Home » Archived » Maven Integration (M2E) » Disable download from local repository?
Disable download from local repository? [message #24552] Mon, 30 March 2009 17:26 Go to next message
Originally posted by: asd.asd.com
I have installed the maven eclipse plugin and the maven stand alone
application on a Vista 32 machine.
I have installed a few .jar files to my local repository using:
call mvn
install:install-file -DgroupId=birt-runtime -DartifactId=coreapi -Dversion=2.1.0
-Dpackaging=jar -Dfile=coreapi.jar
call mvn
install:install-file -DgroupId=birt-runtime -DartifactId=engineapi -Dversion=2.1.0
-Dpackaging=jar -Dfile=engineapi.jar
call mvn
install:install-file -DgroupId=birt-runtime -DartifactId=modelapi -Dversion=2.1.0
-Dpackaging=jar -Dfile=modelapi.jar
call mvn
install:install-file -DgroupId=com.ibm -DartifactId=icu -Dversion=3.8.1 -Dpackaging=jar
-Dfile=com.ibm.icu_3.8.1.v20080530.jar
call mvn
install:install-file -DgroupId=org.apache.commons -DartifactId=codec -Dversion=1.3.0
-Dpackaging=jar -Dfile=org.apache.commons.codec_1.3.0.v20080530-1600.jar
call mvn
install:install-file -DgroupId=birt-runtime -DartifactId=scriptapi -Dversion=2.1.0
-Dpackaging=jar -Dfile=scriptapi.jar
call mvn
install:install-file -DgroupId=birt-runtime -DartifactId=dteapi -Dversion=2.1.0
-Dpackaging=jar -Dfile=dteapi.jar
call mvn
install:install-file -DgroupId=birt-runtime -DartifactId=js -Dversion=2.1.0
-Dpackaging=jar -Dfile=js.jar
But each time i run "Maven test" these dependencies are "downloaded":
url = http://repo1.maven.org/maven2
Downloading:
http://repo1.maven.org/maven2/birt-runtime/engineapi/2.1.0/e ngineapi-2.1.0.pom
Downloading:
http://repo1.maven.org/maven2/birt-runtime/coreapi/2.1.0/cor eapi-2.1.0.pom
Downloading:
http://repo1.maven.org/maven2/birt-runtime/modelapi/2.1.0/mo delapi-2.1.0.pom
Downloading: http://repo1.maven.org/maven2/com/ibm/icu/3.8.1/icu-3.8.1.po m
Downloading:
http://repo1.maven.org/maven2/org/apache/commons/codec/1.3.0 /codec-1.3.0.pom
Downloading:
http://repo1.maven.org/maven2/birt-runtime/js/2.1.0/js-2.1.0 .pom
It is beginning to take a pretty long time compared to actually executing
the test. Is there some way to disable this?
Re: Disable download from local repository? [message #24595 is a reply to message #24552] Mon, 30 March 2009 19:03 Go to previous messageGo to next message
Originally posted by: igor.ifedorenko.com
It is not clear from your question if performance problem occurs when
you run maven test from cli or from m2e.
Assuming you see the problem in m2e, can you please check if pom.xml
files are present in the local repository for the JARs you've installed
with install:install-file? FYI, the problem sounds like
https://issues.sonatype.org/browse/MNGECLIPSE-523 although maven install
plugin is supposed to generate pom.xml in your case.
Igor
> call mvn install:install-file -DgroupId=birt-runtime
> -DartifactId=coreapi -Dversion=2.1.0 -Dpackaging=jar -Dfile=coreapi.jar
> -DartifactId=engineapi -Dversion=2.1.0 -Dpackaging=jar -Dfile=engineapi.jar
> -DartifactId=modelapi -Dversion=2.1.0 -Dpackaging=jar -Dfile=modelapi.jar
> call mvn install:install-file -DgroupId=com.ibm -DartifactId=icu
> -Dversion=3.8.1 -Dpackaging=jar -Dfile=com.ibm.icu_3.8.1.v20080530.jar
> call mvn install:install-file -DgroupId=org.apache.commons
> -DartifactId=codec -Dversion=1.3.0 -Dpackaging=jar
> -DartifactId=scriptapi -Dversion=2.1.0 -Dpackaging=jar -Dfile=scriptapi.jar
> call mvn install:install-file -DgroupId=birt-runtime -DartifactId=dteapi
> -Dversion=2.1.0 -Dpackaging=jar -Dfile=dteapi.jar
> call mvn install:install-file -DgroupId=birt-runtime -DartifactId=js
> -Dversion=2.1.0 -Dpackaging=jar -Dfile=js.jar
> Downloading:
> Downloading:
> Downloading:
> Downloading:
> Downloading:
> executing the test. Is there some way to disable this?
Re: Disable download from local repository? [message #24635 is a reply to message #24595] Tue, 31 March 2009 05:51 Go to previous messageGo to next message
I run the "Maven test" preset from eclipse (not from the commandline). In
eclipse its called Maven Integration not sure if this relates to m2e or
Maven Cli.
In each folder (of the manually installed jars) in the local repository
there is a file:
maven-metadata-local.xml
but thats it. There is no pom.xml file. But there is no pom.xml file in the
other folder which I did not install manually. Some of them have a *.pom
file though.
"Igor Fedorenko" <igor@ifedorenko.com> wrote in message
news:gqrj3u$ccn$1@build.eclipse.org...
> It is not clear from your question if performance problem occurs when you
> Assuming you see the problem in m2e, can you please check if pom.xml files
> are present in the local repository for the JARs you've installed with
> Regards,
> Igor
>> call mvn
>> call mvn
>> call mvn
>> call mvn
>> call mvn
>> call mvn
>> call mvn
>> call mvn
>> Downloading:
>> Downloading:
>> Downloading:
>> Downloading:
>> Downloading:
>> Downloading:
Re: Disable download from local repository? [message #24676 is a reply to message #24635] Wed, 01 April 2009 00:17 Go to previous messageGo to next message
If some pom.xml files are missing, then this is definitely
MNGECLIPSE-523. Try using
mvn install:install-file -DgeneratePom=true ...
to force pom.xml generation.
Igor
> In eclipse its called Maven Integration not sure if this relates to m2e
> or Maven Cli.
> there is a file:
> the other folder which I did not install manually. Some of them have a
> *.pom file though.
>> installed with install:install-file? FYI, the problem sounds like
>> install plugin is supposed to generate pom.xml in your case.
>> Regards,
>> Igor
>>> -Dfile=modelapi.jar
>>> -DartifactId=dteapi -Dversion=2.1.0 -Dpackaging=jar -Dfile=dteapi.jar
>>> Downloading:
>>> Downloading:
>>> Downloading:
>>> Downloading:
>>> Downloading:
>>> Downloading:
Re: Disable download from local repository? [message #24716 is a reply to message #24676] Wed, 01 April 2009 03:32 Go to previous message
Thank you very much, that worked!
news:gqupru$r99$1@build.eclipse.org...
> If some pom.xml files are missing, then this is definitely MNGECLIPSE-523.
> Try using
> Regards,
> Igor
>> or Maven Cli.
>> there is a file:
>> *.pom file though.
>>> Regards,
>>> Igor
>>>> call mvn
>>>> call mvn
>>>> call mvn
>>>> call mvn
>>>> call mvn
>>>> call mvn
>>>> call mvn
>>>> call mvn
>>>> Downloading:
>>>> Downloading:
>>>> Downloading:
>>>> Downloading:
>>>> Downloading:
>>>> Downloading:
Previous Topic:Can child modules be mutually dependent?
Next Topic:conflicts when installing m2eclipse
Current Time: Sun Nov 02 18:19:24 EST 2025
Powered by FUDForum. Page generated in 0.03975 seconds
