| Access of tables or list in shell [message #1866639] |
Tue, 04 June 2024 09:53   |
Eclipse User  |
I would like to select an option from a given list in a specific area. The list contains the following options: Blinking, Hello, and Tool Library. Additionally, it is possible to expand these options and select sub-nodes as parent folders.
However, I am encountering an issue when attempting to access this list.
Furthermore, I am experiencing a similar issue when trying to access the final table, which is labeled "Select Type."
As I am new to SWTBot, I may be missing some details. I appreciate any assistance you can provide.
Thank you.
[Updated on: Tue, 04 June 2024 12:41] by Moderator
| Re: Access of tables or list in shell [message #1866780 is a reply to message #1866651] |
Thu, 06 June 2024 10:01   |
Eclipse User  |
Hi Prashantkumar,
Is this a dialog that opens in a new shell? I would expect to access the items with code similar to this:
        SWTWorkbenchBot workbenchBot = new SWTWorkbenchBot();
        SWTBotShell shell = workbenchBot.shell("New Type");
        SWTBotTree tree = shell.bot().tree();
        SWTBotTreeItem treeItem = tree.getTreeItem("Blinking");
        treeItem.expand();
        SWTBotTreeItem childTreeItem = treeItem.getNode("child");
        SWTBotTable table = shell.bot().table();
        SWTBotTableItem tableItem = table.getTableItem(0);
Hope this helps,
Patrick
FUDForum. Page generated in 0.52143 seconds
