Home » Eclipse Projects » GEF » TranslateToAbsolute() with ScrollPane
TranslateToAbsolute() with ScrollPane [message #227284] Fri, 01 December 2006 07:41 Go to next message
Originally posted by: Sferzah.yandex.ru
i try to calculate feedback in my OrderedLayoutPolicy, but i have a
problem with it when scrollbar is active. How TranslateToAbsolute() work
in this case? And what have i do to solve this problem?
Re: TranslateToAbsolute() with ScrollPane [message #227346 is a reply to message #227284] Sun, 03 December 2006 21:57 Go to previous messageGo to next message
Hi Alexey,
I doubt that the problem is with TranslateToAbsolute() it always works the
same way... I guess, when you scroll the feedback is not fixed anymore and
moves with the scrolling, in this case you might be translating it
relatively to a figure? Can you provide a more detailed description of the
problem, provide the code of your edit policy? You can try not translating
your feedback bounds into absolute coordinates, maybe that would work. I'd
like to try helping you out, but simply need more information about the
problem.
Thanks in advance.
Alex
Re: TranslateToAbsolute() with ScrollPane [message #227361 is a reply to message #227346] Mon, 04 December 2006 03:20 Go to previous message
Hi Alex,
I just investigate feedback from this example
http://eclipsewiki.editme.com/GefDescription2
and try to use this for my purposes.. this example don't use
TranslateToAbsolute() but work incorrect in some cases.. I add here
TranslateToAbsolute() and point to show feedback calculating correctly.
But when diafram too large and scroll appear - absolute coordinates have
some offset and feedback showing wrong with the same calculating method..
> You can try not translating your feedback bounds into absolute coordinates
how i can do that?
Thanks for help me!
here some methods from my EditPolisy class :
protected IFigure createLayoutTargetFeedback()
Shape f = new RectangleFigure();
f.setBackgroundColor(ColorConstants.black);
addFeedback(f);
return f;
protected void showLayoutTargetFeedback(Request request)
ToolbarLayout layout =
(ToolbarLayout)((AbstractGraphicalEditPart)getHost()).getCon tentPane().getLayoutManager();
boolean verticalLayout = !layout.isHorizontal();
IFigure l = getLayoutTargetFeedback();
AbstractGraphicalEditPart after =
(AbstractGraphicalEditPart)getInsertionReference(request);
Point loc = null;
Dimension size = null;
if(after == null)
{ // нет
следу& #1102;щего
if(getHost().getChildren().size() == 0)
{ // если
вообщ& #1077; нет
детей
Figure contentPane =
(Figure)((AbstractGraphicalEditPart)getHost()).getContentPan e();
int mid = verticalLayout? contentPane.getBounds().height/2 +
contentPane.getLocation().y
: contentPane.getBounds().width/2 +
contentPane.getLocation().x;
loc = verticalLayout? new Point(contentPane.getLocation().x, mid) :
new Point(mid,contentPane.getLocation().y);
contentPane.translateToAbsolute(loc);
if(verticalLayout)
loc.translate(0, FEEDBACK_WIDTH/2);
else
loc.translate(FEEDBACK_WIDTH/2,0);
size = verticalLayout? new
Dimension(contentPane.getSize().width,FEEDBACK_WIDTH)
: new
Dimension(FEEDBACK_WIDTH,contentPane.getSize().height);
else
{ // если дети
уже были,
прост& #1086;
добав& #1083;яем в
конец..
int lastIndex = getHost().getChildren().size()-1;
Figure last =
(Figure)((GraphicalEditPart)getHost().getChildren().get(last Index)).getFigure();
loc = last.getLocation();
loc.getTranslated(0,last.getSize().height):loc.getTranslated (last.getSize().width,0);
last.translateToAbsolute(loc);
new Dimension(last.getBounds().width , FEEDBACK_WIDTH)
: new Dimension(FEEDBACK_WIDTH,last.getBounds().height);
else
{ // встав& #1083;яем
перед кем-то
int indexAfter = getHost().getChildren().indexOf(after);
// IFigure f = after.getFigure();
if(indexAfter == 0)
{// встав& #1083;яем
перед самым
первы& #1084;
Figure first =
(Figure)((GraphicalEditPart)getHost().getChildren().get(0)). getFigure();
loc = first.getLocation();
first.translateToAbsolute(loc);
loc.getTranslated(0,-FEEDBACK_WIDTH):loc.getTranslated(-FEED BACK_WIDTH,0);
new Dimension(first.getBounds().width , FEEDBACK_WIDTH)
: new Dimension(FEEDBACK_WIDTH,first.getBounds().height);
else
{// прост& #1086;
перед кем-то
Figure prec =
(Figure)((GraphicalEditPart)getHost().getChildren().get(inde xAfter-1)).getFigure();
Figure next =
(Figure)((GraphicalEditPart)getHost().getChildren().get(inde xAfter)).getFigure();
if(verticalLayout)
int minPrec = prec.getLocation().y + prec.getBounds().height;
int maxNext = next.getLocation().y;
int interval = minPrec - maxNext;
int midInterval = minPrec + interval/2;
loc = new Point(prec.getBounds().x, midInterval);
prec.translateToAbsolute(loc);
size = new Dimension(prec.getSize().width, FEEDBACK_WIDTH);
else
int maxPrec = prec.getLocation().x + prec.getBounds().width;
int minNext = next.getLocation().x;
int interval = minNext - maxPrec;
int midInterval = maxPrec + interval/2;
loc = new Point(midInterval, prec.getBounds().y);
size = new Dimension(FEEDBACK_WIDTH, prec.getSize().height);
Previous Topic:Best way to refresh GraphicalEditor when resource changes outside GEF
Next Topic:keyBinding() Problem
Current Time: Sun Jun 15 23:46:52 EDT 2025
Powered by FUDForum. Page generated in 0.03663 seconds
