Home » Newcomers » Newcomers » Download Platform Source code
Download Platform Source code [message #196838] Wed, 28 February 2007 00:23 Go to next message
How can I download source code for the Platform into Eclipse?
Charlie
Re: Download Platform Source code [message #196875 is a reply to message #196838] Wed, 28 February 2007 02:42 Go to previous messageGo to next message
Originally posted by: nugaee.SPAMtlen.pl
you can use import plugins and fragments
and check "Import as binary with linked content"
or you can download fresh sources from cvs
hope it helps
bartek michalik
Re: Download Platform Source code [message #196935 is a reply to message #196875] Wed, 28 February 2007 05:15 Go to previous messageGo to next message
You can get the source code of all the plugins in eclipse....
Window-->ShowView --->others--->pde---->plugins--->plugins
A plugin view will appear...
right click on any item in the treeviewer of the plugins view...
then import as source project option....
should be selected..
now u can use the entire code of the plugin ...
Re: Download Platform Source code [message #196998 is a reply to message #196875] Wed, 28 February 2007 08:55 Go to previous messageGo to next message
Hi Bartek,
What is the cvs location to download source for the Platform (3.3M5)?
Charlie
> hope it helps
> bartek michalik
Re: Download Platform Source code [message #197002 is a reply to message #196998] Wed, 28 February 2007 09:04 Go to previous messageGo to next message
Originally posted by: jakub.jurkiewicz.gmail.com
Please look here: http://wiki.eclipse.org/index.php/CVS_Howto
regards,
Jakub Jurkiewicz
> Hi Bartek,
> Thanks
> Charlie
>> hope it helps
>> bartek michalik
Re: Download Platform Source code [message #197017 is a reply to message #197002] Wed, 28 February 2007 10:23 Go to previous message
Hi Jakub,
Thank you; this is what I was looking for.
Charlie
Jakub Jurkiewicz wrote:
> regards,
> Jakub Jurkiewicz
>> Hi Bartek,
>> Thanks
>> Charlie
>>> hope it helps
>>> bartek michalik
Previous Topic:how to use pdf in birt? kindly help!
Next Topic:JREE packages -- missing something obvious?
Current Time: Thu Sep 18 14:58:11 EDT 2025
Powered by FUDForum. Page generated in 0.05250 seconds
