Home » Language IDEs » C / C++ IDE (CDT) » which is the right executable ?
which is the right executable ? [message #204486] Fri, 09 November 2007 05:33 Go to next message
I have imported a automake project and I'm have troubles with running in
in Eclipse. The build seems to be ok.
I realized that there are 3 different executables in the project:
- one in the build directory: myprog
- two in the build/.libs : myprog and lt-myprog
The lt-myprog is sometimes there and sometimes not. What is this file ?
If I run the build/.libs/myprog in a terminal or in Eclipse it can't
load my shared library
If I run in a terminal the build/myprog in works fine and loads the library
If I try to specify to Eclipse to run the build/myprog, Eclipse doesn't
recognize it as a binary. I checked the Binary Parsers in the Project
optins and I have Elf and HP-UX parser (Im on Linux).
So to sum up, I have one binary which works fine but is not recognizez
by Eclipse, the other one doesnt work but is recognized by Eclipse. The
3d misterious lt-... works but sometimes dissapears !
I really don't understand what's going on.
Thanks for your help,
Tex
Re: which is the right executable ? [message #204493 is a reply to message #204486] Fri, 09 November 2007 07:57 Go to previous message
Well,
I still don't know why there are several executables but now I managed
to execute the build/.libs/myprog. It seems that the program is being
linked to a loadable library during the compilation
Warning:
*** Warning: Linking the executable myprog against the loadable module
I set the path to this library in the run options and it works now.
But anyway, what are the other executables for ?
Tex.
Tex Twil wrote:
> Hello,
> Regards,
> Tex
Previous Topic:cdt "tool settings" tab is not visible on win2k
Next Topic:indexer/content assist strangeness
Current Time: Thu Nov 06 05:20:33 EST 2025
Powered by FUDForum. Page generated in 0.03913 seconds
