Home » Language IDEs » C / C++ IDE (CDT) » Eclipse forgets(?) path to compiler tools
Eclipse forgets(?) path to compiler tools [message #222430] Thu, 21 August 2008 13:48 Go to next message
Here's a curious one.
I have two CDT projects under Eclipse (running on Ubuntu), one is a
(SVN) branch of the other and they are both built with Blackfin GNU
toolchain (bfin-uclinux-gcc etc) and external makefiles.
When I launch make through an Eclipse make target, the branch project
builds fine and the trunk version cannot find the path to the
bfin-uclinux-* tools.
If I delete my workspace .metadata and import the projects it all works
again... for a while... then the trunk project breaks again with the
branch one still working. I haven't found the pattern but a couple of
restarts of Eclipse seems to get it back into the broken state.
This seemed to start happening when I played around with allowing
parallel make processes but I can't be certain that's related.
If I set the path to the toolchain explicitly in my makefiles then it
works (but that's not a suitable long term solution).
Any ideas? Thanks in advance.
Jon
Re: Eclipse forgets(?) path to compiler tools [message #222817 is a reply to message #222430] Mon, 01 September 2008 07:16 Go to previous message
I found the problem. Posting what I found in case it helps anyone else
and it also seems to expose a bug in CDT.
Under project properties, C/C++ Build - Environment I had "Replace
native environment with specified one" on the project that wasn't
working. When I changed it to "Append variables to native environment"
it worked (and this makes sense).
What threw me is that it works for a while with the "Replace..."
setting. Perhaps CDT doesn't properly recognise this flag at times?
Caching issue?
Jon
Jon Wilson wrote:
> Jon
Previous Topic:Eclipse debug configuration automatically runs "make all
Next Topic:Eclipse doesn't find main()
Current Time: Thu Aug 21 16:41:39 EDT 2025
Powered by FUDForum. Page generated in 0.03098 seconds
