Package Explorer is empty after "Go Into" and delete of this project [message #246883] |
Fri, 17 August 2007 04:59  |
currently my package explorer is empty if I open a certain workspace and I'm
not able find a way to get it populated again.
What I did:
1.) I selected a project A and selected "Go Into"
2.) Somehow (I'm not able to reproduce / undo this) I made this perspective
the default one. So everytime I started Eclipse this view of "Go Intro" for
this specific project A was the default one. I always had to select "Up" to
get the "right" level.
3.) At some point I deleted project A.
Now the "Up" button is inactive and the package explorer is empty.
Any advice how to solve this? I did run eclipse with -clean but no result.
And in addition does anyone know how to set the "Go Into" to the default in
the package explorer? If I could reproduce this, I would like to open a bug
report.
Best regards, Lars
Re: Package Explorer is empty after "Go Into" and delete of this project [message #246917 is a reply to message #246912] |
Sat, 18 August 2007 02:30  |
Hi Dave,
thank you for the tip. Resetting did not help but based on your tip I closed
the perspective.
After closing all perspectives and re-opening the java one the package
explorer is displaying the elements again.
Thank you, Lars
P.S. I will update Bug 200375 accordingly.
"Dave Wegener" <wegener@cboenospam.com> wrote in message
news:fa4o9f$quj$1@build.eclipse.org...
> Have you tried to reset the perspective from the Window menu?
> "Lars Vogel" <Lars.Vogel@gmail.com> wrote in message
> news:fa4dgc$1s1$1@build.eclipse.org...
>> Hi Ed,
>> thank you for your reply. I'm also using Eclipse 3.3
>> I opened Bug 200375 as suggested even though I assume it will be hard to
>> reproduce. I added also a screenshot in the bug report.
>> Best regards, Lars
>> "Ed Merks" <merks@ca.ibm.com> wrote in message
>> news:fa42qk$8ml$1@build.eclipse.org...
>> > Lars,
>> > I couldn't reproduce this behavior. The package explorer doesn't seem
> to
>> > remember the "go into" value (with 3.3). The navigator does seem to
>> > remember and gets slightly upset if I close Eclipse in the state where
> it
>> > was focused on a deleted project and then start up again. But if I
> create
>> > a new project, it shows that project. It seems odd either view would
> stay
>> > in the state of being focused on a deleted project, so perhaps that's
>> > worth opening a bug about...
>> > Lars Vogel wrote:
>> >> Hello,
> and
>> >> I'm not able find a way to get it populated again.
>> >> What I did:
>> >> perspective the default one. So everytime I started Eclipse this view
> of
>> >> "Go Intro" for this specific project A was the default one. I always
> had
>> >> to select "Up" to get the "right" level.
>> >> result.
> default
>> >> in the package explorer? If I could reproduce this, I would like to
> open
>> >> a bug report.
>> >> Best regards, Lars
FUDForum. Page generated in 0.04490 seconds
