Home » Newcomers » Newcomers » Ant Terminated Problem
Ant Terminated Problem [message #211574] Mon, 21 May 2007 23:48 Go to next message
Originally posted by: cockiest.hotmail.com
hi techies,
i am a newbie in eclipse & have problem to run my first ant script. The
script only have one target to echo message "hello world" but the console
output nothing.
this is what i found in the debug screen:
/home/so/_lab_java/eclipse_space/Lesson0/build.xml
<terminated, exit value: 1> /usr/_programming/jdk1.6.0_01/bin/java
fyi eclipse_space is my workspace of eclipse. i am using eclipse 3.2.2
under debian linux 4.0.
can anyone kindly advise the steps to troubleshoot this problem?
thank you.
Re: Ant Terminated Problem [message #211633 is a reply to message #211574] Tue, 22 May 2007 10:29 Go to previous messageGo to next message
If you insert a sleep http://ant.apache.org/manual/CoreTasks/sleep.html into
the ant buildfile before the echo does the output show up?
For "toy" or very fast running Ant builds, the implementation has bug where
it can miss the output
HTH
Darins
"coc" <cockiest@hotmail.com> wrote in message
news:236d3d27efbd91eab9b4e6ef70a4e9e3$1@www.eclipse.org...
> hi techies,
> output nothing. this is what i found in the debug screen:
> can anyone kindly advise the steps to troubleshoot this problem? thank
> you.
Re: Ant Terminated Problem [message #211849 is a reply to message #211633] Wed, 23 May 2007 21:24 Go to previous messageGo to next message
thanks darins,
i have tried both ways inserting sleep (just before the echo or create a
new dependance target) but still the same problem.
i also debug by setting breakpoint at the project tag but it didn't pause
into the debug mode.
is this eclipse or debian or jdk problem?
any clue?
Re: Ant Terminated Problem [message #211924 is a reply to message #211849] Thu, 24 May 2007 10:28 Go to previous messageGo to next message
Anything in your .log file?
news:5f8d50ed5f7696c4394f56682b51a25f$1@www.eclipse.org...
> thanks darins,
> any clue?
Re: Ant Terminated Problem [message #212792 is a reply to message #211924] Tue, 29 May 2007 22:51 Go to previous messageGo to next message
i can't find the .log file. however in the log error screen there are many
errors.
1) these errors showed when open the build.xml with ant editor:
SESSION 2007-05-26 01:21:54.458
eclipse.buildId=M20070212-1330
java.version=1.6.0_01
BootLoader constants: OS=linux, ARCH=x86, WS=gtk, NL=en_US
Command-line arguments: -os linux -ws gtk -arch x86
!ENTRY org.eclipse.ant.core 4 3 2007-05-26 01:22:37.362
!MESSAGE The library "ant_tasks/helpbase-ant.jar" specified from
"org.eclipse.help.base" for the antTasks or antTypes extension does not
exist
!ENTRY org.eclipse.ant.core 4 3 2007-05-26 01:22:37.504
!MESSAGE The library "ant_tasks/resources-ant.jar" specified from
"org.eclipse.core.resources" for the antTasks or antTypes extension does
not exist
!ENTRY org.eclipse.ant.core 4 3 2007-05-26 01:22:37.506
not exist
!ENTRY org.eclipse.ant.core 4 3 2007-05-26 01:22:37.507
not exist
!ENTRY org.eclipse.ant.core 4 3 2007-05-26 01:22:37.509
!MESSAGE The library "jdtCompilerAdapter.jar" specified from
"org.eclipse.jdt.core" for the antTasks or antTypes extension does not
exist
!ENTRY org.eclipse.ant.core 4 3 2007-05-26 01:22:37.510
!MESSAGE The library "ant_tasks/pde-ant.jar" specified from
"org.eclipse.pde.core" for the antTasks or antTypes extension does not
exist
!ENTRY org.eclipse.ant.core 4 3 2007-05-26 01:22:37.512
exist
!ENTRY org.eclipse.ant.core 4 3 2007-05-26 01:22:37.525
exist
!ENTRY org.eclipse.ant.core 4 3 2007-05-26 01:22:37.526
"org.eclipse.help.base" for the extraClasspathEntries extension does not
exist
!ENTRY org.eclipse.ant.core 4 3 2007-05-26 01:22:37.528
!MESSAGE The library "lib/antrunner.jar" specified from
"org.eclipse.ant.ui" for the extraClasspathEntries extension does not exist
!ENTRY org.eclipse.ant.core 4 3 2007-05-26 01:22:37.529
!MESSAGE The library "lib/remoteAnt.jar" specified from
!ENTRY org.eclipse.ant.core 4 3 2007-05-26 01:22:37.530
!MESSAGE The library "lib/antsupportlib.jar" specified from
"org.eclipse.ant.core" for the extraClasspathEntries extension does not
exist
!ENTRY org.eclipse.ant.core 4 3 2007-05-26 01:22:37.531
"org.eclipse.core.resources" for the extraClasspathEntries extension does
not exist
!ENTRY org.eclipse.ant.core 4 3 2007-05-26 01:22:37.533
"org.eclipse.jdt.core" for the extraClasspathEntries extension does not
exist
!ENTRY org.eclipse.ant.core 4 3 2007-05-26 01:22:37.534
"org.eclipse.pde.core" for the extraClasspathEntries extension does not
exist
2) these errors when run the script:
!ENTRY org.eclipse.ant.ui 4 120 2007-05-26 01:29:50.385
!MESSAGE Error logged from Ant UI:
!STACK 0
java.net.SocketTimeoutException: Accept timed out
at java.net.PlainSocketImpl.socketAccept(Native Method)
at java.net.PlainSocketImpl.accept(PlainSocketImpl.java:384)
at java.net.ServerSocket.implAccept(ServerSocket.java:450)
at java.net.ServerSocket.accept(ServerSocket.java:421)
at
org.eclipse.ant.internal.ui.launchConfigurations.RemoteAntBu ildListener$ServerConnection.run(RemoteAntBuildListener.java :95)
could it be the linux permission problem?
Re: Ant Terminated Problem [message #212800 is a reply to message #212792] Tue, 29 May 2007 23:57 Go to previous messageGo to next message
You are essentially missing all the helper JARs that make the functionality
of the Ant integration work in Eclipse.
I am unsure of how or what would have caused this.
I would start with first restoring to Default the Ant runtime classpath
HTH
Darins
news:198357c04192e9b994fd9f98225269c8$1@www.eclipse.org...
> errors.
> SESSION 2007-05-26
> 01:21:54.458 -----------------------------------------------
> exist
> not exist
> not exist
> not exist
> exist
> exist
> exist
> exist
> exist
> exist
> exist
> exist
> not exist
> exist
> exist
> !MESSAGE Error logged from Ant UI: !STACK 0
> at
Re: Ant Terminated Problem [message #212963 is a reply to message #212800] Wed, 30 May 2007 21:18 Go to previous messageGo to next message
i have double checked the original eclipse-SDK-3.2.2-linux-gtk.tar.gz
downloaded from eclipse website. jar files for ant are inside
plugins/org.apache.ant_1.6.5/ only. indeed it doesn't contain the required
files (helpbase-ant.jar, resources-ant.jar, jdtCompilerAdapter.jar, etc)
that in the log.
where can i get these files? additional plugin?
Re: Ant Terminated Problem [message #213143 is a reply to message #212963] Thu, 31 May 2007 13:09 Go to previous messageGo to next message
These JARs are "fluffed" up at runtime from other JARs provided in the
download.
For example the remoteAnt.jar comes from the org.eclipse.ant.ui plugin.
I would suggest clearing your configuration data by deleting all the files
in the eclipse configuration folder EXCEPT the config.ini folder.
Note that you may lose some of your preference settings
HTH
Darins
news:614b5993a4a7867f3e2f35ffe1966aba$1@www.eclipse.org...
>that in the log.
Re: Ant Terminated Problem [message #213588 is a reply to message #213143] Mon, 04 June 2007 01:28 Go to previous message
i think i have found the cause.
i moved the eclipse workspace from _java_lab to java_lab, problem solved!
thank you very much.
Previous Topic:getting the full path of the class currently opend in eclipse editor
Next Topic:how to create executable file
Current Time: Thu Oct 16 22:45:04 EDT 2025
Powered by FUDForum. Page generated in 0.08325 seconds
