Home » Eclipse Projects » Eclipse Platform » Multiple view but using the same View-class (RCP)
Multiple view but using the same View-class (RCP) [message #220206] Thu, 01 April 2004 14:35 Go to next message
Originally posted by: news.vadalus.com
Hi all,
Can anyone tell me whether it is possible to use multiple instances of
the same view class? I have a view which is repeated numerous times in
my perspective, this view is always the same class just showing
different information depending on the values passed to it (imagine a
directory viewer, for example, showing differnet dir views in the same
perspective).
However, I am not sure how I would represent this in the plugin.xml.
Has anyone else done this?
Re: Multiple view but using the same View-class (RCP) [message #220237 is a reply to message #220206] Thu, 01 April 2004 15:21 Go to previous messageGo to next message
Just to clarify, I am not talking about something which would be solved
using
allowMultiple=true
in the plugin.xml.
I want each view to be initialized differently.
Liam
> Hi all,
> perspective).
> Thanks
Re: Multiple view but using the same View-class (RCP) [message #222403 is a reply to message #220237] Tue, 06 April 2004 06:36 Go to previous message
Originally posted by: user.domain.invalid
> using
> allowMultiple=true
> in the plugin.xml.
> Liam
>> Hi all,
>> perspective).
>> Thanks
You can use EditorPart which has an init method.
http://www.coconut-palm-software.com/the_visual_editor/eclip se_rcp
Previous Topic:linking editors with perspectives
Next Topic:Incorrect value from system property "java.io.tmpdir"
Current Time: Wed Sep 03 09:43:03 EDT 2025
Powered by FUDForum. Page generated in 0.06896 seconds
