Jason
> Jason,
> still doesn't work.
> Daniel Serodio
>> Daniel,
>> &__locale=de_DE
>> Jason
>>> like a "hack".
>>> the 2.2 web viewer.
>>> Thanks,
>>> Daniel Serodio
>>> rmurphy wrote:
>>>> Hi Daniel,
>>>> Rob
>>>>> Thanks in advance,
>>>>> Daniel Serodio
Re: Language packs and Web Viewer [message #256461 is a reply to message #256352] Thu, 27 September 2007 10:44 Go to previous messageGo to next message
Jason, thank you for your patience :-)
It turns out that the problem lies with only some languages, and that
includes my native one, Brazilian Portuguese.
I tried all locales included in the NLpack1: "pt_BR", "it", "zh_HK" and
"zh_TW" don't work, the rest (de_DE, es_ES, fr_FR, ja_JP, ko_KR, zh_CN)
works.
Any clue?
Again, thank you for your time.
> directory.
> Jason
>> Jason,
>> still doesn't work.
>> Daniel Serodio
>>> Daniel,
>>> report.
>>> &__locale=de_DE
>>> Jason
>>>> like a "hack".
>>>> translating
>>>> the 2.2 web viewer.
>>>> Thanks,
>>>> Daniel Serodio
>>>> rmurphy wrote:
>>>>> Hi Daniel,
>>>>> Rob
>>>>>> Thanks in advance,
>>>>>> Daniel Serodio
Re: Language packs and Web Viewer [message #256467 is a reply to message #256461] Thu, 27 September 2007 11:17 Go to previous messageGo to next message
Daniel,
I know we are working on some updates for the language packs.
Can you log a bugzilla entry for the language pack you need?
Jason
> works.
> Any clue?
>> directory.
>> Jason
>>> Jason,
>>> still doesn't work.
>>> Daniel Serodio
>>>> Daniel,
>>>> report.
>>>> &__locale=de_DE
>>>> Jason
>>>>> like a "hack".
>>>>> translating
>>>>> the 2.2 web viewer.
>>>>> Thanks,
>>>>> Daniel Serodio
>>>>> rmurphy wrote:
>>>>>> Hi Daniel,
>>>>>> Rob
>>>>>>> Thanks in advance,
>>>>>>> Daniel Serodio
Re: Language packs and Web Viewer [message #256488 is a reply to message #256467] Thu, 27 September 2007 16:51 Go to previous messageGo to next message
Filed bug #204869
Daniel
> Daniel,
> Jason
>> works.
>> Any clue?
>>> directory.
>>> Jason
>>>> Jason,
>>>> still doesn't work.
>>>> WEB-INF
>>>> Daniel Serodio
>>>>> Daniel,
>>>>> report.
>>>>> &__locale=de_DE
>>>>> Jason
>>>>>> file
>>>>>> of the
>>>>>> like a "hack".
>>>>>> translating
>>>>>> the 2.2 web viewer.
>>>>>> Thanks,
>>>>>> Daniel Serodio
>>>>>> rmurphy wrote:
>>>>>>> Hi Daniel,
>>>>>>> for the
>>>>>>> Also,
>>>>>>> Rob
>>>>>>>> Thanks in advance,
>>>>>>>> Daniel Serodio
Re: Language packs and Web Viewer [message #256492 is a reply to message #256467] Thu, 27 September 2007 23:07 Go to previous message
See Bugzilla entry: https://bugs.eclipse.org/bugs/show_bug.cgi?id=204869
> Daniel,
> Jason
>> works.
>> Any clue?
>>> directory.
>>> 1) Unzipped birt-runtime-2_2_0.zip to c:tmp
>>> 2) copy c:tmpbirt-runtime-2_2_0birt-runtime-2_2_0WebViewerExample to
>>> $TOMCAT_HOMEwebapps ( you can rename to birt)
>>> 3) Unzipped NLpack1-birt-runtime-2_1_1.zip to c:tmp
>>> NLpack1-birt-runtime-2_1_1birt-runtime-2_1_1WebViewerExample WEB-INFlib
>>> to my WebViewerWEB-INFlib directory and all of the plugins in
NLpack1-birt-runtime-2_1_1birt-runtime-2_1_1WebViewerExample WEB-INFplatformplugins
>>> to my WebViewerWEB-INFPlatformPlugins direcory
>>> Jason
>>>> Jason,
>>>> still doesn't work.
>>>> 2) Unzipped c:tmpbirt-runtime-2_2_0birt.war to
>>>> $TOMCAT_HOMEwebappsbirt
>>>> 4) Copied the contents of c:tmpbirt-runtime-2_1_1WebViewerExample to
>>>> Daniel Serodio
>>>>> Daniel,
>>>>> report.
>>>>> &__locale=de_DE
>>>>> Jason
>>>>>> like a "hack".
>>>>>> translating
>>>>>> the 2.2 web viewer.
>>>>>> Thanks,
>>>>>> Daniel Serodio
>>>>>> rmurphy wrote:
>>>>>>> Hi Daniel,
>>>>>>> Rob
>>>>>>>> Thanks in advance,
>>>>>>>> Daniel Serodio
See Bugzilla entry 204869:
Previous Topic:Out of Memory Error
Next Topic:Query with argumentlist ; VALUE in ('A','B','C')
Current Time: Tue Jul 22 06:39:45 EDT 2025
Powered by FUDForum. Page generated in 0.08544 seconds
