Home » Modeling » EMF » Genmodel code generation via Maven build(Genmode code generation via Maven build)
Genmodel code generation via Maven build [message #1862834] Sun, 31 December 2023 06:42 Go to next message
I'm currently wrapping my head around building multiple pre-existing projects (partly EMF/metamodels) via Maven.
One of the problems I stumbled upon is the source code generation process of Genmodels. I found some (more or less related) projects on the internet but I could not get them to run successfully:
- https://github.com/enikao/xcore-xtend-maven/tree/master
- https://github.com/BlackBeltTechnology/emf-genmodel-generator/tree/develop
I've created a minimal working example with a small Ecore metamodel and a pom.xml config for Maven to learn the correct way of generating the source code. The project can be found on GitHub: https://github.com/maxkratz/maven-ecore-modeling-example
Therefore, I added an MWE2 file that can be run inside Eclipse and *successfully* generates the metamodel code to `src-gen`.
However, if I run the project via Maven, I get an Exception that some of the MWE2 classes cannot be loaded:
[INFO] Scanning for projects...
[INFO]
[INFO] ----------------< org.example.model:org.example.model >-----------------
[INFO] Building Example Model 0.0.1-SNAPSHOT
[INFO] --------------------------------[ jar ]---------------------------------
[INFO]
[INFO] --- build-helper-maven-plugin:3.5.0:add-source (add-source) @ org.example.model ---
[INFO] Source directory: /home/maxkratz/gits/maven-ecore-modeling-example/org.example.model/src-gen added.
[INFO]
[INFO] --- exec-maven-plugin:3.1.1:java (mwe2Launcher) @ org.example.model ---
0    [org.eclipse.emf.mwe2.launch.runtime.Mwe2Launcher.main()] ERROR mf.mwe2.launch.runtime.Mwe2Launcher  - org/eclipse/emf/mwe2/language/Mwe2RuntimeModule
java.lang.NoClassDefFoundError: org/eclipse/emf/mwe2/language/Mwe2RuntimeModule
	at org.eclipse.emf.mwe2.language.Mwe2StandaloneSetupGenerated.createInjector(Mwe2StandaloneSetupGenerated.java:47)
	at org.eclipse.emf.mwe2.language.Mwe2StandaloneSetupGenerated.createInjectorAndDoEMFRegistration(Mwe2StandaloneSetupGenerated.java:41)
	at org.eclipse.emf.mwe2.launch.runtime.Mwe2Launcher.run(Mwe2Launcher.java:75)
	at org.eclipse.emf.mwe2.launch.runtime.Mwe2Launcher.main(Mwe2Launcher.java:36)
	at org.codehaus.mojo.exec.ExecJavaMojo.lambda$execute$0(ExecJavaMojo.java:283)
	at java.base/java.lang.Thread.run(Thread.java:840)
Caused by: java.lang.ClassNotFoundException: org.eclipse.emf.mwe2.language.Mwe2RuntimeModule
	at org.codehaus.mojo.exec.URLClassLoaderBuilder$ExecJavaClassLoader.loadClass(URLClassLoaderBuilder.java:163)
	at java.base/java.lang.ClassLoader.loadClass(ClassLoader.java:525)
	... 6 more
As far as I can see, all necessary dependencies are present in the plugin's configuration in the pom.xml file.
This leads me to ask two questions:
- Does anyone have a small example of how to build the metamodel source code from a Genmodel via Maven?
- What did I miss in my pom.xml configuration to resolve the NoClassDefFoundError/ClassNotFoundException?
I appreciate the help.
Max
Re: Genmodel code generation via Maven build [message #1862838 is a reply to message #1862834] Mon, 01 January 2024 05:19 Go to previous messageGo to next message
The GEF project has a working example. It's easy to set up the environment for it:
https://github.com/eclipse/gef/blob/master/CONTRIBUTING.md
There is an m2e launch configuration available to run the Maven/Tycho build locally.
Here is the part where it specifies to launch the *.mwe2:
https://github.com/eclipse/gef/blob/f2384c5632f68b0ca2dec4088ffa2118214a8909/org.eclipse.gef.dot/pom.xml#L120-L185
Re: Genmodel code generation via Maven build [message #1862841 is a reply to message #1862838] Mon, 01 January 2024 09:01 Go to previous messageGo to next message
Thank you for your fast reply.
I tried to build the GEF project by checking out the repository's code and using Maven to run the build headlessly. Unfortunately, I'm unable to build the GEF project with Maven.
Under `CONTRIBUTING.md`, the documentation states that Java 11 must be used. However, if I use a Java 11 installation, Maven complains about class files compiled with a higher version. After some unsuccessful tries, I had a look at the Jenkins configuration file and observed that Jenkins uses JDK17 instead of Java 11. I switched my test environment to JDK17 but now I get an error when I try to build the main project:
[ERROR] Failed to execute goal org.eclipse.tycho:tycho-compiler-plugin:4.0.4:compile (default-compile) on project org.eclipse.gef.common: useJDK = BREE configured, but no toolchain of type 'jdk' with id 'JavaSE-1.8' found. See https://maven.apache.org/guides/mini/guide-using-toolchains.html -> [Help 1]
[ERROR]
[ERROR] To see the full stack trace of the errors, re-run Maven with the -e switch.
[ERROR] Re-run Maven using the -X switch to enable full debug logging.
[ERROR]
[ERROR] For more information about the errors and possible solutions, please read the following articles:
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/MojoExecutionException
[ERROR]
[ERROR] After correcting the problems, you can resume the build with the command
[ERROR]   mvn <args> -rf org.eclipse.gef.plugins:org.eclipse.gef.common
However, I compared the provided pom.xml file you mentioned and I noticed that I had at least two dependencies missing:
          <dependency>
            <groupId>org.eclipse.xtext</groupId>
            <artifactId>org.eclipse.xtext.common.types</artifactId>
            <version>${xtext-version}</version>
          </dependency>
          <dependency>
            <artifactId>org.eclipse.xtext.xtext.generator</artifactId>
          </dependency>
I added them to my small example repo (https://github.com/maxkratz/maven-ecore-modeling-example/commit/a79d1d5f59db821155fbda36b7e2b2d1dbdedc77) and now the Maven build process runs successfully.
Thank you very much!
Re: Genmodel code generation via Maven build [message #1862842 is a reply to message #1862841] Mon, 01 January 2024 10:01 Go to previous message
FYI, for anyone else looking at this post in the future, I have this in my <home>/.m2/toolschains.xml
<?xml version="1.0" encoding="UTF8"?>
<toolchains>
  <toolchain>
    <type>jdk</type>
    <provides>
      <id>JavaSE-1.8</id>
      <version>1.8</version>
      <vendor>sun</vendor>
    </provides>
    <configuration>
      <jdkHome>C:/Program Files/Java/jdk1.8.0_261</jdkHome>
    </configuration>
  </toolchain>
  <toolchain>
    <type>jdk</type>
    <provides>
      <id>JavaSE-11</id>
      <version>11</version>
    </provides>
    <configuration>
      <jdkHome>C:/Program Files/Java/jdk-11.0.13+8</jdkHome>
    </configuration>
  </toolchain>
  <toolchain>
    <type>jdk</type>
    <provides>
      <id>JavaSE-17</id>
      <version>17</version>
      <vendor>adoptium</vendor>
    </provides>
    <configuration>
	    <jdkHome>C:/Program Files/Java/jdk-17.0.5+8</jdkHome>
    </configuration>
  </toolchain>
</toolchains>
Previous Topic:Changed behavior of Undo/Redo menu's entries?
Next Topic:Access Ecore class Attribute with multiplicity 0..1 (Optional parameter)
Current Time: Wed Jul 30 22:17:51 EDT 2025
Powered by FUDForum. Page generated in 0.03608 seconds
