Search across projects [message #203807] |
Sun, 29 February 2004 20:08 |
If one wants to rename a method that is being called in more than one
workspace project, what is the course of action? In my installation (M7)
Refactor->Rename can only find references in a single project (where a
method is declared). I tried reference searching instead and it does not
find references across projects either. Then I tried searching using
declared working set. No luck again.
The only way that I was at least able to find all method references is
when I use java search on a method name withouth declared parameters.
What I am doing wrong?
Vladimir
FUDForum. Page generated in 0.03007 seconds
