Home » Archived » BIRT » How to generate XLS or DOC by using REAPI
How to generate XLS or DOC by using REAPI [message #250369] Mon, 30 July 2007 09:16 Go to next message
does anyone know how to generate XLS or DOC format per Birt 2.2 Report
Engine API ?
i can generate PDF and HTML by using HTML- or PDFRenderOption
programtically, but until now still don not find any example about how to
use Birt 2.2 REAPI to generate XLS or DOC programmatically. Some prevoius
discussions about it do not also give any ideas.
thanks in advance
Re: How to generate XLS or DOC by using REAPI [message #250415 is a reply to message #250369] Mon, 30 July 2007 12:30 Go to previous messageGo to next message
Originally posted by: jasonweathersby.alltel.net
Peng,
You just need to use the RenderOption class like this:
IReportDocument document = null;
//Open the report design
document
=engine.openReportDocument("output/resample/customers.rptdocument ");
IRenderOption options = new RenderOption();
options.setOutputFormat("xls");
options.setOutputFileName("output/resample/customers.xls");
IRenderTask task = engine.createRenderTask(document);
task.setRenderOption(options);
Jason
Peng wrote:
> Engine API ?
> to use Birt 2.2 REAPI to generate XLS or DOC programmatically. Some
> prevoius discussions about it do not also give any ideas.
> thanks in advance
Re: How to generate XLS or DOC by using REAPI [message #250689 is a reply to message #250415] Wed, 01 August 2007 03:21 Go to previous messageGo to next message
I tried the this example but I get the following error:
org.eclipse.birt.report.engine.api.EngineException
at
org.eclipse.birt.report.engine.api.impl.ReportEngineHelper.o penReportDocument(ReportEngineHelper.java:395)
at
org.eclipse.birt.report.engine.api.impl.ReportEngineHelper.o penReportDocument(ReportEngineHelper.java:342)
at
org.eclipse.birt.report.engine.api.impl.ReportEngine.openRep ortDocument(ReportEngine.java:423)
Re: How to generate XLS or DOC by using REAPI [message #250751 is a reply to message #250689] Wed, 01 August 2007 10:40 Go to previous messageGo to next message
Can you post the entire stack trace.
Here is the complete sample I used:
Jason
import java.util.HashMap;
import java.util.logging.Level;
import org.eclipse.birt.core.framework.Platform;
import org.eclipse.birt.report.engine.api.EngineConfig;
import org.eclipse.birt.report.engine.api.EngineConstants;
import org.eclipse.birt.report.engine.api.EngineException;
import org.eclipse.birt.report.engine.api.HTMLActionHandler;
import org.eclipse.birt.report.engine.api.HTMLRenderOption;
import org.eclipse.birt.report.engine.api.PDFRenderOption;
import org.eclipse.birt.report.engine.api.HTMLServerImageHandler;
import org.eclipse.birt.report.engine.api.IReportEngine;
import org.eclipse.birt.report.engine.api.IReportEngineFactory;
import org.eclipse.birt.report.engine.api.IReportRunnable;
import org.eclipse.birt.report.engine.api.IReportDocument;
import org.eclipse.birt.report.engine.api.IRenderTask;
import org.eclipse.birt.report.engine.api.IRenderOption;
import org.eclipse.birt.report.engine.api.RenderOption;
import org.eclipse.birt.report.engine.api.IHTMLRenderOption;
import org.eclipse.birt.report.engine.api.IPDFRenderOption;
public class RenderTaskXLS {
public void runReport() throws EngineException
IReportEngine engine=null;
EngineConfig config = null;
try{
config = new EngineConfig( );
config.setBIRTHome("C:/birt/birt-runtime-2_2_0/birt-runtime-2_2_0/ReportEngine ");
config.setLogConfig(null, Level.FINE);
Platform.startup( config );
IReportEngineFactory factory = (IReportEngineFactory)
Platform.createFactoryObject(
IReportEngineFactory.EXTENSION_REPORT_ENGINE_FACTORY );
engine = factory.createReportEngine( config );
}catch( Exception ex){
ex.printStackTrace();
document =
task.render();
task.close();
engine.destroy();
Platform.shutdown();
System.out.println("Finished");
* @param args
try
RenderTaskXLS ex = new RenderTaskXLS( );
ex.runReport();
catch ( Exception e )
e.printStackTrace();
Said wrote:
> at
> at
> at
Re: How to generate XLS or DOC by using REAPI [message #250840 is a reply to message #250751] Wed, 01 August 2007 17:52 Go to previous messageGo to next message
Originally posted by: xxxx.xxx.com
Jason, I could be able to generate a report output in XLS but I am
getting annoying log messages as follows in my dos window where I run
the Java class:
add data col = 0
Get Data = [0,0]
Get Data = [0,0]
add data col = 1
Get Data = [1,0]
Get Data = [1,0]
add data col = 2
Get Data = [2,0]
Get Data = [2,0]
Get Data = [0,0]
Get Data = [1,0]
Get Data = [2,0]
Get Data = [0,0]
Is there any way I can avoid this?
> Jason
> try{
> document =
> task.render();
> task.close();
> engine.destroy();
> * @param args
> public static void main(String[] args) {
> try
> ex.runReport();
> Said wrote:
>> Hi,
>> at
>> at
>> at
Re: How to generate XLS or DOC by using REAPI [message #250871 is a reply to message #250840] Wed, 01 August 2007 23:32 Go to previous messageGo to next message
Can you set the log level to OFF?
Jason
> the Java class:
> add data col = 0
> Get Data = [0,0]
> Get Data = [0,0]
> add data col = 1
> Get Data = [1,0]
> Get Data = [1,0]
> add data col = 2
> Get Data = [2,0]
> Get Data = [2,0]
> Get Data = [0,0]
> Get Data = [1,0]
> Get Data = [2,0]
> Get Data = [0,0]
> Thanks
>> Jason
>> try{
>> document =
>> task.render();
>> task.close();
>> engine.destroy();
>> * @param args
>> try
>> ex.runReport();
>> Said wrote:
>>> Hi,
>>> at
>>> at
>>> at
Re: How to generate XLS or DOC by using REAPI [message #250887 is a reply to message #250751] Thu, 02 August 2007 02:44 Go to previous messageGo to next message
The following code works for HTML,PDF, XLS and DOC:
HTMLRenderOption options = new HTMLRenderOption();
options.setOutputFormat(format);
options.setOutputFileName(output);
HTMLRenderContext renderContext = new HTMLRenderContext();
renderContext.setImageDirectory("images");
renderContext.setBaseImageURL("images/");
HTMLEmitterConfig emitterConfig = new HTMLEmitterConfig();
emitterConfig.setActionHandler(new HTMLActionHandler());
HTMLCompleteImageHandler imageHandler = new HTMLCompleteImageHandler();
emitterConfig.setImageHandler(imageHandler);
econfig.getEmitterConfigs().put(format, emitterConfig);
HashMap<String, Object> appContext = new HashMap<String, Object>();
appContext.put(EngineConstants.APPCONTEXT_HTML_RENDER_CONTEX T,
renderContext);
appContext.put(EngineConstants.APPCONTEXT_CLASSLOADER_KEY,
Thread.currentThread()
.getContextClassLoader());
task.setAppContext(appContext);
Re: How to generate XLS or DOC by using REAPI [message #252545 is a reply to message #250840] Wed, 15 August 2007 11:26 Go to previous messageGo to next message
Jason, I couldnt stop (with log level OFF) displaying these messaged
from printing. One thing I am noticing about these messages that they
dont look like (message format) they are from the logger but from a
debug statement like System.out.println().
Is there any possibility that any developer could ve left that debug
statement in there and forgot to take it out?
> the Java class:
> add data col = 0
> Get Data = [0,0]
> Get Data = [0,0]
> add data col = 1
> Get Data = [1,0]
> Get Data = [1,0]
> add data col = 2
> Get Data = [2,0]
> Get Data = [2,0]
> Get Data = [0,0]
> Get Data = [1,0]
> Get Data = [2,0]
> Get Data = [0,0]
> Thanks
>> Jason
>> try{
>> document =
>> task.render();
>> task.close();
>> engine.destroy();
>> * @param args
>> try
>> ex.runReport();
>> Said wrote:
>>> Hi,
>>> at
>>> at
>>> at
Re: How to generate XLS or DOC by using REAPI [message #252574 is a reply to message #252545] Wed, 15 August 2007 14:45 Go to previous message
Please have a look at bug
https://bugs.eclipse.org/bugs/show_bug.cgi?id=198843
It is fixed in 2.2.1.
Spunk
"Kris" <xxxx@xxx.com> schrieb im Newsbeitrag
news:f9v5vh$rt2$1@build.eclipse.org...
> Jason, I couldnt stop (with log level OFF) displaying these messaged from
> printing. One thing I am noticing about these messages that they dont look
> like (message format) they are from the logger but from a debug statement
> Thanks
>> getting annoying log messages as follows in my dos window where I run the
>> Java class:
>> add data col = 0
>> Get Data = [0,0]
>> Get Data = [0,0]
>> add data col = 1
>> Get Data = [1,0]
>> Get Data = [1,0]
>> add data col = 2
>> Get Data = [2,0]
>> Get Data = [2,0]
>> Get Data = [0,0]
>> Get Data = [1,0]
>> Get Data = [2,0]
>> Get Data = [0,0]
>> Thanks
>>> Jason
>>> try{
>>> document =
>>> task.render();
>>> task.close();
>>> engine.destroy();
>>> * @param args
>>> try
>>> ex.runReport();
>>> Said wrote:
>>>> Hi,
>>>> at
>>>> at
>>>> at
Previous Topic:How to configure datasource in BIRT Viewer
Next Topic:Best Practices for Secuirty and Authorization w/in Birt
Current Time: Tue Nov 18 22:16:13 EST 2025
Powered by FUDForum. Page generated in 0.09624 seconds
