All of a sudden I can no longer remote debug [message #223005] |
Fri, 20 July 2007 15:44  |
Originally posted by: darrinps.tx.rr.com
OK, working with both Europa and 3.2.1 and they both have the same problem
starting a few hours ago...has been working fine for months (3.2.1 at
least) prior to that.
What happens is that when I try to remote debug, the debugger will attach
just fine and my break points sort of work, but eclipse tells me "Source
not found"!
For example, say I have a breakpoint set at line 20...the debugger shows
that line 20 is stopped at, but it pops up a dialog asking me to attach
source even though the source is clearly there because I just used it to
set the breakpoint.
This just started happening without me doing anything more than just
modifying a file then saving it...didn't even compile locally (did that
remotely).
I've tried rebooting the machine, stopping/starting eclipse, going back to
a prior version, switching the JVM between 1.4.2 and 1.6, doing a clean
build, etc.
What should I try next?
Re: All of a sudden I can no longer remote debug [message #223017 is a reply to message #223005] |
Fri, 20 July 2007 15:56  |
As luck would have it...a few minutes after I posted this I got it to work
after trying for several hours before that.
Not sure what I did to fix it, but I think the last clean after I fixed a
problem with one of the jars (duplicate entry) in the Java Build Path
Libraries might have been what did it.
FUDForum. Page generated in 0.10248 seconds
