Home » Eclipse Projects » Eclipse Platform » Code is done... now what?
Code is done... now what? [message #215613] |
Thu, 25 March 2004 03:44  |
Originally posted by: fayth69.cox.net
I must be totally and completely blind...
I am just learning java and swt. I am able to successfully compile and run
my programs from within the Eclipse environment. Now I would like to send
some of my programs to a friend to show him what I am doing. For the life of
me I cannot find one bit of documentation on what I need to include with the
..java file nor am I familiar with the exact command to use to run it. I've
now peeled my eyelids off for the last 4 hours trying to find documentation.
Could somebody please assist me? I'm so lost and frustrated at this point...
Thank you in advance... fayth
Re: Code is done... now what? [message #215979 is a reply to message #215849] |
Thu, 25 March 2004 16:17   |
Originally posted by: fayth.ut-mapdepot.com
I'm sorry Marcelo, I'm not getting any results. I've told Eclipse to pack
everything it can, I've installed swt.jar and the dll's in the \java\lib
\java\bin folders, I've tried a million variations of the java -classpath
and java -Djava.library.path= command line options. I still get the same
error as before.
Is there some documentation on how to do this? I can't believe this
documentation is not more easily accessible, I don't mean that in a bad
way - I'm just frustrated :P.
Sincerely, Fayth
"marcelo correia" <mcorreia@linkz.com.br> wrote in message
news:c3v5p6$de4$1@eclipse.org...
> Your application needs the swt library.
> I believe you can pack it with your app, or put it into your classpath.
> m.
> Fayth wrote:
> > Marcelo... thank you very much for your response. I receive errors when
I
> > try to run this...
> > Exception in thread "main" java.lang.NoClassDefFoundError:
> > org/eclipse/swt/widgets/Composite
> > at java.lang.ClassLoader.defineClass0(Native Method)
> > at java.lang.ClassLoader.defineClass(Unknown Source)
> > at java.security.SecureClassLoader.defineClass(Unknown Source)
> > at java.net.URLClassLoader.defineClass(Unknown Source)
> > at java.net.URLClassLoader.access$100(Unknown Source)
> > at java.net.URLClassLoader$1.run(Unknown Source)
> > at java.security.AccessController.doPrivileged(Native Method)
> > at java.net.URLClassLoader.findClass(Unknown Source)
> > at java.lang.ClassLoader.loadClass(Unknown Source)
> > at sun.misc.Launcher$AppClassLoader.loadClass(Unknown Source)
> > at java.lang.ClassLoader.loadClassInternal(Unknown Source)
> > I exported the jar like you said, made sure I generated the Manifest
file
> > and selected the Main-Class entry-point. Do I need to export swt.jar
too? Is
> > this a library issue or classpath issue?
> > Sincerely,
> > Fayth
> > news:c3uv2b$4ar$1@eclipse.org...
> >>You can create a jar package for your aplication.
> >>Once you get the package, the command line is:
> >>java -jar yourPackage.jar
> >>remember that you need a Manifest referencing your Main-Class.
> >>m.
> > run
> > send
> > life of
with
> > the
> > I've
> > documentation.
> > point...
Re: Code is done... now what? [message #216005 is a reply to message #215979] |
Thu, 25 March 2004 17:46   |
Originally posted by: Lamont_Gilbert.rigidsoftware.com
Have you created a plugin, or a java program? Are you using any eclipse
clases like SWT in your program, or is it pure java code?
> error as before.
> Sincerely, Fayth
>>m.
> I
>>>try to run this...
> file
> too? Is
>>>Sincerely,
>>> Fayth
>>>>m.
>>>run
>>>send
>>>life of
> with
>>>the
>>>I've
>>>documentation.
>>>point...
Respectfully,
CL Gilbert
"Verily, verily, I say unto you, He that entereth not by the door() into
the sheepfold{}, but climbeth up some other *way, the same is a thief
and a robber." John 10:1
GnuPG Key Fingerprint:
82A6 8893 C2A1 F64E A9AD 19AE 55B2 4CD7 80D2 0A2D
For a free Java interface to Freechess.org see
http://www.rigidsoftware.com/Chess/chess.html
Re: Code is done... now what? [message #216047 is a reply to message #215979] |
Thu, 25 March 2004 18:33   |
Originally posted by: mcorreia.linkz.com.br
Have you tried to put swt.jar at: $JAVA_HOME:/jre/lib/ext ??
m.
> error as before.
> Sincerely, Fayth
>>m.
> I
>>>try to run this...
> file
> too? Is
>>>Sincerely,
>>> Fayth
>>>>m.
>>>run
>>>send
>>>life of
> with
>>>the
>>>I've
>>>documentation.
>>>point...
Re: Code is done... now what? [message #216114 is a reply to message #215979] |
Fri, 26 March 2004 00:26   |
Gilbert and Marcelo... I finally figured out that the swt.jar goes in the
\lib\ext folder, I was correct in putting the dll in the \bin folder. Next I
needed -Djava.library.path=<thepath to \lib\ext> in my command line when I
ran my demo. :)
Thank you both, especially Marcelo, for answering me. I'm on my way!!!!
Sincerely, Fayth
"Fayth" <fayth@ut-mapdepot.com> wrote in message
news:c3vi02$sfj$1@eclipse.org...
> error as before.
> Sincerely, Fayth
> > m.
when
> I
> > > try to run this...
> file
> too? Is
> > > Sincerely,
> > > Fayth
> > >>m.
and
> > > run
> > > send
> > > life of
> with
> > > the
> > > I've
> > > documentation.
> > > point...
Re: Code is done... now what? [message #216222 is a reply to message #216114] |
Fri, 26 March 2004 08:34   |
Cheers
m.
> ran my demo. :)
> Sincerely, Fayth
>>error as before.
>>Sincerely, Fayth
>>>m.
> when
>>I
>>>>try to run this...
>>file
>>too? Is
>>>>Sincerely,
>>>> Fayth
>>>>>m.
> and
>>>>run
>>>>send
>>>>life of
>>with
>>>>the
>>>>I've
>>>>documentation.
>>>>point...
Re: Code is done... now what? [message #216295 is a reply to message #216114] |
Fri, 26 March 2004 09:58   |
> ran my demo. :)
That is odd. Seems like you put the file in the *wrong* \lib\ext
folder. Since you have the JDK, you have two \lib\ext folders. This
folder is loaded automatically by the JRE. So you should not need that
-D line. use that line if you put the jar in your own location
somewhere, which is best anyway because it probably slows the loading fo
the jvm a bit.
you have a \lib\ext folder probably in c:/jdk/jre/lib/ext and another in
c:/program files/java/jre/lib/ext
make sure the java.exe you are running corresponds to the ext folder you
put the swt in.
> Sincerely, Fayth
>>error as before.
>>Sincerely, Fayth
>>>m.
> when
>>I
>>>>try to run this...
>>file
>>too? Is
>>>>Sincerely,
>>>> Fayth
>>>>>m.
> and
>>>>run
>>>>send
>>>>life of
>>with
>>>>the
>>>>I've
>>>>documentation.
>>>>point...
Respectfully,
CL Gilbert
Re: Code is done... now what? [message #216316 is a reply to message #216295] |
Fri, 26 March 2004 10:50   |
So you're saying it SHOULD go in the \j2re.1.4_03\jre\lib\etc??? What
happens when I distribute it to, say, people who only have the java Virtual
Machine installed (11MB versus 136MB)?
Fayth
"CL [dnoyeb] Gilbert" <Lamont_Gilbert@rigidsoftware.com> wrote in message
news:c41g6c$u3u$1@eclipse.org...
the
Next I
I
> > ran my demo. :)
> the jvm a bit.
> put the swt in.
> > Sincerely, Fayth
pack
java -classpath
> >>error as before.
> >>Sincerely, Fayth
> >>>m.
> > when
> >>I
> >>>>try to run this...
> >>file
> >>too? Is
> >>>>Sincerely,
> >>>> Fayth
> >>>>>m.
> > and
> >>>>run
> >>>>send
> >>>>life of
> >>with
> >>>>the
it.
> >>>>I've
> >>>>documentation.
> >>>>point...
> Respectfully,
> CL Gilbert
Re: Code is done... now what? [message #216364 is a reply to message #216316] |
Fri, 26 March 2004 12:21   |
They need the jre(around 10mb). You can put swt.jar on it.
I think thats all you need.
cheers
m.
> Fayth
> the
> Next I
> I
>>>ran my demo. :)
>>the jvm a bit.
>>put the swt in.
>>>Sincerely, Fayth
> pack
> java -classpath
>>>>error as before.
>>>>Sincerely, Fayth
>>>>>m.
>>>when
>>>>I
>>>>>>try to run this...
>>>>file
>>>>too? Is
>>>>>>Sincerely,
>>>>>> Fayth
>>>>>>>m.
>>>and
>>>>>>run
>>>>>>send
>>>>>>life of
>>>>with
>>>>>>the
> it.
>>>>>>I've
>>>>>>documentation.
>>>>>>point...
>>Respectfully,
>>CL Gilbert
Re: Code is done... now what? [message #216413 is a reply to message #216364] |
Fri, 26 March 2004 15:01  |
Cool ... thanks for all the assistance guys!!! Very much appreciated!
Fayth
news:c41ohp$9uf$1@eclipse.org...
> cheers
> m.
Virtual
> > Fayth
message
> > the
> > Next I
when
> > I
> >>>ran my demo. :)
> >>the jvm a bit.
> >>put the swt in.
> >>>Sincerely, Fayth
> > pack
\java\lib
> > java -classpath
same
> >>>>error as before.
bad
> >>>>Sincerely, Fayth
classpath.
> >>>>>m.
> >>>when
> >>>>I
> >>>>>>try to run this...
Source)
> >>>>file
> >>>>too? Is
> >>>>>>Sincerely,
> >>>>>> Fayth
> >>>>>>>m.
> >>>and
> >>>>>>run
to
> >>>>>>send
the
> >>>>>>life of
include
> >>>>with
> >>>>>>the
> > it.
> >>>>>>I've
> >>>>>>documentation.
this
> >>>>>>point...
> >>Respectfully,
> >>CL Gilbert
Current Time: Sun Jun 15 06:44:23 EDT 2025
Powered by FUDForum. Page generated in 0.05064 seconds
