Home » Eclipse Projects » GEF » Navigator-like window
Navigator-like window [message #226634] Mon, 20 November 2006 04:06 Go to next message
Originally posted by: divis1969.mail.ru
I'm wondering is it possible to create a Navigator-like view using GEF?
There is an extension point sample (SampleView) that is based on JFace
TreeViewer. It works good for me, but I would like to use the same tree
viewparts I had created for my model.
Unfortunately, I do not know how to use GEF TreeViewer to make it work the
same way as JFace TreeViewer. I had successfuly created a view, based on GEF
TreeViewer, but I can't add DrillDownAdapter to it. Also it works a little
bit weird, but I suppose I just did not complete this example...
Maybe there is some kind of example how to use GEF for Navigator-like view?
I'm using Eclipse 3.2.1, GEF 3.2.0
Dmitry
Re: Navigator-like window [message #226671 is a reply to message #226634] Mon, 20 November 2006 15:42 Go to previous messageGo to next message
Hi Dmitry
Look at the GEF logic editor example. The outline view's hierarchy mode is
GEF TreeViewer.
Cheers...
Anthony
"Dmitry Smirnov" <divis1969@mail.ru> wrote in message
news:ejrr6e$o6n$1@utils.eclipse.org...
> GEF TreeViewer, but I can't add DrillDownAdapter to it. Also it works a
> little bit weird, but I suppose I just did not complete this example...
> view?
> Dmitry
Re: Navigator-like window [message #226800 is a reply to message #226671] Thu, 23 November 2006 08:00 Go to previous messageGo to next message
Thank you Anthony. I've seen this example.
I just did not realize that ContentOutlinePage can used in any view, not
only in Outline.
So, I've implemented some kind of resource browser based on
ContentOutlinePage, but still has some problems
1. I do not know where to get EditDomain, that is needed for TreeViewer's
setEditDomain. I just set it to null. View seems to work, it shows content
in a tree view. But I still not sure, is it correct ot not. My example is
based on GEF example by Elias Volankis I found in internet. (It was a long
time ago, so I just do not remember where I found it :-) )
2. My view seems to not work correctly. I've noticed that when I running it,
if I switch from my view to Eclipse Navigator or vice versa, tools menu of
the view is not shown correctly. It looks like menu is not switched.
Sometimes, I can see both my tree and Navigator tree together (mine is in
toolmenu area, since my menu is shorter and fits into page tabs row.
I've attached the source (it is corrected a litle bit to remove some
proprietary info).
What could be the problems with it?
Dmitry
"Anthony Hunter" <anthonyh@ca.ibm.com> wrote in message
news:ejt41h$rhk$1@utils.eclipse.org...
> Hi Dmitry
> GEF TreeViewer.
> Cheers...
> Anthony
>> Hi,
>> the
>> view?
>> Thanks,
>> Dmitry
Re: Navigator-like window [message #226808 is a reply to message #226671] Thu, 23 November 2006 08:00 Go to previous messageGo to next message
only in Outline.
proprietary info).
Dmitry
> Hi Dmitry
> GEF TreeViewer.
> Cheers...
> Anthony
>> Hi,
>> the
>> view?
>> Thanks,
>> Dmitry
Re: Navigator-like window [message #226824 is a reply to message #226808] Thu, 23 November 2006 12:55 Go to previous messageGo to next message
I've noticed that setting focus on my view is not working well. Seems like
page tab do not receive focus (but setFocus) is called).
news:ek4615$bkk$2@utils.eclipse.org...
> only in Outline.
> it,
> proprietary info).
> Dmitry
>> Hi Dmitry
>> is
>> GEF TreeViewer.
>> Cheers...
>> Anthony
>>> Hi,
>>> the
>>> view?
>>> Thanks,
>>> Dmitry
Re: Navigator-like window [message #226876 is a reply to message #226808] Fri, 24 November 2006 16:04 Go to previous messageGo to next message
Hi Dmitry,
1. "My example is based on GEF example by Elias Volankis"
The shapes example shows where the editing domain is coming from, your
editor.
2. You mean you have two sets of icons in the view toolbar? Not sure what
the issue is, but you should be able to debug.
Cheers...
Anthony
> only in Outline.
> it,
> proprietary info).
> Dmitry
>> Hi Dmitry
>> is
>> GEF TreeViewer.
>> Cheers...
>> Anthony
>>> Hi,
>>> the
>>> view?
>>> Thanks,
>>> Dmitry
Re: Navigator-like window [message #226972 is a reply to message #226876] Mon, 27 November 2006 11:14 Go to previous message
I've found the root cause.
It is the EditDomain which was null. This causes some problem in processing
setFocus event.
Unfortunately, I do not have an EditDomain since an editor (at least the one
provided with example) is not yet created: my view is some kind of resource
(file) browser (like Package Explorer, CDT C++ Projects view, etc), I start
it from Window->ShowView.
But I has found a solution: I've created a dummy DefaultEditDomain with null
as the argument in its ctor. This works.
I suppose I could encounter some problems in future but it works good for
now.
Dmitry
news:ek7mri$7vp$1@utils.eclipse.org...
> Hi Dmitry,
> editor.
> Cheers...
> Anthony
>> only in Outline.
>> content
>> long
>> it,
>> of
>> proprietary info).
>> Dmitry
>>> Hi Dmitry
>>> is
>>> GEF TreeViewer.
>>> Cheers...
>>> Anthony
>>>> Hi,
>>>> the
>>>> on
>>>> view?
>>>> Thanks,
>>>> Dmitry
Previous Topic:Class Diagram example: multiple selection
Next Topic:Preventing GEF from discovering chidren of a model
Current Time: Sun Jun 15 22:10:28 EDT 2025
Powered by FUDForum. Page generated in 0.08829 seconds
