| M5: java.lang.NoClassDefFoundError when doing ANT stuff [message #196339] |
Mon, 21 February 2005 01:52  |
Windows XPSP1
Unzipping SDK3.1M5a, using an existing workspace and java project, when
attempting to do an ANT build using an ANT builder, or attempting to open
a build.xml file with the ANT file editor, Eclipse crashes with the
following output in my .log file:
!SESSION 2005-02-20 23:09:02.843
eclipse.buildId=I20050219-1500
java.version=1.5.0_01
Framework arguments: -showlocation
Command-line arguments: -os win32 -ws win32 -arch x86 -clean -data
C:\DOCUME~1\bhoylman\HOME\Eclipse\workspace3.1M5a -showlocation
!SESSION Sun Feb 20 23:10:35 MST 2005
!ENTRY org.eclipse.core.launcher 4 0 Feb 20, 2005 23:10:35.968
!MESSAGE Exception launching the Eclipse Platform:
!STACK
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:167)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:268 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:260)
at org.eclipse.core.launcher.Main.run(Main.java:887)
at org.eclipse.core.launcher.Main.main(Main.java:871)
This subsequently leaves an eclipse.exe and a javaw process orphaned as
well. I have tried a clean workspace with the project imported and the
same thing happens. This is NOT the case with build I20050202.
Ouch! Any comments welcome.
Peace.
| Re: M5: java.lang.NoClassDefFoundError when doing ANT stuff [message #196482 is a reply to message #196461] |
Tue, 22 February 2005 10:32  |
"Ullrich Pollaehne" <u.pollaehne12@web.de> wrote in message
news:cvf666$hqb$1@www.eclipse.org...
> Hi Darin,
> Darin Swanson wrote:
>> I am having no luck using bugzilla this morning.
>> I believe you are specifying -Xverify:none when running Eclipse?
> yeah, you got me. ;-)
> After removing -Xverify:none ANT worked as expected.
> Is there a chance to get a M5b?
> Ullrich.
No this will not cause an M5b.
You options are:
to not specify -Xverify:none
to make use of the integration build that will come out today where the
problem is fixed
to patch the org.eclipse.ant.core plugin of M5a with the one that comes out
in the integration build of today.
HTH
Darins
FUDForum. Page generated in 0.04447 seconds
