| Installation Failure [message #19482] |
Tue, 26 May 2009 13:39  |
Hello
I have just downloaded a 3.4.0 release of Eclipse EE, and I try to install
IAM. When I try to install the plugin through
http://q4e.googlecode.com/svn/trunk/updatesite-iam/ by using "Software
updates", the following error occurs, somone can help me, please ?
Cannot complete the request. See the details.
Unsatisfied dependency: [org.eclipse.iam.feature.teamsupport.feature.group
0.9.0.200905051159] requiredCapability:
org.eclipse.equinox.p2.iu/org.eclipse.team.svn.ui/[0.7.7,1.0 .0)
org.eclipse.equinox.p2.iu/org.eclipse.team.svn.core/[0.7.7,1 .0.0)
Unsatisfied dependency: [org.eclipse.iam.teamsupport 0.9.0.200905051159]
requiredCapability: osgi.bundle/org.eclipse.team.svn.ui/[0.7.7,0.8.0)
requiredCapability: osgi.bundle/org.eclipse.team.svn.core/[0.7.7,0.8.0)
Unsatisfied dependency: [org.eclipse.platform.ide 3.4.0.I20080617-2000]
requiredCapability:
org.eclipse.equinox.p2.iu/org.eclipse.platform.feature.group /[3.4.0.v20080610-9I96EhtEm-T_5LxIsybz-3MdGZmOA3uwv7Ka_M,3.4 .0.v20080610-9I96EhtEm-T_5LxIsybz-3MdGZmOA3uwv7Ka_M]
Unsatisfied dependency: [org.eclipse.iam.feature.buckminster.feature.group
org.eclipse.equinox.p2.iu/org.eclipse.iam.buckminster.core/[ 0.9.0.200905051159,0.9.0.200905051159]
org.eclipse.equinox.p2.iu/org.eclipse.iam.teamsupport/[0.9.0 .200905051159,0.9.0.200905051159]
Unsatisfied dependency: [org.eclipse.platform.feature.group
3.4.0.v20080610-9I96EhtEm-T_5LxIsybz-3MdGZmOA3uwv7Ka_M]
requiredCapability:
org.eclipse.equinox.p2.iu/org.eclipse.debug.core/[3.4.0.v200 80612,3.4.0.v20080612]
requiredCapability:
org.eclipse.equinox.p2.iu/org.eclipse.help.feature.group/[1. 0.0.v20080603-7r7xEHJEJkZu5nE6Q4Qrtvu6JZ9L,1.0.0.v20080603-7 r7xEHJEJkZu5nE6Q4Qrtvu6JZ9L]
Unsatisfied dependency: [org.eclipse.help.feature.group
1.0.0.v20080603-7r7xEHJEJkZu5nE6Q4Qrtvu6JZ9L] requiredCapability:
org.eclipse.equinox.p2.iu/org.eclipse.rcp.feature.group/[3.4 .0.v20080324a-989JERhEk-jWnd5IY8K5tjxB,3.4.0.v20080324a-989J ERhEk-jWnd5IY8K5tjxB]
| Re: Installation Failure [message #19995 is a reply to message #19853] |
Wed, 27 May 2009 18:16  |
On 5/27/09 8:02 AM, Abel Muiño wrote:
> Helo Stéphane,
> Stephane wrote:
>> To resolve my problems :
>> - I have deleted the following line in the .classpath of my projects :
>> <classpathentry kind="con"
>> path="org.devzuz.q.maven.jdt.core.mavenClasspathContainer"/ >
> This is the old classpath container name, used by q4e. So I am guessing
> that you didn't uninstall q4e before installing IAM ?
I've seen this problem, Eclipse caches the contents of the old classpath
container even if you uninstall the plugin. I guess the only solution is
to remove it from the .classpath or delete it completely and reimport
>> - I have added in my pom exclusions for duplicate artefact to avoid
>> duplicate entries in the "Maven Classpath Container"
> Could you open a bugzilla with a sample pom showing the problem? The
> Maven Classpath Container should not allow duplicate entries, so this
> might be a bug.
> Thanks for your feedback!
> Abel Muiño
| Re: Installation Failure [message #569387 is a reply to message #19482] |
Tue, 26 May 2009 15:56  |
Hello Stéphane,
You should not install the Subversive or Buckminster integrations, since
the required dependencies are not installed in Eclipse EE.
Abel Muiño
| Re: Installation Failure [message #569412 is a reply to message #19529] |
Wed, 27 May 2009 05:29  |
Hello Abel,
Thanks for your help.
Now, it's ok with the install.
My installation is an upgrade from a previous version. When I activate the
plugin with selecting Maven 2 -> "Use Maven dependency management". Errors
are displayed which where not there with the previous release :
Build path contains duplicate entry:
.../.m2/repository/org/osgi/osgi_R4_core/1.0/osgi_R4_core-1. 0.jar' for
project 'mngtlib'
The error is only in Eclipse, when I use the Maven CLI the compilation is
ok :(
| Re: Installation Failure [message #569466 is a reply to message #19664] |
Wed, 27 May 2009 06:45  |
It seems that an exclusion in a denpendency is not well managed so the
excluded artifact seems to be added to "Maven Classpath Container"
So I changed my pom to avoid this problem but now another problems occurs.
Lots of errors "the type ... is not generic". It ssems that the project
has switch in 1.4 java style.
I have checked that my project in Eclipse is 1.6 and in my pom :
<plugin>
<groupId>org.apache.maven.plugins</groupId>
<artifactId>maven-compiler-plugin</artifactId>
<configuration>
<source>1.6</source>
<target>1.6</target>
</configuration>
</plugin>
Any idea, please ?
| Re: Installation Failure [message #569486 is a reply to message #19709] |
Wed, 27 May 2009 09:01  |
| Re: Installation Failure [message #569513 is a reply to message #19709] |
Wed, 27 May 2009 10:58  |
Hello Stéphane,
IAM will set the java compliance options for Eclise's JDT. Somehow, this
seemed not to work for your project, so if you're able to reproduce this,
please file a bugzilla with instructions.
If the problem shows again, you can try the following workaround:
- Cleaning your project (inside eclipse). This will re-process your pom.
- (Optionally) you can disable and enable Maven support for the project,
to force IAM to start from scratch.
- Setting the java settings in the project properties manually
Thanks!
> <plugin>
> <configuration>
> </configuration>
> </plugin>
> Any idea, please ?
Abel Muiño
| Re: Installation Failure [message #569539 is a reply to message #19770] |
Wed, 27 May 2009 11:02  |
Helo Stéphane,
Could you open a bugzilla with a sample pom showing the problem? The Maven
Classpath Container should not allow duplicate entries, so this might be a
bug.
Abel Muiño
| Re: Installation Failure [message #569563 is a reply to message #19810] |
Wed, 27 May 2009 12:06  |
It seems that the issue occurs when I try to add a specific dependency.
(but it works well with the mvn CLI)
I'm going to try to reproduce the issue in a simple project to file a
bugzilla.
I tried this workaround. The issue is always there :(
> Thanks!
>> <plugin>
>> <configuration>
>> </configuration>
>> </plugin>
>> Any idea, please ?
| Re: Installation Failure [message #569583 is a reply to message #19853] |
Wed, 27 May 2009 12:18  |
Previously, I have uninstalled q4e as described in the documentation
(plugin uninstallation, file plugin deletion in plugins folder, eclipse
-clean)
> bug.
I'm going to try to reproduce in a sample project
| Re: Installation Failure [message #569609 is a reply to message #19853] |
> Helo Stéphane,
> might be a bug.
> Abel Muiño
FUDForum. Page generated in 0.07439 seconds
