Home » Language IDEs » ServerTools (WTP) » Difficulties with StructuredTextEditor in a MultiPageEditorPart
Difficulties with StructuredTextEditor in a MultiPageEditorPart [message #211601] Wed, 02 April 2008 17:30 Go to next message
Originally posted by: jfolap.gmail.com
I have a MultiPageEditorPart which offers a GraphicalEditorWithFlyoutPalette
and a StructuredTextEditor. Things work pretty good except that the Source
menu has problems when my StructuredTextEditor is active. The menu labels
are not being retrieved nor do the actions function as expected.
For example, the "Source" menu shows "ToggleComment.label",
"AddBlockComment.label", etc. Only "Shift Right", "Shift Left", and
"Format" appear and function as expected. Clicking any of the problemmatic
actions, such as "ToggleComment.label", has no effect.
I assume I need to do something with the action contributor of the
StructuredTextEditor when the multipage editor makes it the active part.
However, I am not sure what that is.
Any help would be appreciated.
Thank you
Re: Difficulties with StructuredTextEditor in a MultiPageEditorPart [message #211776 is a reply to message #211601] Thu, 03 April 2008 14:31 Go to previous messageGo to next message
> Thank you
Which version are you using? Have you told the StructuredTextEditor
about your main editor part?
Nitin Dahyabhai
Eclipse WTP Source Editing
IBM Rational
Re: Difficulties with StructuredTextEditor in a MultiPageEditorPart [message #211836 is a reply to message #211776] Fri, 04 April 2008 18:22 Go to previous messageGo to next message
Originally posted by: john.palof.logiclibrary.com
Thank you for replying.
Yes, I set my MultiPageEditorPart as the StructuredTextEditor's content
via setEditorPart.
Regarding the version (excerpts from Configuration Details):
Feature:
org.eclipse.wst (1.5.1.v200609111500-X3TmmF3AeboB5EW) "Web Standard Tools
(WST)"
Plugins:
org.eclipse.wst.sse.core (1.1.100.v200609182120) "Structured Text Model"
[Active]
org.eclipse.wst.sse.doc.user (1.0.203.v200608300230) "Structured text
editor and snippets documentation" [Resolved]
org.eclipse.wst.sse.ui (1.0.200.v200609211325) "Structured Source Editor"
[Active]
org.eclipse.wst.sse.ui.infopop (1.0.101.v200605040131) "SSE infopops"
[Resolved]
Re: Difficulties with StructuredTextEditor in a MultiPageEditorPart [message #211919 is a reply to message #211836] Mon, 07 April 2008 12:57 Go to previous messageGo to next message
> via setEditorPart.
> Feature:
> Tools (WST)"
> Plugins:
> [Active]
> Editor" [Active]
> [Resolved]
Hmm, best to open a bug report, then. If at all possible, also try
it with the upcoming 3.0M6 build. The menu contribution story has
been revamped to make use of handlers and UI contexts, and it's
possible that the problem is fixed by these changes.
Nitin Dahyabhai
IBM Rational
Re: Difficulties with StructuredTextEditor in a MultiPageEditorPart [message #211926 is a reply to message #211919] Mon, 07 April 2008 15:33 Go to previous messageGo to next message
I will give 3.0M6 a try and report back to this posting.
Re: Difficulties with StructuredTextEditor in a MultiPageEditorPart [message #212149 is a reply to message #211926] Tue, 08 April 2008 15:08 Go to previous messageGo to next message
Originally posted by: wuamy.ca.ibm.com
If your multipage editor edits xml content, the easiest thing to do prior
to WTP 3. M6 would be to add the following code to your multipage editor:
* @see
org.eclipse.ui.part.MultiPageEditorPart#createSite(org.eclip se.ui.IEditorPart)
protected IEditorSite createSite(IEditorPart page) {
IEditorSite site = null;
if (page == editor) {
site = new MultiPageEditorSite(this, page) {
public String getId() {
// Sets this ID so nested editor is configured for XML source
return ContentTypeIdForXML.ContentTypeID_XML + ".source";
//$NON-NLS-1$;
else {
site = super.createSite(page);
return site;
See this page for more info:
http://www.eclipse.org/webtools/wst/components/sse/tutorials /multipage-editor-tutorial.html
After 3.0 M6, check out this wiki page for more info:
http://wiki.eclipse.org/Table_of_WTP_IDs
Re: Difficulties with StructuredTextEditor in a MultiPageEditorPart [message #212869 is a reply to message #212149] Wed, 23 April 2008 15:38 Go to previous message
Thank you! Your suggestion worked perfectly and the links to the related
documents helped.
Previous Topic:Need to launch the "Generate Java Bean Skeleton" Wizard
Next Topic:J2EE Preview Server, Jetty, Dynamic Web Projects and log4j
Current Time: Fri Jun 13 23:47:13 EDT 2025
Powered by FUDForum. Page generated in 0.25518 seconds
