Home » Language IDEs » ServerTools (WTP) » Java 6 and J2EE project facet
Java 6 and J2EE project facet [message #187393] Wed, 31 January 2007 12:11 Go to next message
I have eclipse 3.2 and WTP 1.5.2 (current version). I tried to switch my
j2ee projects to java 6 but I can't set java 6 in "Project facets" because
highest version is 5.0.
Does wtp 1.5 supports java version 6? How to configure eclipse to use facet
- java 6.0?
I couldn't find anything about that with google...
Thanks in advance.
Denis
Re: Java 6 and J2EE project facet [message #187408 is a reply to message #187393] Wed, 31 January 2007 14:12 Go to previous messageGo to next message
Originally posted by: kosta.bea.com
Denis,
WTP 1.5 does support java 6.0. My guess is that you are not able to
select 6.0 for the java facet because the server runtime that your
project is configured to use does not support it (due to being
configured to use a 5.0 vm). Take a look at your server runtime
configuration and make sure that it uses a 6.0 vm. After you've adjusted
your server runtime you should be able to select 6.0 for the java facet.
- Konstantin
Re: Java 6 and J2EE project facet [message #187439 is a reply to message #187408] Thu, 01 February 2007 02:48 Go to previous message
On Wed, 31 Jan 2007 11:12:29 -0800, Konstantin Komissarchik wrote:
> Denis,
> - Konstantin
Thanks, that solved my "problem" :-)
Denis
Previous Topic:Extending the HTML editor for content assist
Next Topic:VersionsVersionsVersions
Current Time: Sun Nov 09 01:51:43 EST 2025
Powered by FUDForum. Page generated in 0.24717 seconds
