Home » Archived » BIRT » Cannot add POJO as data source to simple report
Cannot add POJO as data source to simple report [message #255887] Thu, 20 September 2007 21:10 Go to next message
Originally posted by: deadwinterday.yahoo.com
Hi folks:
I am attempting to write a very simple report which uses a very simple
POJO for its data. I cannot seem to get the JavaScript interpreter to
correctly load my POJO class. I have tried copying the class to:
C:\Software\BIRT\eclipse\plugins\org.eclipse.birt.report.vie wer_2.2.0.v20070620\birt\WEB-INF\classes
C:\Software\BIRT\eclipse\plugins\org.eclipse.birt.report.vie wer_2.2.0.v20070620\birt\WEB-INF\lib
C:\Software\BIRT\eclipse\plugins\org.eclipse.birt.report.vie wer_2.2.0.v20070620\birt\scriptlib
Neither has worked.
This is the error I am getting in preview mode:
A BIRT exception occurred.
Plug-in Provider:Eclipse.org
Plug-in Name:BIRT Data Engine
Plug-in ID:org.eclipse.birt.data
Version:2.2.0.v200706221
Error Code:data.engine.BirtException
Error Message:A BIRT exception occurred: Error evaluating Javascript
expression. Script engine error: ReferenceError:
"SpeedometerDataSourceBean" is not defined. (DataSet[Data Set].__bm_open#4)
Script source: DataSet[Data Set].__bm_open, line: 1, text:
__bm_open(). See next exception for more information.
Error evaluating Javascript expression. Script engine error:
ReferenceError: "SpeedometerDataSourceBean" is
__bm_open()
This is my class:
package com.mycompany.platform.ui;
public class SpeedometerDataSourceBean {
private String count = "42";
public String getCount() {
return count;
public void setCount(String count) {
this.count = count;
These are my scripts:
"open"
importPackage(Packages.com.supplyscape.platform.ui);
c = new SpeedometerDataSourceBean();
count = c.getCount();
"fetch"
row["COUNT"] = count;
return true;
I can post the design XML if need be.
Any help will be appreciated. Thanks.
-Carlos Rodriguez
Re: Cannot add POJO as data source to simple report [message #255898 is a reply to message #255887] Thu, 20 September 2007 23:48 Go to previous messageGo to next message
You have defined the class in the package
> package com.mycompany.platform.ui; <-- mycompany
and imported the package
> importPackage(Packages.com.supplyscape.platform.ui); <-- supplyscape
It is possible that this is just a typing error.
Snjeza
Carlos Rodriguez wrote:
> Hi folks:
> Neither has worked.
> ReferenceError: "SpeedometerDataSourceBean" is not defined.
> __bm_open()
> This is my class:
> return count;
> this.count = count;
> "open"
> "fetch"
> return true;
> -Carlos Rodriguez
Re: Cannot add POJO as data source to simple report [message #255923 is a reply to message #255898] Fri, 21 September 2007 13:00 Go to previous messageGo to next message
Yes, I am sorry. This was just a typo when writing it to the newsgroup.
It was a halfhearted attempt to hide the name of my company. The real
code for the class is:
package com.supplyscape.platform.ui;
return count;
this.count = count;
I should also add that I also attempted to package the class by itself in
a jar, and then added the following to the manifest found in:
C:\Software\BIRT\eclipse\plugins\org.eclipse.birt.report.vie wer_2.2.0.v20070620\META-INF
like so:
Class-Path: myclass.jar
-carlos
> Snjeza
>> Hi folks:
C:SoftwareBIRTeclipsepluginsorg.eclipse.birt.report.viewer_2 .2.0.v20070620birtWEB-INFclasses
C:SoftwareBIRTeclipsepluginsorg.eclipse.birt.report.viewer_2 .2.0.v20070620birtWEB-INFlib
C:SoftwareBIRTeclipsepluginsorg.eclipse.birt.report.viewer_2 .2.0.v20070620birtscriptlib
>> Neither has worked.
>> __bm_open()
>> This is my class:
>> return count;
>> this.count = count;
>> "open"
>> "fetch"
>> return true;
>> -Carlos Rodriguez
Re: Cannot add POJO as data source to simple report [message #255959 is a reply to message #255923] Sat, 22 September 2007 16:38 Go to previous message
> like so:
You need to find the following line in the MANIFEST.MF file:
Bundle-ClassPath: viewer.jar
and change it to:
Bundle-ClassPath: viewer.jar,
myclass.jar
Put myclass.jar in the
directory (the viewer's root directory).
Check if BIRT has been loaded from the C:\Software\BIRT\eclipse\plugins
location and restart Eclipse using the -clean option
Adding myclass.jar to
would have to work.
Snjeza
Previous Topic:What is the minimal deployment of the webviewer?
Next Topic:Urgent Please advise asap
Current Time: Tue Sep 16 08:32:33 EDT 2025
Powered by FUDForum. Page generated in 0.03170 seconds
