Home » Eclipse Projects » GEF » UpdateListener.firePainting(Rectangle, Map) causes NullPointerException
UpdateListener.firePainting(Rectangle, Map) causes NullPointerException [message #225387] Mon, 30 October 2006 13:50 Go to next message
I've already submitted a bug report as #162779, but I thought that it would be
good to post here as well, and check to see if anyone else has had similar problems.
I have an editpart viewer that listens for paint events in other editpart
viewers. So, my viewer adds and removes paint listeners from update managers
quite often. As a result, I believe that I found this bug in the UpdateManager
code. I think that it originates in the removeUpdateListener(UpdateListener) source:
public void removeUpdateListener(UpdateListener listener) {
if (listener == null)
throw new IllegalArgumentException();
for (int index = 0; index < listeners.length; index++)
if (listeners[index] == listener) {
int newSize = listeners.length - 1;
/****** BUG Here: newListeners[] is set to null when the new size==0 *****/
UpdateListener newListeners[] = null;
if (newSize != 0) {
newListeners = new UpdateListener[newSize];
System.arraycopy(listeners, 0, newListeners, 0, index);
System.arraycopy(listeners, index + 1, newListeners, index, newSize - index);
/*************** BUG here newListeners is null when newSize == 0 ************/
listeners = newListeners;
return;
Then firePainting(Rectangle, Map) assumes that this.listeners will never be null:
protected void firePainting(Rectangle damage, Map dirtyRegions) {
UpdateListener localListeners[] = listeners;
for (int i = 0; i < localListeners.length; i++)
localListeners[i].notifyPainting(damage, dirtyRegions);
The bug, I believe, can be fixed by either setting the listeners to a size-0
array, or by checking for null.
Here is my stack trace:
3-0\13-0\13-2\00-193-1\03-0\12-0\1org.eclipse.swt.SWTExcepti on: Failed to
execute runnable (java.lang.NullPointerException)
at org.eclipse.swt.SWT.error(SWT.java:3374)
at org.eclipse.swt.SWT.error(SWT.java:3297)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:126)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3325)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2971)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1914)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1878)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:419)
at zestrcp.Application.run(Application.java:18)
at
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:78)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:92)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:68)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:400)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:177)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:336 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:280)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
at org.eclipse.draw2d.UpdateManager.firePainting(UpdateManager. java:113)
at
org.eclipse.draw2d.DeferredUpdateManager.repairDamage(Deferr edUpdateManager.java:267)
at
org.eclipse.draw2d.DeferredUpdateManager.performUpdate(Defer redUpdateManager.java:167)
at
org.eclipse.draw2d.DeferredUpdateManager$UpdateRequest.run(D eferredUpdateManager.java:46)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:123)
... 20 more
Re: UpdateListener.firePainting(Rectangle, Map) causes NullPointerException [message #225441 is a reply to message #225387] Mon, 30 October 2006 22:55 Go to previous messageGo to next message
I agree with you.
Qinxian
在 2006-10-30一的 10:50 -0800,Del Myers写道:
> if (newSize != 0) {
> return;
> at
> at
> at
> at
> at
> at
> ... 20 more
Re: UpdateListener.firePainting(Rectangle, Map) causesNullPointerException [message #225636 is a reply to message #225441] Wed, 01 November 2006 00:55 Go to previous messageGo to next message
Why throw the nullpoint exception, if you add a new updatelistener and
remove it, it don't throw the exception.Because FigureCavas adda a listener
already, so the listen size can't ne zero.
But the code maybe wrong, should be
//declare should be here
if (newSize != 0) {
index);
return;
"Xiang Qinxian" <fyaoxy@gmail.com> wrote in message
news:1162266944.479.42.camel@qinxian.xiang...
I agree with you.
Qinxian
Re: UpdateListener.firePainting(Rectangle, Map) causesNullPointerException [message #225686 is a reply to message #225636] Wed, 01 November 2006 12:19 Go to previous message
Well, none of my code removes the FigureCanvas listener, so obviously something
is going wrong. The fact of the matter is I get a NPE.
Del
> if (newSize != 0) {
> index);
> return;
> I agree with you.
> Regards,
> Qinxian
> ÔÚ 2006-10-30Ò»µÄ 10:50 -0800£¬Del MyersдµÀ£º
>> would be
>> problems.
>> managers
>> UpdateManager
>> if (newSize != 0) {
>> index);
>> return;
>> be null:
>> size-0
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>> at
>> at
>> at
>> at
>> ... 20 more
Previous Topic:Global Copy Action not Working
Next Topic:Moving a block container and its children NOT WORKING
Current Time: Mon Nov 10 03:15:32 EST 2025
Powered by FUDForum. Page generated in 0.04759 seconds
