Home » Archived » EPF » Define steps in a new task descriptor
Define steps in a new task descriptor [message #24789] Tue, 28 November 2006 06:30 Go to next message
Dear all,
When defining a delivery process, I have added a new task descriptor but
it is impossible to define new steps as done in the method content. I this
a bug or is a policy when defining a delivery process.
Thank you in advance.
Regads,
Aitor.
Re: Define steps in a new task descriptor [message #24857 is a reply to message #24789] Tue, 28 November 2006 13:10 Go to previous messageGo to next message
Originally posted by: storaskar.xx.xxx.xxx
Steps for that new task descriptor will only be added if that task
descriptor's linked task has any steps associated with it. Most likely, in
your case, either there is no task associated with task descriptor OR
there are no available steps for that task. It's misleading since the
"Add" button is not disabled. There is a bug for that to disable the "Add"
button https://bugs.eclipse.org/bugs/show_bug.cgi?id=164032
Re: Define steps in a new task descriptor [message #24998 is a reply to message #24789] Wed, 29 November 2006 18:29 Go to previous messageGo to next message
Originally posted by: phaumer.xxx.com
I recorded a demo on how to add steps to task from a plug-in. Once you have
done that you can use these extended tasks for your processes. Check it out
here: http://www.eclipse.org/epf/general/epfc-mc.exe. There is also a
general into to EPFC here: http://www.eclipse.org/epf/general/epfc-ovu.exe
Peter.
Thanks and best regards,
Peter Haumer.
____________________________________________________________ __
PETER HAUMER
IBM | Eclipse Process Framework Committer
"Aitor Bediaga" <aitor.bediaga@esi.es> wrote in message
news:ff01c1a866876f38e21d3b3fa922bbdb$1@www.eclipse.org...
> Dear all,
> Regads,
> Aitor.
Re: Define steps in a new task descriptor [message #25074 is a reply to message #24998] Thu, 30 November 2006 10:18 Go to previous message
These recordings, although somewhat large, are very useful. Thanks for
letting us know about them, and I look forward to the others to come.
Prof. Christopher Fuhrman
Department of Software and IT Engineering
University of Quebec - École de technologie supérieure (ETS)
http://profs.logti.etsmtl.ca/cfuhrman/index.shtml?en
+1 (514) 396 8638
Re: Define steps in a new task descriptor [message #569422 is a reply to message #24789] Tue, 28 November 2006 13:10 Go to previous message
Re: Define steps in a new task descriptor [message #573687 is a reply to message #24789] Wed, 29 November 2006 18:29 Go to previous message
here: http://www.eclipse.org/epf/general/epfc-mc.exe There is also a
Peter.
Peter Haumer.
PETER HAUMER
> Dear all,
> Regads,
> Aitor.
Re: Define steps in a new task descriptor [message #573815 is a reply to message #24998] Thu, 30 November 2006 10:18 Go to previous message
+1 (514) 396 8638
Previous Topic:Re: about chinese character
Next Topic:Service Operation idea built into EPF?
Current Time: Wed Oct 08 06:59:20 EDT 2025
Powered by FUDForum. Page generated in 0.05156 seconds
