Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » Getting some parsing exceptions.....
Getting some parsing exceptions..... [message #16696] Fri, 27 January 2006 06:37 Go to next message
Can you help why I am getting these type of errors while evaluating
some
Ocl expressions?....like-
Expression : self.attribute->product(self.attribute)
Error : org.eclipse.emf.ocl.helper.OclParsingException[1]:
Collection type conformance failure: (null).(product)
Please fix your code to add using
EClass.getEStructuralFeatures()
instead of EClass.getEReferences()
Expression : Set{self.attribute.name}->product(Set{self.attribute.name})
Error : org.eclipse.emf.ocl.helper.OclParsingException[1]: Collection
type conformance failure: (Set(null)).(product)
instead of EClass.getEAttributes()
Expression : Set{self.attribute}->product(Set{self.attribute})
Collection type conformance failure: (Set(null)).(product)
Thanks and Regards,
Shrawanika
Re: Getting some parsing exceptions..... [message #16726 is a reply to message #16696] Fri, 27 January 2006 07:09 Go to previous messageGo to next message
Shrawanika,
This should be changed. Please open a bugzilla to make sure it does.
Shrawanika wrote:
> evaluating some Ocl expressions?....like-
> Expression : self.attribute->product(self.attribute) Error :
> Please fix your code to add using EClass.getEStructuralFeatures()
> Collection
> Thanks and Regards,
> Shrawanika
Re: Getting some parsing exceptions..... [message #16735 is a reply to message #16696] Fri, 27 January 2006 08:17 Go to previous messageGo to next message
Hi, Shrawanika,
It appears from the OclParsingException that the "attribute" feature does
not have a type (the type is "null"). Is that the case?
Regarding the syserrs about Eclass.getEStructuralFeatures(), yes, please
open a bugzilla.
Christian
Shrawanika wrote:
> some
> Collection
> Thanks and Regards,
> Shrawanika
Re: Getting some parsing exceptions..... [message #19796 is a reply to message #16726] Thu, 02 February 2006 01:20 Go to previous messageGo to next message
Thanks!
I filed: https://bugs.eclipse.org/bugs/show_bug.cgi?id=126144
Re: Getting some parsing exceptions..... [message #19882 is a reply to message #16735] Thu, 02 February 2006 03:51 Go to previous messageGo to next message
Hi Christian,
No, the "attribute" feature has type defined (the Type is not "null").
I instantiated UML 1.3 Metamodel. And the attributes have DataType as
their Object Type.
Then, what can be the possible reason for this error:
Thanks and Regards,
Shrawanika
Re: Getting some parsing exceptions..... [message #20007 is a reply to message #19882] Thu, 02 February 2006 09:09 Go to previous messageGo to next message
Hi, Shrawanika,
If "attribute" is a DataType with multiplicity many, then this should
certainly work. Even if it was a scalar multiplicity, it should be coerced
to a Set type automatically. Looks like a bug, if you care to raise it.
Christian
Shrawanika wrote:
> Hi Christian,
> "null").
> their Object Type.
> Thanks and Regards,
> Shrawanika
Re: Getting some parsing exceptions..... [message #21333 is a reply to message #20007] Fri, 03 February 2006 07:18 Go to previous message
I filed: https://bugs.eclipse.org/bugs/show_bug.cgi?id=126336
Shrawanika
Re: Getting some parsing exceptions..... [message #564365 is a reply to message #16696] Fri, 27 January 2006 07:09 Go to previous message
Shrawanika,
Shrawanika wrote:
> Collection
> Thanks and Regards,
> Shrawanika
Re: Getting some parsing exceptions..... [message #564422 is a reply to message #16696] Fri, 27 January 2006 08:17 Go to previous message
Hi, Shrawanika,
open a bugzilla.
Christian
Shrawanika wrote:
> some
> Collection
> Thanks and Regards,
> Shrawanika
Re: Getting some parsing exceptions..... [message #565323 is a reply to message #16726] Thu, 02 February 2006 01:20 Go to previous message
Thanks!
Re: Getting some parsing exceptions..... [message #565357 is a reply to message #16735] Thu, 02 February 2006 03:51 Go to previous message
Hi Christian,
their Object Type.
Thanks and Regards,
Shrawanika
Re: Getting some parsing exceptions..... [message #565446 is a reply to message #19882] Thu, 02 February 2006 09:09 Go to previous message
Hi, Shrawanika,
Christian
Shrawanika wrote:
> Hi Christian,
> "null").
> their Object Type.
> Thanks and Regards,
> Shrawanika
Re: Getting some parsing exceptions..... [message #565590 is a reply to message #20007] Fri, 03 February 2006 07:18 Go to previous message
Shrawanika
Previous Topic:[Announce] EMFT TRANSACTION 1.0.0 I200602021008 is available
Next Topic:[Announce] EMFT OCL 1.0.0 I200602020906 is available
Current Time: Fri Jun 13 20:45:30 EDT 2025
Powered by FUDForum. Page generated in 0.05863 seconds
