Home » Archived » BIRT » Classloader (?) problem in Birt
Classloader (?) problem in Birt [message #254318] Tue, 04 September 2007 03:00 Go to next message
Originally posted by: R.Schuster.dzbw.de
I use Eclipse 3.3.0 and Birt 2.2.0 together with Java 1.6. I developed a
custom Datasource / Dataset extension which consists of 3 plugins: The 1st
one is simply a wrapper plugin which contains own and 3rd party libraries
(JBoss Client API and others). The 2nd contains the implementations of
IDriver, IConnection and so on. The last one creates a custom wizard page.
My Connection implementation reads in an external config file which
contains
birt {
// jBoss LoginModule
org.jboss.security.ClientLoginModule required
to load the JBoss login code.
My Java code also uses reflection implicitly to load some more "classes"
like in env.put(Context.INITIAL_CONTEXT_FACTORY,
"org.jnp.interfaces.NamingContextFactory");
I can now create a Datasource and a Dataset. By double-clicking the new
Dataset and selecting "Preview Results" my plugin logs in to JBoss and
loads and displays data. Anything is good at this point.
But if I put the fields of my Dataset in a report page (a table for
example) and press the "Preview" tab of the designer an error occurs: "The
login module class cannot be found: org.jboss.security.ClientLoginModule".
This sounds like a problem with Eclipses class loading mechanism. I
googled the famous web page
http://www.eclipsezone.com/articles/eclipse-vms/ and gave the buddy class
loading a try. But no success.
Can somebody explain why it works in the Datasource property dialog but
not with in the Preview tab? What to do to solve the issue? Hard-coding
the call to ClientLoginModule is no solution because reflection is used at
other places, too.
Roger
Re: Classloader (?) problem in Birt [message #254333 is a reply to message #254318] Tue, 04 September 2007 04:45 Go to previous messageGo to next message
Hi Roger,
afaik BIRT report previews are executed using the eclipse tomcat plugin,
which will start the tomcat with its own classpath. I think you'll have
to add the jboss libs into the tomcats classpath. It might work putting
the jbossall-client.jar into the scriptlib directory of the birt viewer
plugin: org.eclipse.birt.report.viewer.
See
http://wiki.eclipse.org/BIRT/FAQ/Scripting#Q:_Where_do_I_hav e_to_put_my_classes_in_order_to_access_them_by_JavaScript.3F
Best regards
Alex
Roger Schuster wrote:
> 1st one is simply a wrapper plugin which contains own and 3rd party
> libraries (JBoss Client API and others). The 2nd contains the
> implementations of IDriver, IConnection and so on. The last one creates
> contains
> birt {
> "The login module class cannot be found:
> class loading a try. But no success.
> at other places, too.
> Regards,
> Roger
Re: Classloader (?) problem in Birt [message #254367 is a reply to message #254333] Tue, 04 September 2007 06:39 Go to previous messageGo to next message
Hi Alexander,
I put the *.jar with the 3rd party libs into the birt/scriptlib directory
of the viewer plugin. I restarted Eclipse and tested it by "Run as Eclipse
Application". Unfortunately it still doesn't work.
Anyway, thank you for your help.
Roger
> See
Re: Classloader (?) problem in Birt [message #254370 is a reply to message #254318] Tue, 04 September 2007 06:47 Go to previous messageGo to next message
Hi again,
after some debugging I discovered that if I make
org.eclipse.birt.report.data.adapter depend from my wrapper plugin it will
work! But I can't believe that a custom ODA will need the modification of
Birt sources or configuration. Any idea, please?
Roger
Re: Classloader (?) problem in Birt [message #254381 is a reply to message #254318] Tue, 04 September 2007 08:56 Go to previous messageGo to next message
I had a similar problem that I solved using buddy classloading.
You can take a look at this thread:
http://dev.eclipse.org/newslists/news.eclipse.birt/msg20903. html
Snjeza
> contains
> birt {
> Regards,
> Roger
Re: Classloader (?) problem in Birt [message #254511 is a reply to message #254381] Wed, 05 September 2007 02:48 Go to previous messageGo to next message
Originally posted by: firstname.lastname.napa.fi
On Tue, 04 Sep 2007 15:56:33 +0300, Snjezana Peco <snjeza.peco@gmail.com>
I have a similar problem: javascript in the RCP designer preview fails
to find the classes exported by my ODA runtime plugin, so I tried adding
the following lines to that plugin's manifest.mf:
Eclipse-RegisterBuddy: org.eclipse.birt.report.data.adapter,
org.eclipse.tomcat,
org.mozilla.rhino,
It didn't help, did I choose the wrong buddies?
-Antti-
Re: Classloader (?) problem in Birt [message #254523 is a reply to message #254511] Wed, 05 September 2007 03:48 Go to previous messageGo to next message
On Wed, 05 Sep 2007 09:48:16 +0300, Antti Karanta
> fails to find the classes exported by my ODA runtime plugin, so I tried
> adding the following lines to that plugin's manifest.mf:
To clarify: into my ODA runtime plugin's manifest.mf.
> org.eclipse.tomcat,
> org.mozilla.rhino,
I also threw in org.eclipse.birt.report.engine, but to no avail. I guess
I'm still being a buddy with the wrong plugins?
-Antti-
Re: Classloader (?) problem in Birt [message #254535 is a reply to message #254523] Wed, 05 September 2007 07:37 Go to previous messageGo to next message
>> org.eclipse.tomcat,
>> org.mozilla.rhino,
AFAIK this can't work because at least
org.eclipse.birt.report.data.adapter doesn't offer a BuddyPolicy.
Roger
Re: Classloader (?) problem in Birt [message #254561 is a reply to message #254535] Wed, 05 September 2007 19:22 Go to previous messageGo to next message
Every plugin supports buddy classloading.
In order to solve that issue, you have to patch some BIRT's plugins.
I have done the following:
- added Eclipse-BuddyPolicy: registered to the org.mozilla.rhino plugin
- added Eclipse-RegisterBuddy: org.mozilla.rhino to my viewer plugin (I
have a specific viewer plugin, but you can try to use the BIRT viewer
plugin)
- fixed classloading problem in the org.eclipse.birt.report.engine as it
is described in
http://dev.eclipse.org/newslists/news.eclipse.birt/msg20833. html
After these changes Preview Results in the scripted datasource as well
as Preview in the viewer work correctly.
Snjeza
>>> org.eclipse.tomcat,
>>> org.mozilla.rhino,
>> guess I'm still being a buddy with the wrong plugins?
> Regards,
> Roger
Re: Classloader (?) problem in Birt [message #254594 is a reply to message #254561] Thu, 06 September 2007 03:41 Go to previous message
On Thu, 06 Sep 2007 02:22:08 +0300, Snjezana Peco <snjeza.peco@gmail.com>
I suppose he meant it's not enabled.
> plugin)
> is described in
Thanks a lot for your help. I was able to get the preview working by
enabling buddying in org.eclipse.birt.report.viewer plugin's manifest.mf
like this:
and then registering my ODA runtime plugin as its buddy:
Eclipse-RegisterBuddy: org.eclipse.birt.report.viewer
-Antti-
Previous Topic:Accessing an arbitrary data set row with javascript
Next Topic:Timezones
Current Time: Tue Nov 04 22:56:32 EST 2025
Powered by FUDForum. Page generated in 0.04837 seconds
