Home » Language IDEs » ServerTools (WTP) » JSP version mismatch using WTP with BEA?
JSP version mismatch using WTP with BEA? [message #204144] Fri, 09 November 2007 15:57 Go to next message
I'm having a problem getting a JSF web project to build on Europa JEE.
The odd thing is, in my JSP page, the auto-complete brings up the
"deferredSyntaxAllowedAsLiteral" as a valid attribute of a <%@ page, but
once its there, I get a warning that seems to indicate that the build
process doesn't think its valid:
Undefined attribute name (deferredSyntaxAllowedAsLiteral)
Similar problem in my web.xml file: auto-complete will bring up a
deferred-syntax-allowed-as-literal tag, but I get the following "Problem":
cvc-complex-type.2.4.a: Invalid content was found starting with element
'deferred-syntax-allowed-as-literal'. One of
'{"http://java.sun.com/xml/ns/javaee":description,
"http://java.sun.com/xml/ns/javaee":display-name,
"http://java.sun.com/xml/ns/javaee":icon,
"http://java.sun.com/xml/ns/javaee":url-pattern}' is expected.
ProjectName/WebContent/WEB-INF web.xml line 30
It almost looks like auto-complete is JSP version 2.1 (or higher) and the
build is 2.0 (or lower).
Can this be fixed? Why the version mismatch?
Thanks in advance!
Re: JSP version mismatch using WTP with BEA? [message #204259 is a reply to message #204144] Mon, 12 November 2007 11:24 Go to previous messageGo to next message
Was this something from the Web Page Editor's UI, or did you really
mean from the source page?
Nitin Dahyabhai
Structured Source Editing
Re: JSP version mismatch using WTP with BEA? [message #204267 is a reply to message #204259] Mon, 12 November 2007 13:44 Go to previous messageGo to next message
> Nitin Dahyabhai
Are you asking if the error was from the Web Page Editor's UI? I'm
assuming it would be some sort of background build process in Eclipse that
would generate the warning message, but I'm not sure how a source page
could generate a warning -- I would think it would be some else that
generates a warning based on a source page.
I must not be understanding what you are asking for.
Mev
Re: JSP version mismatch using WTP with BEA? [message #204275 is a reply to message #204267] Mon, 12 November 2007 13:59 Go to previous message
> that would generate the warning message, but I'm not sure how a source
> page could generate a warning -- I would think it would be some else
> that generates a warning based on a source page.
I meant the "autocomplete." The source page doesn't know about that
attribute.
Nitin Dahyabhai
Previous Topic:XSD editor: nillable property?
Next Topic:creating a top down web service with eclipse
Current Time: Wed Oct 29 20:51:39 EDT 2025
Powered by FUDForum. Page generated in 0.03437 seconds
