Home » Eclipse Projects » Eclipse Platform » RCP M9 SDK start up errors
RCP M9 SDK start up errors [message #247058] Fri, 28 May 2004 19:09 Go to next message
Greetings,
I get the following error when I try to run RCP M9 SDK.
--snip--
!SESSION May 29, 2004
11:04:59.546 ---------------------------------------------
eclipse.buildId=I200405211200
java.version=1.4.2
!ENTRY org.eclipse.osgi May 29, 2004 11:04:59.562
!MESSAGE Startup error
!STACK 1
java.lang.IllegalArgumentException: Bundle org.eclipse.update.configurator
not found.
at
org.eclipse.core.runtime.adaptor.EclipseStarter.loadBasicBun dles(EclipseStar
ter.java:431)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.startup(Ecli pseStarter.java:
219)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:125)
at
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39
at
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl
..java:25)
at java.lang.reflect.Method.invoke(Method.java:324)
at org.eclipse.core.launcher.Main.basicRun(Main.java:185)
at org.eclipse.core.launcher.Main.run(Main.java:638)
at org.eclipse.core.launcher.Main.main(Main.java:622)
--snip--
Now, if I edit the config.ini to override default bundles and start
"org.eclipse.core.runtime" bundle. I get the following error.
--snip--
11:06:52.140 ---------------------------------------------
java.version=1.4.2
!ENTRY org.eclipse.osgi May 29, 2004 11:06:52.140
!MESSAGE Application error
!STACK 1
java.lang.RuntimeException: No application id has been found.
at
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.
java:294)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:256)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:127)
at
at
..java:25)
--snip--
Any suggestions how I can get started with the RCP SDK ?
Rahul
Re: RCP M9 SDK start up errors [message #247070 is a reply to message #247058] Fri, 28 May 2004 20:07 Go to previous message
Originally posted by: pascal.ibm.canada
RCP is *not* an application. It is a base to build against.
You can do the analogy with Java where if you run java.exe nothing happens.
PaScaL
Rahul wrote:
> Greetings,
> --snip--
> java.version=1.4.2
> BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
> !STACK 1
> not found.
> at
> ter.java:431)
> at
> 219)
> at
> at
> at
> .java:25)
> --snip--
> --snip--
> java.version=1.4.2
> !STACK 1
> at
> java:294)
> at
> at
> at
> at
> .java:25)
> --snip--
> Cheers,
> Rahul
Previous Topic:Migrating between milestone releases
Next Topic:M9- deprecated Plugin constructor
Current Time: Mon Jun 16 23:37:14 EDT 2025
Powered by FUDForum. Page generated in 0.03715 seconds
