Home » Language IDEs » C / C++ IDE (CDT) » adding an existing file to the project
adding an existing file to the project [message #215401] Sat, 03 May 2008 08:20 Go to next message
Originally posted by: vitaly.panor.zoran.com
Is there a way of adding an existing file (not a directory) to the
project, without copying it to the project directory? Something similar to
"add existing item" in Visual Studio.
Re: adding an existing file to the project [message #215494 is a reply to message #215401] Mon, 05 May 2008 18:45 Go to previous messageGo to next message
Originally posted by: newsgroups.snipah.com
Yes.
Context Menu
New -> File -> Advanced -> Link to file in file system
Enrico
> Thanks
Re: adding an existing file to the project [message #215700 is a reply to message #215494] Wed, 07 May 2008 17:34 Go to previous messageGo to next message
Originally posted by: gbr.majentis.com
Enrico Ehrich wrote:
> Yes.
> Context Menu
> Enrico
>> Thanks
I'm sure if my first post went through, so sorry for the double post if it
did.
New -> File -> Advanced -> Link inserts absolute paths. I need relative
paths, since each developer can put their source tree wherever they want.
Is there a way to use relative paths?
Re: adding an existing file to the project [message #215707 is a reply to message #215494] Wed, 07 May 2008 18:03 Go to previous messageGo to next message
> Yes.
> Context Menu
> Enrico
>> Thanks
To answer my own question...
Environment variables didn't seem to work. But when you link to a file in
the filesystem, it has its own variables. I set that up, and each dev
sets up the same variable name to point to the proper path on their
system, and it all works.
Kinda backwards, I think. Using files in alternate directories is so
common, that relative positioning should just work without doing the
backflips.
Re: adding an existing file to the project [message #215915 is a reply to message #215494] Sun, 11 May 2008 03:27 Go to previous message
Hi Enrico,
Thanks a lot!
Previous Topic:Content assist with smart pointers
Next Topic:JavaDoc Plugin for CDT
Current Time: Thu Oct 23 00:28:18 EDT 2025
Powered by FUDForum. Page generated in 0.37322 seconds
