Home » Archived » BIRT » eng.createRunAndRenderTask
eng.createRunAndRenderTask [message #236775] Thu, 03 May 2007 16:16 Go to next message
Originally posted by: joannem.smartmech.com
I am having an issue where I am unable to get past the following in my
java program to create my report using BIRT
task = eng.createRunAndRenderTask(design);
When I display the value of design I get the following
"org.eclipse.birt.report.engine.api.impl.ReportRunnable@1de891b"
The following is my java program....
import java.io.*;
import java.lang.*;
import java.util.HashMap;
import java.util.List;
import java.util.logging.Level;
import org.eclipse.birt.report.engine.api.*;
import org.eclipse.birt.core.framework.Platform;
public class BIRT {
FileOutputStream out; // declare a file output object
PrintStream p; // declare a print stream object
try
// Create a new file output stream
out = new FileOutputStream("myfile.txt",true);
// Connect print stream to the output stream
p = new PrintStream( out );
p.println ("This is written to a file");
// Variables used to control BIRT engine instance
EngineConfig conf = null;
ReportEngine eng = null;
IReportRunnable design = null;
IRunAndRenderTask task = null;
HTMLRenderContext renderContext = null;
HashMap contextMap = null;
HTMLRenderOption options = null;
// Setup the BIRT engine configuration. The Engine Home is hardcoded
// here, this is proably better set in an environment variable or in
// a configuration file. No other options need to be set
conf = new EngineConfig( );
conf.setEngineHome("/home/rci/BIRT2/birt-runtime-2_1_1/ReportEngine ");
conf.setLogConfig("/usr/Local", Level.ALL);
// System.out.println("I am here!");
p.println ("I am here");
// Create new Report engine based off of the configuration
eng = new ReportEngine( conf );
// With our new engine, lets try to open the report design
try
p.println ("before design");
design =
eng.openReportDesign("/home/rci/BIRT2/workspace/netrec/netrecloc.rptdesign ");
p.println ("After design");
catch (Exception e)
p.println ("An error occured during the opening of the report
file!");
//System.err.println("An error occured during the opening of the
report file!");
e.printStackTrace();
System.exit(-1);
p.println ("Before assign task");
p.println ("The design is " + design);
// With the file open, create the Run and Render task to run the report
p.println ("after task");
p.println ("task is " + task);
// Set Render context to handle url and image locations, and apply to
the
// task
renderContext = new HTMLRenderContext();
renderContext.setImageDirectory("image");
contextMap = new HashMap();
contextMap.put(EngineConstants.APPCONTEXT_HTML_RENDER_CONTEX T,
renderContext );
task.setAppContext( contextMap );
p.println ("task set appcontext");
// This will set the output file location, the format to render to, and
// apply to the task
options = new HTMLRenderOption();
options.setOutputFileName("/var/www/html/smech/repout/test.html ");
options.setOutputFormat("html");
task.setRenderOption(options);
try
p.println ("before task.run");
task.run();
catch (Exception e)
p.println ("An error occured while running the report!");
//System.err.println("An error occurred while running the report!");
System.exit(-1);
// Destroy the engine and let the garbage collector
// do its thing
p.println ("All went well. Closing program!");
//System.out.println("All went well. Closing program!");
eng.destroy();
p.close();
} // try
catch (Exception eout)
System.err.println ("Error writing to file");
} // catch
} // main
} // BIRT
Any suggestions why I can't get past the createRunAndRenderTask , would be
greatly appreciated.
Re: eng.createRunAndRenderTask [message #236780 is a reply to message #236775] Thu, 03 May 2007 18:11 Go to previous messageGo to next message
Originally posted by: jasonweathersby.alltel.net
Jo-Anne,
Take a look at this example.
http://wiki.eclipse.org/index.php/Simple_Execute
Also can you post the stack trace?
Jason
> import java.io.*;
> import java.lang.*;
> public class BIRT {
> public static void main(String[] args) {
> try
> try
> { // System.out.println("I am here!");
> design =
> catch (Exception e)
> p.println ("An error occured during the opening of the report file!");
> report file!");
> System.exit(-1);
> // Set Render context to handle url and image locations, and apply to the
> // task
> renderContext );
> try
> task.run();
> catch (Exception e)
> System.exit(-1);
> // do its thing
> eng.destroy();
> p.close();
> } // try
> } // catch
> } // main
> } // BIRT
> be greatly appreciated.
Re: eng.createRunAndRenderTask [message #237102 is a reply to message #236780] Tue, 08 May 2007 13:52 Go to previous messageGo to next message
This is a portion of my log file from when I run the report.... It's 1926
lines so I didn't put it all on. I'm not sure what I'm doing wrong!
May 3, 2007 3:48:26 PM
org.eclipse.birt.report.engine.api.impl.ReportEngine setu
pScriptScope
INFO: Error occurs while initialze script scope
org.mozilla.javascript.EvaluatorException: Cannot add a property to a
sealed obj
ect. ()
at
org.mozilla.javascript.DefaultErrorReporter.runtimeError(Def aultError
Reporter.java:76)
at
org.mozilla.javascript.Context.reportRuntimeError(Context.ja va:591)
at
org.mozilla.javascript.Context.reportRuntimeError(Context.ja va:630)
at
org.mozilla.javascript.Context.reportRuntimeError0(Context.j ava:600)
at
org.mozilla.javascript.ScriptableObject.addSlot(ScriptableOb ject.java
:1685)
at
org.mozilla.javascript.ScriptableObject.getSlotToSet(Scripta bleObject
java:1647)
at
org.mozilla.javascript.ScriptableObject.put(ScriptableObject .java:247
at org.mozilla.javascript.IdScriptable.put(IdScriptable.java:11 1)
at
org.mozilla.javascript.ScriptableObject.defineProperty(Scrip tableObje
ct.java:1077)
at
org.mozilla.javascript.IdScriptable.defineProperty(IdScripta ble.java:
194)
at
ct.java:1103)
at
org.mozilla.javascript.IdScriptable.addIdFunctionProperty(Id Scriptabl
e.java:451)
at
org.mozilla.javascript.NativeString.fillConstructorPropertie s(NativeS
tring.java:71)
at
org.mozilla.javascript.IdScriptable.addAsPrototype(IdScripta ble.java:
424)
at org.mozilla.javascript.NativeString.init(NativeString.java:5 7)
at
org.mozilla.javascript.Context.initStandardObjects(Context.j ava:703)
at
org.eclipse.birt.report.engine.api.impl.ReportEngine.setupSc riptScope
(ReportEngine.java:122)
at
org.eclipse.birt.report.engine.api.impl.ReportEngine.<init>(ReportEng
ine.java:89)
at
org.eclipse.birt.report.engine.api.impl.ReportEngineFactory. createRep
ortEngine(ReportEngineFactory.java:13)
at
org.eclipse.birt.report.engine.api.ReportEngine.<init>(ReportEngine.j
ava:55)
at BIRT.main(BIRT.java:70)
org.eclipse.birt.report.engine.api.impl.ReportEngine open
ReportDesign
....... ( a lot more lines in between ) ........
FINE: ReportEngine.openReportDesign:
designName=/home/rci/BIRT2/workspace/netrec
org.eclipse.birt.report.model.metadata.ChoicePropertyType
validateXml
FINE: return internal name for choice Fixed
May 3, 2007 3:48:28 PM
org.eclipse.birt.report.model.metadata.DimensionPropertyT
ype validateXml
FINE: return dimension value with user defined unit 0.075in
validateXml
ype validateXml
validateXml
ype validateXml
validateXml
org.eclipse.birt.report.engine.api.impl.ReportEngine crea
teRunAndRenderTask
FINE: ReportEngine.createRunAndRenderTask:
reportRunnable=org.eclipse.birt.repor
Re: eng.createRunAndRenderTask [message #237135 is a reply to message #237102] Tue, 08 May 2007 14:42 Go to previous messageGo to next message
Jo-Anne,
Does this just happen with the one report?
Can you create a report that just has a label and try it?
Also what version of BIRT are you using to design the reports?
Jason
> 1926 lines so I didn't put it all on. I'm not sure what I'm doing wrong!
> pScriptScope
> scope
> sealed obj
> ect.
> at
> Reporter.java:76)
> at
> at
> at
> at
> :1685)
> at
> java:1647)
> at
> at
> at
> ct.java:1077)
> at
> 194)
> at
> ct.java:1103)
> at
> e.java:451)
> at
> tring.java:71)
> at
> 424)
> at
> at
> at
> at
> ine.java:89)
> at
> at
> ava:55)
> at
> BIRT.main(BIRT.java:70) May
> 3, 2007 3:48:26 PM org.eclipse.birt.report.engine.api.impl.ReportEngine
> open
> ReportDesign ...... ( a lot more lines in between )
> validateXml
> Fixed May 3, 2007 3:48:28 PM
> ype
> validateXml
> 0.075in May 3, 2007 3:48:28 PM
> validateXml
> ype
> validateXml
> validateXml
> ype
> validateXml
> validateXml
> teRunAndRenderTask
Re: eng.createRunAndRenderTask [message #237159 is a reply to message #237135] Tue, 08 May 2007 15:20 Go to previous messageGo to next message
Yes I have just tried the one report but will take your suggestion. I'm
using Birt 2.1.1. I looked at the reference you made for the simple
execution but I get errors on the HashMap. I'm using java version 1.4.1,
does it have to be a newer version to use HashMap?
Re: eng.createRunAndRenderTask [message #237189 is a reply to message #237159] Tue, 08 May 2007 16:23 Go to previous messageGo to next message
Jo-Anne,
Just change the maps to the correct 1.4 syntax.
Jason
> 1.4.1, does it have to be a newer version to use HashMap?
Re: eng.createRunAndRenderTask [message #237329 is a reply to message #237189] Wed, 09 May 2007 11:39 Go to previous messageGo to next message
Thanks for you suggestions. I've made a simple report with just a label
in it and I still cannot get past that part in my java program to
RunAndRender. I've been searching the web trying to find something.
There is another person who appear to have this issue and your comment was
to use the supplied birt.war file. How is the war file used? Right now
it's sitting in my birt-runtime-2_1_1 directory. Is there something I'm
supposed to be doing with it? I put it in the classpath as I wasn't sure
if I needed it or not.
Re: eng.createRunAndRenderTask [message #237340 is a reply to message #237329] Wed, 09 May 2007 13:52 Go to previous messageGo to next message
Jo-Anne,
Here is an example that works in my 2.1.1 install. Verify that the
2.1.1 libs are in your buildpath.
Jason
import java.util.ArrayList;
import org.eclipse.birt.report.engine.api.EngineConfig;
import org.eclipse.birt.report.engine.api.EngineConstants;
import org.eclipse.birt.report.engine.api.EngineException;
import org.eclipse.birt.report.engine.api.HTMLActionHandler;
import org.eclipse.birt.report.engine.api.HTMLEmitterConfig;
import org.eclipse.birt.report.engine.api.HTMLRenderContext;
import org.eclipse.birt.report.engine.api.HTMLRenderOption;
import org.eclipse.birt.report.engine.api.HTMLServerImageHandler;
import org.eclipse.birt.report.engine.api.IReportEngine;
import org.eclipse.birt.report.engine.api.IReportEngineFactory;
import org.eclipse.birt.report.engine.api.IReportRunnable;
import org.eclipse.birt.report.engine.api.IRunAndRenderTask;
public class ExecuteReport {
public void runReport() throws EngineException
HashMap parameters = new HashMap();
String name = "Top Count";
Integer pvalue = new Integer(4);
parameters.put(name, pvalue);
IReportEngine engine=null;
EngineConfig config = null;
//config.setRourcePath()
try{
//Configure the Engine and start the Platform
config = new EngineConfig( );
config.setEngineHome(
"C:/birt-runtime-2_1_1/birt-runtime-2_1_1/ReportEngine" );
config.setLogConfig(null, Level.FINE);
config.setResourcePath("c:/mybirtresources/");
Platform.startup( config );
IReportEngineFactory factory = (IReportEngineFactory) Platform
.createFactoryObject(
IReportEngineFactory.EXTENSION_REPORT_ENGINE_FACTORY );
engine = factory.createReportEngine( config );
engine.changeLogLevel( Level.WARNING );
}catch( Exception ex){
ex.printStackTrace();
//Configure the emitter to handle actions and images
HTMLEmitterConfig emitterConfig = new HTMLEmitterConfig( );
emitterConfig.setActionHandler( new HTMLActionHandler( ) );
HTMLServerImageHandler imageHandler = new HTMLServerImageHandler( );
emitterConfig.setImageHandler( imageHandler );
config.getEmitterConfigs( ).put( "html", emitterConfig ); //$NON-NLS-1$
//Open the report design
design = engine.openReportDesign("C:/temp/ProdLineChart.rptdesign");
//Create task to run and render the report,
IRunAndRenderTask task = engine.createRunAndRenderTask(design);
//Set Render context to handle url and image locataions
HTMLRenderContext renderContext = new HTMLRenderContext();
//Set the Base URL for all actions
renderContext.setBaseURL("http://localhost/");
//Tell the Engine to prepend all images with this URL - Note this
requires using the HTMLServerImageHandler
//renderContext.setBaseImageURL("http://localhost/myimages");
renderContext.setBaseImageURL("file:///c:/temp/");
//Tell the Engine where to write the images to
renderContext.setImageDirectory("C:/temp/");
//Tell the Engine what image formats are supported. Note you must
have SVG in the string
//to render charts in SVG.
renderContext.setSupportedImageFormats("JPG;PNG;BMP;SVG");
HashMap contextMap = new HashMap();
contextMap.put( EngineConstants.APPCONTEXT_HTML_RENDER_CONTEXT,
renderContext );
//Set parameters for the report
task.setParameterValues(parameters);
//Alternatively set each seperately
//task.setParameterValue("Top Count", new Integer(12));
task.validateParameters();
HTMLRenderOption options = new HTMLRenderOption();
//Remove HTML and Body tags
//options.setEmbeddable(true);
//Set ouptut location
options.setOutputFileName("C:/temp/output.html");
//options.setOutputStream(response.getOutputStream());
//Set output format
//run the report and destroy the engine
//Note - If the program stays resident do not shutdown the Platform
or the Engine
task.run();
task.close();
engine.shutdown();
Platform.shutdown();
System.out.println("Finished");
* @param args
try
ExecuteReport ex = new ExecuteReport( );
ex.runReport();
catch ( Exception e )
> was to use the supplied birt.war file. How is the war file used? Right
> now it's sitting in my birt-runtime-2_1_1 directory. Is there something
> I'm supposed to be doing with it? I put it in the classpath as I wasn't
> sure if I needed it or not.
Re: eng.createRunAndRenderTask [message #237548 is a reply to message #237340] Thu, 10 May 2007 11:22 Go to previous messageGo to next message
Thanks for that program Jason, I still get stopped at the same spot. I've
been trying to find something on the net regarding the following error
that I get
Exception in thread "main" java.lang.NoSuchMethodError:
org.mozilla.javascript.ImporterTopLevel.initStandardObjects( Lorg/mozilla/javascript/Context;Z)V
at
org.eclipse.birt.core.script.ScriptContext.<init>(ScriptContext.java:81)
What I've been finding keeps referring to the js.jar files in the
classpath. I have the following js.jar files on the system
/tomcat5/webapps/birt-viewer/WEB-INF/lib/js.jar
/tomcat5/webapps/birt-viewer/WEB-INF/platform/plugins/org.mo zilla.rhino/lib/js.jar
/eclipse/plugins/org.mozilla.rhino_1.6.0.v20060629-0630/lib/ js.jar
/birt-runtime-2_1_1/ReportEngine/lib/js.jar
/birt-runtime-2_1_1/ReportEngine/plugins/org.mozilla.rhino/l ib/js.jar
/birt-runtime-2_1_1/WebViewerExample/WEB-INF/lib/js.jar
/birt-runtime-2_1_1/WebViewerExample/WEB-INF/platform/plugin s/org.mozilla.rhino/lib/js.jar
/birt-runtime-2_1_1/ChartEngine/js.jar
Should all these js.jar files be included in the classpath? Does the
order they are in make a difference?
Re: eng.createRunAndRenderTask [message #237588 is a reply to message #237548] Thu, 10 May 2007 11:53 Go to previous messageGo to next message
Jo-Anne,
All the libs in the ReportEngine/lib should be in your classpath.
Jason
> I've been trying to find something on the net regarding the following
> error that I get
> at
Re: eng.createRunAndRenderTask [message #237619 is a reply to message #237588] Thu, 10 May 2007 14:03 Go to previous messageGo to next message
Just double checked and they are... I'm really stumped by this!
Re: eng.createRunAndRenderTask [message #237627 is a reply to message #237619] Thu, 10 May 2007 14:23 Go to previous messageGo to next message
Jo-Anne,
How are you building the example?
Are you using the BIRT Allinone 2.1.1 download, starting a new java
project, adding the ReportEngine/libs to the buildpath and then creating
your java class?
Jason
Re: eng.createRunAndRenderTask [message #237648 is a reply to message #237627] Thu, 10 May 2007 14:56 Go to previous messageGo to next message
I'm very new to this, and not so familiar with java, so I'll try to
explain what I've done.
The BIRT Allinone 2.1.1 download was used for installation. I am using a
linux system, if that makes a difference. I created a report template in
BIRT. I added the files from ReportEngine/lib to my classpath. I have
created a java program, then used the one you sent me to try and generate
this report.... but can't get past the RunAndRenderTask. This java
program is called from a background process created with php.
This is the class path that I'm using.
CLASSPATH=/usr/java142/lib/tools.jar:.:/opt/StyleReportEE/bi n/lax.jar:/opt/Style
ReportEE/lib/design_pro.jar:/opt/StyleReportEE/lib/etools.ja r:/opt/StyleReportEE
/lib/sree_pro.jar:/var/www/html/smech:/home/rci/BIRT2/eclips e/plugins/com.lowagi
e.itext_1.3.0.v20060909-0630/lib/itext-1.3.jar:/home/rci/BIR T2/birt-runtime-2_1_
1/ReportEngine:/home/rci/BIRT2/birt-runtime-2_1_1/ReportEngi ne/lib/chartengineap
i.jar:/home/rci/BIRT2/birt-runtime-2_1_1/ReportEngine/lib/co m.ibm.icu_3.4.4.1.ja
r:/home/rci/BIRT2/birt-runtime-2_1_1/ReportEngine/lib/common s-cli-1.0.jar:/home/
rci/BIRT2/birt-runtime-2_1_1/ReportEngine/lib/commons-codec- 1.3.jar:/home/rci/BI
RT2/birt-runtime-2_1_1/ReportEngine/lib/coreapi.jar:/home/rc i/BIRT2/birt-runtime
-2_1_1/ReportEngine/lib/dataadapterapi.jar:/home/rci/BIRT2/b irt-runtime-2_1_1/Re
portEngine/lib/dteapi.jar:/home/rci/BIRT2/birt-runtime-2_1_1 /ReportEngine/lib/en
gineapi.jar:/home/rci/BIRT2/birt-runtime-2_1_1/ReportEngine/ lib/flute.jar:/home/
rci/BIRT2/birt-rutnime-2_1_1/ReportEngine/lib/js.jar:/home/r ci/BIRT2/birt-runtim
e-2_1_1/ReportEngine/lib/modelapi.jar:/home/rci/BIRT2/birt-r untime-2_1_1/ReportE
ngine/lib/org.eclipse.emf.common_2.2.0.v200606051102.jar:/ho me/rci/BIRT2/birt-ru
ntime-2_1_1/ReportEngine/lib/org.eclipse.emf.ecore_2.2.0.v20 0606051102.jar:/home
/rci/BIRT2/birt-runtime-2_1_1/ReportEngine/lib/org.eclipse.e mf.ecore.xmi_2.2.0.v
200606051102.jar:/home/rci/BIRT2/birt-runtime-2_1_1/ReportEn gine/lib/sac.jar:/ho
me/rci/BIRT2/birt-runtime-2_1_1/ReportEngine/lib/scriptapi.j ar:/home/rci/BIRT2/e
clipse/plugins:/opt/sybase/SYBSsa9/java/jodbc.jar:
Re: eng.createRunAndRenderTask [message #237666 is a reply to message #237648] Thu, 10 May 2007 15:21 Go to previous message
Jo-Anne,
That looks proper. Can you try using the Allinone Linux distro to
create a Java Project? If you can get it working in the designer this
may lead to what the issue is in deployment. First create a new project
in the allione and specify it as a java project. Right click on the new
project and modify the build path. Choose libs and add all the libs
under the ReportEngine/lib folder. Next right click on the new Java
Class and enter the code I sent you. Make sure you modify the paths to
yours. After it compiles, right click on the class and choose debug as
Java application. This should bring up the launch configuration. Select
ok and the output should show in the console view.
Alternatively you could use the genReport.bat file and run it. Open the
bat file and modify the classpath and set BIRT_HOME. Verify that the
program runs fine.
Jason
> a linux system, if that makes a difference. I created a report template
> in BIRT. I added the files from ReportEngine/lib to my classpath. I
> have created a java program, then used the one you sent me to try and
> generate this report.... but can't get past the RunAndRenderTask. This
> java program is called from a background process created with php.
Previous Topic:Nightly Builds
Next Topic:Parameters (command line)
Current Time: Sat Jun 14 17:19:41 EDT 2025
Powered by FUDForum. Page generated in 0.07024 seconds
