Home » Archived » BIRT » Problem defining parameters when creating Data Set BIRT 2.2M2
Problem defining parameters when creating Data Set BIRT 2.2M2 [message #207779] Wed, 20 December 2006 14:42
I'm using BIRT 2.2M2 build.
I'm creating a Data Set for my report which takes in report parameters.
My SQL query follows the example below:
SELECT * FROM CUSTOMER WHERE CUSTOMER_ID BETWEEN ? AND ?
I bound the SQL parameters to the report parameters with defined default
values. I am able to preview the results in the Edit Data Set window.
But i am unable to see the output columns and when i creat a chart that
uses the Data Set i created, i can't see any rows to bind the X and Y axis
too.
Is this a bug or am i doing something wrong?
Thanks.
Previous Topic:Customizing series title in chart
Next Topic:problen in birt-runtime-2_1_1
Current Time: Tue Jul 22 14:52:39 EDT 2025
Powered by FUDForum. Page generated in 0.04770 seconds
