Home » Newcomers » Newcomers » Java Scrapbook Question
Java Scrapbook Question [message #208504] Tue, 01 May 2007 20:47 Go to next message
Hi. I'm playing with the Scrapbook, and once you figure out a couple of
tricks, it is very cool. Two things that had me stumped: (1) Use the Set
Imports to set up the imports for your scrapbook session. (2) To inspect
something, you can put as many lines of code you need to build it as long
as you end with just the expression. For example, create a new object,
run any methods you need, and just end the snippet with the object's
variable, like below:
Book b1 = new Book("test book");
b1.setName("new book name");
b1
Highlight the snippet and press the Inspect button (e.g., right click).
You can then drill into the object, just like in the debugger.
However, I have one question. On the "Set the Import Declarations" dialog,
there is a button "Add Type" as well as "Add Packages". What does the "Add
Type" button do? Thanks. Mark Dexter
Re: Java Scrapbook Question [message #208594 is a reply to message #208504] Wed, 02 May 2007 09:18 Go to previous messageGo to next message
Originally posted by: eclipse5.rizzoweb.com
> dialog, there is a button "Add Type" as well as "Add Packages". What
> does the "Add Type" button do? Thanks. Mark Dexter
"Add Package" is equivalent to a complete package import statement, like
import java.util.*;
while "Add Type" is equivalent to importing a single class, like
import java.util.Collection;
Hope this helps,
Eric
Re: Java Scrapbook Question [message #208602 is a reply to message #208594] Wed, 02 May 2007 09:28 Go to previous messageGo to next message
Thanks! Mark
Re: Java Scrapbook Question [message #524868 is a reply to message #208504] Sat, 03 April 2010 04:06 Go to previous message
[Deleted]
[Updated on: Sat, 03 April 2010 04:19] by Moderator
Previous Topic:Help getting Eclipse running
Next Topic:MRajan
Current Time: Thu Sep 18 00:57:43 EDT 2025
Powered by FUDForum. Page generated in 0.07370 seconds
