Home » Language IDEs » ServerTools (WTP) » Exporting another project when publishing to a server
Exporting another project when publishing to a server [message #203806] Tue, 06 November 2007 15:24 Go to next message
Originally posted by: christoph.hodte.de
I have a question. Ich have two projects one is a WTP project and the
other is a simple java project. The WTP project depends on the simple java
project. I add the depend project to the buildpath and eclipse find the
classes.
The problem is when I publish the WTP project to a tomcat server the
depended project is not publish to the server or isn't copied to the
classes directory.
Is that a bug? When not how must I configure the projects that both are
published.
I have a Workaround. I export the simple java project to a jar and copy
the jar in the lib dir. But that is not a good solution.
Chris
Re: Exporting another project when publishing to a server [message #203814 is a reply to message #203806] Tue, 06 November 2007 15:49 Go to previous messageGo to next message
Instead of adding the Java project using the Java Build Path page of
project Properties, use the J2EE Module Dependencies page. Checking the
Java project there internally adds it to the build path and WTP will
automatically do during publishing what you are doing manually, i.e.
build a jar from the Java project's Java output and publish it to
WEB-INF/lib.
Larry
Christoph wrote:
> Hello,
> java project. I add the depend project to the buildpath and eclipse find
> the classes.
> classes directory.
> published.
> Chris
Re: Exporting another project when publishing to a server [message #203860 is a reply to message #203814] Wed, 07 November 2007 02:44 Go to previous messageGo to next message
Thx for the answer. But when I use the J2EE Dependency I must use a J2EE
Application Server but I only need the Tomcat instead Geronimo.
Can I do the same with Tomcat without manuel exporting the project to a
jar?
Christoph
Re: Exporting another project when publishing to a server [message #203884 is a reply to message #203860] Wed, 07 November 2007 06:03 Go to previous message
> jar?
> Christoph
AFAIK, you don't need to use a J2EE Application Server to use the J2EE
Module Dependecies page to add inter-project dependencies.
Mauro.
Previous Topic:hierarchical view not showing in Project Explorer
Next Topic:problem in adding Derby plug-ins to Eclipse
Current Time: Sat Nov 08 20:52:12 EST 2025
Powered by FUDForum. Page generated in 0.04341 seconds
