Home » Language IDEs » Java Development Tools (JDT) » eclipse plugin generator problem
eclipse plugin generator problem [message #246004] |
Thu, 19 July 2007 09:12  |
Originally posted by: hannes.de-bondt.org
I am writing a plugin generator. the generated plugin is an editor. the
Idea is, you walk trough a wizard, and afterwards, you have a generated
plugin.
The code is generated, but now I have following problem,
"The project was not built since its build path is incomplete. Cannot
find the class file for java.lang.Object. Fix the build path then try
building this project"
what should I do, in which file can I specify the build-path?
thanx in advance.
Hannes
Re: eclipse plugin generator problem [message #246014 is a reply to message #246004] |
Thu, 19 July 2007 09:26   |
--------------020604090908060407010402
Hannes,
Hopefully the JDT guys won't look at this and say, gross! ;-) Here's
an example of how we create a plugin project in EMF (and you're probably
missing the JRE setup):
public static IProject createEMFProject
(IPath javaSource,
URI projectLocationURI,
List<IProject> referencedProjects,
Monitor monitor,
int style,
List<?> pluginVariables)
IProgressMonitor progressMonitor =
BasicMonitor.toIProgressMonitor(monitor);
String projectName = javaSource.segment(0);
IProject project = null;
try
List<IClasspathEntry> classpathEntries = new
UniqueEList<IClasspathEntry>();
progressMonitor.beginTask("", 10);
progressMonitor.subTask
(CodeGenEcorePlugin.INSTANCE.getString
("_UI_CreatingEMFProject_message",
new Object [] { projectName, projectLocationURI !=
null ? projectLocationURI.toString() : projectName }));
IWorkspace workspace = ResourcesPlugin.getWorkspace();
project = workspace.getRoot().getProject(projectName);
// Clean up any old project information.
if (!project.exists())
URI location = projectLocationURI;
if (location == null)
location =
URI.createFileURI(workspace.getRoot().getLocation().append(p rojectName).toOSString());
location = location.appendSegment(".project");
File projectFile = new File(location.toString());
if (projectFile.exists())
projectFile.renameTo(new File(location.toString() +
".old"));
IJavaProject javaProject = JavaCore.create(project);
IProjectDescription projectDescription = null;
ResourcesPlugin.getWorkspace().newProjectDescription(project Name);
if (projectLocationURI != null)
projectDescription.setLocationURI(new
java.net.URI(projectLocationURI.toString()));
project.create(projectDescription, new
SubProgressMonitor(progressMonitor, 1));
else
projectDescription = project.getDescription();
classpathEntries.addAll(Arrays.asList(javaProject.getRawClas spath()));
boolean isInitiallyEmpty = classpathEntries.isEmpty();
if (referencedProjects.size() != 0 && (style &
(EMF_PLUGIN_PROJECT_STYLE | EMF_EMPTY_PROJECT_STYLE)) == 0)
projectDescription.setReferencedProjects
(referencedProjects.toArray(new
IProject[referencedProjects.size()]));
for (IProject referencedProject : referencedProjects)
IClasspathEntry referencedProjectClasspathEntry =
JavaCore.newProjectEntry(referencedProject.getFullPath());
classpathEntries.add(referencedProjectClasspathEntry);
String [] natureIds = projectDescription.getNatureIds();
if (natureIds == null)
natureIds = new String [] { JavaCore.NATURE_ID };
else
boolean hasJavaNature = false;
boolean hasPDENature = false;
for (int i = 0; i < natureIds.length; ++i)
if (JavaCore.NATURE_ID.equals(natureIds[i]))
hasJavaNature = true;
if ("org.eclipse.pde.PluginNature".equals(natureIds[i]))
hasPDENature = true;
if (!hasJavaNature)
String [] oldNatureIds = natureIds;
natureIds = new String [oldNatureIds.length + 1];
System.arraycopy(oldNatureIds, 0, natureIds, 0,
oldNatureIds.length);
natureIds[oldNatureIds.length] = JavaCore.NATURE_ID;
if (!hasPDENature)
"org.eclipse.pde.PluginNature";
projectDescription.setNatureIds(natureIds);
ICommand [] builders = projectDescription.getBuildSpec();
if (builders == null)
builders = new ICommand [0];
boolean hasManifestBuilder = false;
boolean hasSchemaBuilder = false;
for (int i = 0; i < builders.length; ++i)
if
("org.eclipse.pde.ManifestBuilder".equals(builders[i].getBuilderName()))
hasManifestBuilder = true;
if
("org.eclipse.pde.SchemaBuilder".equals(builders[i].getBuilderName()))
hasSchemaBuilder = true;
if (!hasManifestBuilder)
ICommand [] oldBuilders = builders;
builders = new ICommand [oldBuilders.length + 1];
System.arraycopy(oldBuilders, 0, builders, 0,
oldBuilders.length);
builders[oldBuilders.length] =
projectDescription.newCommand();
builders[oldBuilders.length].setBuilderName("org.eclipse.pde.ManifestBuilder ");
if (!hasSchemaBuilder)
builders[oldBuilders.length].setBuilderName("org.eclipse.pde.SchemaBuilder ");
projectDescription.setBuildSpec(builders);
project.open(new SubProgressMonitor(progressMonitor, 1));
project.setDescription(projectDescription, new
IContainer sourceContainer = project;
if (javaSource.segmentCount() > 1)
sourceContainer =
project.getFolder(javaSource.removeFirstSegments(1).makeAbso lute());
if (!sourceContainer.exists())
((IFolder)sourceContainer).create(false, true, new
if (isInitiallyEmpty)
IClasspathEntry sourceClasspathEntry =
JavaCore.newSourceEntry(javaSource);
for (Iterator<IClasspathEntry> i =
classpathEntries.iterator(); i.hasNext(); )
IClasspathEntry classpathEntry = i.next();
if (classpathEntry.getPath().isPrefixOf(javaSource))
i.remove();
classpathEntries.add(0, sourceClasspathEntry);
IClasspathEntry jreClasspathEntry =
JavaCore.newVariableEntry
(new Path(JavaRuntime.JRELIB_VARIABLE), new
Path(JavaRuntime.JRESRC_VARIABLE), new
Path(JavaRuntime.JRESRCROOT_VARIABLE));
if
(classpathEntry.getPath().isPrefixOf(jreClasspathEntry.getPa th()))
i.remove();
String jreContainer = JavaRuntime.JRE_CONTAINER;
String complianceLevel =
CodeGenUtil.EclipseUtil.getJavaComplianceLevel(project);
if ("1.5".equals(complianceLevel))
jreContainer +=
" /org.eclipse.jdt.internal.debug.ui.launcher.StandardVMType/J 2SE-1.5 ";
else if ("1.6".equals(complianceLevel))
jreContainer +=
" /org.eclipse.jdt.internal.debug.ui.launcher.StandardVMType/J avaSE-1.6 ";
classpathEntries.add(JavaCore.newContainerEntry(new
Path(jreContainer)));
if ((style & EMF_EMPTY_PROJECT_STYLE) == 0)
if ((style & EMF_PLUGIN_PROJECT_STYLE) != 0)
Path("org.eclipse.pde.core.requiredPlugins")));
// Remove variables since the plugin.xml should
provide the complete path information.
if (classpathEntry.getEntryKind() ==
IClasspathEntry.CPE_VARIABLE &&
!JavaRuntime.JRELIB_VARIABLE.equals(classpathEntry.getPath() .toString())
IClasspathEntry.CPE_PROJECT)
i.remove();
else
CodeGenUtil.EclipseUtil.addClasspathEntries(classpathEntries ,
"ECLIPSE_CORE_RUNTIME", "org.eclipse.core.runtime");
"ECLIPSE_CORE_RESOURCES", "org.eclipse.core.resources");
"EMF_COMMON", "org.eclipse.emf.common");
"EMF_ECORE", "org.eclipse.emf.ecore");
if ((style & EMF_XML_PROJECT_STYLE) != 0)
"EMF_ECORE_XMI", "org.eclipse.emf.ecore.xmi");
if ((style & EMF_MODEL_PROJECT_STYLE) == 0)
"EMF_EDIT", "org.eclipse.emf.edit");
if ((style & EMF_EDIT_PROJECT_STYLE) == 0)
"ECLIPSE_SWT", "org.eclipse.swt");
"ECLIPSE_JFACE", "org.eclipse.jface");
"ECLIPSE_UI_VIEWS", "org.eclipse.ui.views");
"ECLIPSE_UI_EDITORS", "org.eclipse.ui.editors");
"ECLIPSE_UI_IDE", "org.eclipse.ui.ide");
"ECLIPSE_UI_WORKBENCH", "org.eclipse.ui.workbench");
"EMF_COMMON_UI", "org.eclipse.emf.common.ui");
"EMF_EDIT_UI", "org.eclipse.emf.edit.ui");
if ((style & EMF_XML_PROJECT_STYLE) == 0)
if ((style & EMF_TESTS_PROJECT_STYLE) != 0)
"JUNIT", "org.junit");
if (pluginVariables != null)
for (Iterator<?> i = pluginVariables.iterator();
i.hasNext(); )
Object variable = i.next();
if (variable instanceof IClasspathEntry)
classpathEntries.add((IClasspathEntry)variable);
else if (variable instanceof String)
String pluginVariable = (String)variable;
String name;
String id;
int index = pluginVariable.indexOf("=");
if (index == -1)
name =
pluginVariable.replace('.','_').toUpperCase();
id = pluginVariable;
else
name = pluginVariable.substring(0, index);
id = pluginVariable.substring(index + 1);
CodeGenUtil.EclipseUtil.addClasspathEntries(classpathEntries , name, id);
javaProject.setRawClasspath
(classpathEntries.toArray(new
IClasspathEntry[classpathEntries.size()]),
javaProject.setOutputLocation(new Path("/" +
javaSource.segment(0) + "/bin"), new
catch (Exception exception)
exception.printStackTrace();
CodeGenEcorePlugin.INSTANCE.log(exception);
finally
progressMonitor.done();
return project;
> the Idea is, you walk trough a wizard, and afterwards, you have a
> generated plugin.
> thanx in advance.
> Hannes
Content-Type: text/html; charset=ISO-8859-1
<html>
<head>
</head>
Hannes,<br>
<br>
probably missing the JRE setup):<br>
<blockquote><small> public static IProject createEMFProject</small><br>
<small> (IPath javaSource,</small><br>
<small> URI projectLocationURI,</small><br>
<small> List<IProject> referencedProjects,</small><br>
<small> Monitor monitor,</small><br>
<small> int style,</small><br>
<small> List<?> pluginVariables)</small><br>
<small> {</small><br>
<small> IProgressMonitor progressMonitor =
BasicMonitor.toIProgressMonitor(monitor);</small><br>
<small> String projectName = javaSource.segment(0);</small><br>
<small> IProject project = null;</small><br>
<small> try</small><br>
<small> List<IClasspathEntry> classpathEntries = new
UniqueEList<IClasspathEntry>();</small><br>
<small> </small><br>
<small> progressMonitor.beginTask("", 10);</small><br>
<small> progressMonitor.subTask</small><br>
<small> (CodeGenEcorePlugin.INSTANCE.getString</small><br>
<small> ("_UI_CreatingEMFProject_message", </small><br>
<small> new Object [] { projectName, projectLocationURI
!= null ? projectLocationURI.toString() : projectName }));</small><br>
<small> IWorkspace workspace = ResourcesPlugin.getWorkspace();</small><br>
<small> project = workspace.getRoot().getProject(projectName);</small><br>
<small> // Clean up any old project information.</small><br>
<small> //</small><br>
<small> if (!project.exists())</small><br>
<small> URI location = projectLocationURI;</small><br>
<small> if (location == null)</small><br>
<small> location =
URI.createFileURI(workspace.getRoot().getLocation().append(p rojectName).toOSString()); </small><br>
<small> }</small><br>
<small> location = location.appendSegment(".project");</small><br>
<small> File projectFile = new File(location.toString());</small><br>
<small> if (projectFile.exists())</small><br>
<small> projectFile.renameTo(new File(location.toString()
+ ".old"));</small><br>
<small> IJavaProject javaProject = JavaCore.create(project);</small><br>
<small> IProjectDescription projectDescription = null;</small><br>
<small> projectDescription =
ResourcesPlugin.getWorkspace().newProjectDescription(project Name); </small><br>
<small> if (projectLocationURI != null)</small><br>
<small> projectDescription.setLocationURI(new
java.net.URI(projectLocationURI.toString()));</small><br>
<small> project.create(projectDescription, new
SubProgressMonitor(progressMonitor, 1));</small><br>
<small> else </small><br>
<small> projectDescription = project.getDescription();</small><br>
<small>
classpathEntries.addAll(Arrays.asList(javaProject.getRawClas spath())); </small><br>
<small> boolean isInitiallyEmpty = classpathEntries.isEmpty();</small><br>
<small> if (referencedProjects.size() != 0 && (style
& (EMF_PLUGIN_PROJECT_STYLE | EMF_EMPTY_PROJECT_STYLE)) == 0)</small><br>
<small> projectDescription.setReferencedProjects</small><br>
<small> (referencedProjects.toArray(new
IProject[referencedProjects.size()]));</small><br>
<small> for (IProject referencedProject :
referencedProjects)</small><br>
<small> IClasspathEntry referencedProjectClasspathEntry
= JavaCore.newProjectEntry(referencedProject.getFullPath());</small ><br>
<small>
classpathEntries.add(referencedProjectClasspathEntry);</small ><br>
<small> String [] natureIds =
projectDescription.getNatureIds();</small><br>
<small> if (natureIds == null)</small><br>
<small> natureIds = new String [] { JavaCore.NATURE_ID };</small><br>
<small> else</small><br>
<small> boolean hasJavaNature = false;</small><br>
<small> boolean hasPDENature = false;</small><br>
<small> for (int i = 0; i < natureIds.length; ++i)</small><br>
<small> if (JavaCore.NATURE_ID.equals(natureIds[i]))</small><br>
<small> hasJavaNature = true;</small><br>
<small> if
("org.eclipse.pde.PluginNature".equals(natureIds[i]))</small ><br>
<small> hasPDENature = true;</small><br>
<small> if (!hasJavaNature)</small><br>
<small> String [] oldNatureIds = natureIds;</small><br>
<small> natureIds = new String [oldNatureIds.length + 1];</small><br>
<small> System.arraycopy(oldNatureIds, 0, natureIds, 0,
oldNatureIds.length);</small><br>
<small> natureIds[oldNatureIds.length] =
JavaCore.NATURE_ID;</small><br>
<small> if (!hasPDENature)</small><br>
"org.eclipse.pde.PluginNature";</small><br>
<small> projectDescription.setNatureIds(natureIds);</small><br>
<small> ICommand [] builders =
projectDescription.getBuildSpec();</small><br>
<small> if (builders == null)</small><br>
<small> builders = new ICommand [0];</small><br>
<small> boolean hasManifestBuilder = false;</small><br>
<small> boolean hasSchemaBuilder = false;</small><br>
<small> for (int i = 0; i < builders.length; ++i)</small><br>
<small> if
("org.eclipse.pde.ManifestBuilder".equals(builders[i].getBuilderName())) </small><br>
<small> hasManifestBuilder = true;</small><br>
<small> if
("org.eclipse.pde.SchemaBuilder".equals(builders[i].getBuilderName())) </small><br>
<small> hasSchemaBuilder = true;</small><br>
<small> if (!hasManifestBuilder)</small><br>
<small> ICommand [] oldBuilders = builders;</small><br>
<small> builders = new ICommand [oldBuilders.length + 1];</small><br>
<small> System.arraycopy(oldBuilders, 0, builders, 0,
oldBuilders.length);</small><br>
<small> builders[oldBuilders.length] =
projectDescription.newCommand();</small><br>
<small>
builders[oldBuilders.length].setBuilderName("org.eclipse.pde.ManifestBuilder ");</small><br>
<small> if (!hasSchemaBuilder)</small><br>
<small>
builders[oldBuilders.length].setBuilderName("org.eclipse.pde.SchemaBuilder ");</small><br>
<small> projectDescription.setBuildSpec(builders);</small><br>
<small> project.open(new SubProgressMonitor(progressMonitor,
1));</small><br>
<small> project.setDescription(projectDescription, new
<small> IContainer sourceContainer = project;</small><br>
<small> if (javaSource.segmentCount() > 1)</small><br>
<small> sourceContainer =
project.getFolder(javaSource.removeFirstSegments(1).makeAbso lute()); </small><br>
<small> if (!sourceContainer.exists())</small><br>
<small> ((IFolder)sourceContainer).create(false, true,
new SubProgressMonitor(progressMonitor, 1));</small><br>
<small> if (isInitiallyEmpty)</small><br>
<small> IClasspathEntry sourceClasspathEntry = </small><br>
<small> JavaCore.newSourceEntry(javaSource);</small><br>
<small> for (Iterator<IClasspathEntry> i =
classpathEntries.iterator(); i.hasNext(); )</small><br>
<small> IClasspathEntry classpathEntry = i.next();</small><br>
<small> if
(classpathEntry.getPath().isPrefixOf(javaSource))</small><br >
<small> i.remove();</small><br>
<small> classpathEntries.add(0, sourceClasspathEntry);</small><br>
<small> IClasspathEntry jreClasspathEntry =</small><br>
<small> JavaCore.newVariableEntry</small><br>
<small> (new Path(JavaRuntime.JRELIB_VARIABLE), new
Path(JavaRuntime.JRESRCROOT_VARIABLE));</small><br>
<small> if
(classpathEntry.getPath().isPrefixOf(jreClasspathEntry.getPa th())) </small><br>
<small> String jreContainer = JavaRuntime.JRE_CONTAINER;</small><br>
<small> String complianceLevel =
CodeGenUtil.EclipseUtil.getJavaComplianceLevel(project);</small ><br>
<small> if ("1.5".equals(complianceLevel))</small><br>
<small> jreContainer +=
" /org.eclipse.jdt.internal.debug.ui.launcher.StandardVMType/J 2SE-1.5 ";</small><br>
<small> else if ("1.6".equals(complianceLevel))</small><br>
" /org.eclipse.jdt.internal.debug.ui.launcher.StandardVMType/J avaSE-1.6 ";</small><br>
<small>
Path(jreContainer)));</small><br>
<small> if ((style & EMF_EMPTY_PROJECT_STYLE) == 0)</small><br>
<small> if ((style & EMF_PLUGIN_PROJECT_STYLE) != 0)</small><br>
<small>
Path("org.eclipse.pde.core.requiredPlugins")));</small><br >
<small> // Remove variables since the plugin.xml should
provide the complete path information.</small><br>
<small> if (classpathEntry.getEntryKind() ==
IClasspathEntry.CPE_VARIABLE && </small><br>
<small>
||</small><br>
<small> classpathEntry.getEntryKind() ==
IClasspathEntry.CPE_PROJECT)</small><br>
<small>
"ECLIPSE_CORE_RUNTIME", "org.eclipse.core.runtime");</small><br>
<small>
"ECLIPSE_CORE_RESOURCES", "org.eclipse.core.resources");</small><br>
<small>
"EMF_COMMON", "org.eclipse.emf.common");</small><br>
<small>
"EMF_ECORE", "org.eclipse.emf.ecore");</small><br>
<small> if ((style & EMF_XML_PROJECT_STYLE) != 0)</small><br>
<small>
"EMF_ECORE_XMI", "org.eclipse.emf.ecore.xmi");</small><br>
<small> if ((style & EMF_MODEL_PROJECT_STYLE) == 0)</small><br>
<small>
"EMF_EDIT", "org.eclipse.emf.edit");</small><br>
<small> if ((style & EMF_EDIT_PROJECT_STYLE) == 0)</small><br>
<small>
"ECLIPSE_SWT", "org.eclipse.swt");</small><br>
<small>
"ECLIPSE_JFACE", "org.eclipse.jface");</small><br>
<small>
"ECLIPSE_UI_VIEWS", "org.eclipse.ui.views");</small><br>
<small>
"ECLIPSE_UI_EDITORS", "org.eclipse.ui.editors");</small><br>
<small>
"ECLIPSE_UI_IDE", "org.eclipse.ui.ide");</small><br>
<small>
"ECLIPSE_UI_WORKBENCH", "org.eclipse.ui.workbench");</small><br>
<small>
"EMF_COMMON_UI", "org.eclipse.emf.common.ui");</small><br>
<small>
Re: eclipse plugin generator problem [message #246127 is a reply to message #246014] |
Wed, 25 July 2007 08:24   |
I tried to understand the code, but is was very dificult.
I allready had a dirty solution, without the EMF. The deadline for this
project is way to short to chance to EMF now. so I will have to do it
quick and dirty.
But the problem with the wrong build path still exists.
Is there someone who can tell me where (so in which file) I can adapt
the build path.
Thanx in advance
Hannes
Ed Merks wrote:
> Hannes,
> (IPath javaSource,
> Monitor monitor,
> int style,
> try
> location =
> ".old"));
> else
> else
> if (!hasJavaNature)
> if (!hasPDENature)
> if
> if
> sourceContainer =
> i.remove();
> if
> i.remove();
> jreContainer +=
> jreContainer +=
> i.remove();
> else
> i.hasNext(); )
> String name;
> String id;
> if (index == -1)
> name =
> else
> finally
> return project;
>> generated plugin.
>> thanx in advance.
>> Hannes
Re: eclipse plugin generator problem [message #246135 is a reply to message #246127] |
Wed, 25 July 2007 09:27   |
Hannes,
I wasn't trying to suggest you should use EMF, but rather providing a
working example. If you installed EMF you could set breakpoints and
watch the behavior. The most important part of the example below for
you sounds like the setting of the JRE into the classapth and finally
calling setRawClasspath on the Java project. So look closely at the
..classpath file in your result verses a working project and keep in mind
that you just set a good classpath with the right entries to produce
your desired result.
> this project is way to short to chance to EMF now. so I will have to
> do it quick and dirty.
> the build path.
> Thanx in advance
> Hannes
> Ed Merks wrote:
>> Hannes,
>> Here's an example of how we create a plugin project in EMF (and
>> you're probably missing the JRE setup):
>> (IPath javaSource,
>> Monitor monitor,
>> int style,
>> try
>> location =
>> ".old"));
>> else
>> else
>> if
>> if (!hasJavaNature)
>> if (!hasPDENature)
>> if
>> if
>> project.open(new
>> sourceContainer =
>> i.remove();
>> if
>> i.remove();
>> jreContainer +=
>> jreContainer +=
>> i.remove();
>> else
>> i.hasNext(); )
>> String name;
>> String id;
>> if (index == -1)
>> name =
>> else
>> finally
>> return project;
>>> generated plugin.
>>> Cannot find the class file for java.lang.Object. Fix the build path
>>> then try building this project"
>>> thanx in advance.
>>> Hannes
Re: eclipse plugin generator problem [message #246217 is a reply to message #246135] |
Wed, 25 July 2007 18:43  |
In fact, I was looking for using EMF, it looks very nice... but those
damn deadlines...
I'll take a look for the .classpath tomorrow.
Thanx
Hannes
Ed Merks wrote:
> Hannes,
>> the build path.
>> Thanx in advance
>> Hannes
>> Ed Merks wrote:
>>> Hannes,
>>> (IPath javaSource,
>>> Monitor monitor,
>>> int style,
>>> try
>>> location =
>>> ".old"));
>>> else
>>> else
>>> if
>>> if (!hasJavaNature)
>>> if (!hasPDENature)
>>> if
>>> if
>>> project.open(new
>>> sourceContainer =
>>> i.remove();
>>> if
>>> i.remove();
>>> jreContainer +=
>>> jreContainer +=
>>> i.remove();
>>> else
>>> i.hasNext(); )
>>> String name;
>>> String id;
>>> if (index == -1)
>>> name =
>>> else
>>> finally
>>> return project;
>>>> generated plugin.
>>>> thanx in advance.
>>>> Hannes
Current Time: Fri Sep 19 04:23:51 EDT 2025
Powered by FUDForum. Page generated in 0.05071 seconds
