Home » Eclipse Projects » Eclipse Platform » Plugin Editors...RuleBasedPartitionScanner or RuleBasedScanner...
Plugin Editors...RuleBasedPartitionScanner or RuleBasedScanner... [message #201736] Wed, 25 February 2004 15:09 Go to next message
Hi all,
New to plugin development. I'm trying to develop and editor (robust one)
that will handle Perl code. I been using the the example Java Editor,
Readme Tool example and the XML Editor that got created using the PDE.
Some utilize RuleBasedScanner, some use RuleBasedPartitionScanner. BUT,
looking at other robust editors (other than the examples), they are all
using RuleBasedPartitionScanner for predicate based rules.
My question is, which is the correct one to utilize? Or more importantly,
whats the advantages/disadvantages of using one over the other?
tia,
adym
Re: Plugin Editors...RuleBasedPartitionScanner or RuleBasedScanner... [message #202814 is a reply to message #201736] Fri, 27 February 2004 02:17 Go to previous message
Originally posted by: bob.objfac.com
"alincoln" <alincoln@edgewater.com> wrote in message
news:c1ivd3$jvp$1@eclipse.org...
> Hi all,
There is no correct one. RuleBasedPartitionScanner lets you use
IPredicateRule, which has some advantages (an optimization) and
disadvantages (less general) compared to IRule. Figure out what your
scanners have to do, _then_ pick a scanner. In particular, if you do not
have simple resumable rules, you don't want IPredicateRule.
Bob
Previous Topic:plugins don't work in Eclipse 3.0?
Next Topic:Force lazy marker generation?
Current Time: Wed Sep 03 15:44:44 EDT 2025
Powered by FUDForum. Page generated in 0.04254 seconds
