Home » Language IDEs » ServerTools (WTP) » Web App Context
Web App Context [message #219205] Tue, 12 August 2008 14:24 Go to next message
Originally posted by: nowhere.a.com
In the properties for a project, there is an item named Web Project
Settings which has a single property named Context Root.
My Project name is MYAPP
I set the Context Root to app
Publishing the project produces a directory named:
<webapp>/MYAPP
Should not the directory name for the application follow the context
root name? I was expecting:
<webapp>/app
Wojtek :-)
Re: Web App Context [message #219213 is a reply to message #219205] Tue, 12 August 2008 16:01 Go to previous messageGo to next message
> <webapp>/MYAPP
> <webapp>/app
For the Tomcat support, and probably others, the directory name is
determined by the module's deploy-name as specified in the project's
".settings/org.eclipse.wst.common.component" file.
Larry
Re: Web App Context [message #219221 is a reply to message #219213] Tue, 12 August 2008 17:48 Go to previous messageGo to next message
>> <webapp>/MYAPP
>> Should not the directory name for the application follow the context root
>> <webapp>/app
> For the Tomcat support, and probably others, the directory name is determined
I don't suppose this could be exposed in properties?
Wojtek :-)
Re: Web App Context [message #219228 is a reply to message #219213] Tue, 12 August 2008 17:59 Go to previous messageGo to next message
>> <webapp>/MYAPP
>> <webapp>/app
It seemed that the name should in the attribute "deploy-name". However
when I changed it, I could no longer add the project to the server.
So it seems that the "Add/Remove Projects" in the Server matches the
deploy-name with existing project names.
Oh, and when I exited Eclipse with the file open, Ecplise crashed. No
messages, just a pop-up from windows stating that Eclipse abended.
Wojtek :-)
Re: Web App Context [message #219252 is a reply to message #219228] Wed, 13 August 2008 08:30 Go to previous messageGo to next message
>>> <webapp>/MYAPP
>>> <webapp>/app
WTP continues to have issues if the project name and the deploy-name do
not match. For example, see:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=202541
https://bugs.eclipse.org/bugs/show_bug.cgi?id=154833
Likely a JVM bug. You can check the "eclipse" directory to see if any
crash file was written there that might provide clues.
Larry
Re: Web App Context [message #219260 is a reply to message #219252] Wed, 13 August 2008 10:10 Go to previous message
>>>> <webapp>/MYAPP
>>>> <webapp>/app
>> It seemed that the name should in the attribute "deploy-name". However when
> WTP continues to have issues if the project name and the deploy-name do not
> Likely a JVM bug. You can check the "eclipse" directory to see if any crash
Forgot to look.
I was left with an Eclipse which was "unstable". Every time I tried to
open the project, Project Explorer did not show the project. When I did
a Refresh, two copies of the project were displayed. A deploy only
created MYAPP\WEB-INF\lib. The lib had my external jar files, but the
rest were empty.
It looked like a real mis-match between config files which was not
being cleaned up.
So I ended up deleting Eclipse, then re-installing it. I also created a
new workspace, created a new Web project, then copied in my source.
Thanks for your help.
Wojtek :-)
Previous Topic:Getting "error parsing site stream"
Next Topic:Location of validation method for Context Root
Current Time: Wed Oct 08 10:40:54 EDT 2025
Powered by FUDForum. Page generated in 0.04408 seconds
