Home » Eclipse Projects » EclipseLink » DatabaseException is always logged to server.log(I want to test for a lock on a row, this works basically, but an exception is always logged with stacktrace and pollutes the server.log file.)
DatabaseException is always logged to server.log [message #1860098] |
Mon, 17 July 2023 14:13  |
Hi to all,
I have a problem with perhaps eclipselink, and I did not find any solution.
I will synchronize multiple cluster-node by database and try to use a row-lock:
Map<String, Object> properties = new HashMap<>();
properties.put("javax.persistence.lock.timeout", timeout);
properties.put("jakarta.persistence.lock.timeout", timeout);
final PlatformDatabaseLock lock = getEntityManager().find(PlatformDatabaseLock.class, processId, LockModeType.PESSIMISTIC_WRITE, properties);
This works, but if some execution hits the lock, there is an exception thrown, which is not catchable. It always is propagated to serverlog, so the whole serverlog is polluted with this exception and the corresponding stackstack, and searching for real errors is nearly impossible.
I tried with try/catch around the statement, around the method-call, around the call to the EJB... I tried it with an Interceptor... nothing worked.
I also set this parameter in persistence.xml, but this does not have any effect:
<property name="eclipselink.logging.exceptions" value="false" />
Can somebody tell me, how to check for a lock on a row of a table but without having to deal with exceptions?
The exception and the stacktrace are show here:
Local Exception Stack:
Exception [EclipseLink-4002] (Eclipse Persistence Services - 4.0.1.payara-p1.v202304041433): org.eclipse.persistence.exceptions.DatabaseException
Internal Exception: org.postgresql.util.PSQLException: ERROR: could not obtain lock on row in relation "_platform_database_lock"
Error Code: 0
Call: SELECT _id, created, last_update, platform_lock_until, version FROM _platform_database_lock WHERE (_id = ?) FOR UPDATE NOWAIT
bind => [EMAIL_NOTIFICATION_IMMEDIATELY]
Query: ReadObjectQuery(name="readPlatformDatabaseLock" referenceClass=PlatformDatabaseLock sql="SELECT _id, created, last_update, platform_lock_until, version FROM _platform_database_lock WHERE (_id = ?) FOR UPDATE NOWAIT")
at org.eclipse.persistence.exceptions.DatabaseException.sqlException(DatabaseException.java:343)
at org.eclipse.persistence.internal.databaseaccess.DatabaseAccessor.processExceptionForCommError(DatabaseAccessor.java:1805)
at org.eclipse.persistence.internal.databaseaccess.DatabaseAccessor.basicExecuteCall(DatabaseAccessor.java:694)
at org.eclipse.persistence.internal.databaseaccess.DatabaseAccessor.executeCall(DatabaseAccessor.java:569)
at org.eclipse.persistence.internal.sessions.AbstractSession.basicExecuteCall(AbstractSession.java:2048)
at org.eclipse.persistence.sessions.server.ClientSession.executeCall(ClientSession.java:311)
at org.eclipse.persistence.internal.queries.DatasourceCallQueryMechanism.executeCall(DatasourceCallQueryMechanism.java:280)
at org.eclipse.persistence.internal.queries.DatasourceCallQueryMechanism.executeCall(DatasourceCallQueryMechanism.java:266)
at org.eclipse.persistence.internal.queries.DatasourceCallQueryMechanism.selectOneRow(DatasourceCallQueryMechanism.java:813)
at org.eclipse.persistence.internal.queries.ExpressionQueryMechanism.selectOneRowFromTable(ExpressionQueryMechanism.java:2912)
at org.eclipse.persistence.internal.queries.ExpressionQueryMechanism.selectOneRow(ExpressionQueryMechanism.java:2865)
at org.eclipse.persistence.queries.ReadObjectQuery.executeObjectLevelReadQuery(ReadObjectQuery.java:563)
at org.eclipse.persistence.queries.ObjectLevelReadQuery.executeDatabaseQuery(ObjectLevelReadQuery.java:1236)
at org.eclipse.persistence.queries.DatabaseQuery.execute(DatabaseQuery.java:913)
at org.eclipse.persistence.queries.ObjectLevelReadQuery.execute(ObjectLevelReadQuery.java:1195)
at org.eclipse.persistence.queries.ReadObjectQuery.execute(ReadObjectQuery.java:448)
at org.eclipse.persistence.queries.ObjectLevelReadQuery.executeInUnitOfWork(ObjectLevelReadQuery.java:1283)
at org.eclipse.persistence.internal.sessions.UnitOfWorkImpl.internalExecuteQuery(UnitOfWorkImpl.java:3008)
at org.eclipse.persistence.internal.sessions.AbstractSession.executeQuery(AbstractSession.java:1841)
at org.eclipse.persistence.internal.sessions.AbstractSession.executeQuery(AbstractSession.java:1823)
at org.eclipse.persistence.internal.sessions.AbstractSession.executeQuery(AbstractSession.java:1773)
at org.eclipse.persistence.internal.jpa.EntityManagerImpl.executeQuery(EntityManagerImpl.java:999)
at org.eclipse.persistence.internal.jpa.EntityManagerImpl.findInternal(EntityManagerImpl.java:941)
at org.eclipse.persistence.internal.jpa.EntityManagerImpl.find(EntityManagerImpl.java:817)
at com.sun.enterprise.container.common.impl.EntityManagerWrapper.find(EntityManagerWrapper.java:402)
at de.example.domainmodel.platform.persistence.PersistenceAware.getExclusiveLock(PersistenceAware.java:104)
at de.example.domain.business.notifications.email.PersonalMessageMailNotificationImmediatelyScheduler.execute(PersonalMessageMailNotificationImmediatelyScheduler.java:46)
at jdk.internal.reflect.GeneratedMethodAccessor290.invoke(Unknown Source)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.base/java.lang.reflect.Method.invoke(Method.java:568)
at org.glassfish.ejb.security.application.EJBSecurityManager.runMethod(EJBSecurityManager.java:588)
at org.glassfish.ejb.security.application.EJBSecurityManager.invoke(EJBSecurityManager.java:408)
at com.sun.ejb.containers.BaseContainer.invokeBeanMethod(BaseContainer.java:4835)
at com.sun.ejb.EjbInvocation.invokeBeanMethod(EjbInvocation.java:653)
at com.sun.ejb.containers.interceptors.AroundInvokeChainImpl.invokeNext(InterceptorManager.java:834)
at com.sun.ejb.EjbInvocation.proceed(EjbInvocation.java:603)
at com.sun.ejb.containers.interceptors.SystemInterceptorProxy.doCall(SystemInterceptorProxy.java:163)
at com.sun.ejb.containers.interceptors.SystemInterceptorProxy.aroundTimeout(SystemInterceptorProxy.java:145)
at jdk.internal.reflect.GeneratedMethodAccessor227.invoke(Unknown Source)
at com.sun.ejb.containers.interceptors.AroundInvokeInterceptor.intercept(InterceptorManager.java:888)
at com.sun.ejb.containers.interceptors.AroundInvokeChainImpl.invokeNext(InterceptorManager.java:833)
at org.jboss.weld.module.ejb.AbstractEJBRequestScopeActivationInterceptor.aroundInvoke(AbstractEJBRequestScopeActivationInterceptor.java:81)
at org.jboss.weld.module.ejb.SessionBeanInterceptor.aroundInvoke(SessionBeanInterceptor.java:52)
at jdk.internal.reflect.GeneratedMethodAccessor200.invoke(Unknown Source)
at com.sun.ejb.containers.interceptors.InterceptorManager.intercept(InterceptorManager.java:375)
at com.sun.ejb.containers.BaseContainer.__intercept(BaseContainer.java:4807)
at com.sun.ejb.containers.BaseContainer.intercept(BaseContainer.java:4795)
at com.sun.ejb.containers.BaseContainer.callEJBTimeout(BaseContainer.java:4045)
at com.sun.ejb.containers.EJBTimerService.deliverTimeout(EJBTimerService.java:1208)
at com.sun.ejb.containers.EJBTimerService$TaskExpiredWork.run(EJBTimerService.java:1937)
at java.base/java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:539)
at java.base/java.util.concurrent.FutureTask.run(FutureTask.java:264)
at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1136)
at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:635)
at java.base/java.lang.Thread.run(Thread.java:833)
Caused by: org.postgresql.util.PSQLException: ERROR: could not obtain lock on row in relation "_platform_database_lock"
at org.postgresql.core.v3.QueryExecutorImpl.receiveErrorResponse(QueryExecutorImpl.java:2676)
at org.postgresql.core.v3.QueryExecutorImpl.processResults(QueryExecutorImpl.java:2366)
at org.postgresql.core.v3.QueryExecutorImpl.execute(QueryExecutorImpl.java:356)
at org.postgresql.jdbc.PgStatement.executeInternal(PgStatement.java:496)
at org.postgresql.jdbc.PgStatement.execute(PgStatement.java:413)
at org.postgresql.jdbc.PgPreparedStatement.executeWithFlags(PgPreparedStatement.java:190)
at org.postgresql.jdbc.PgPreparedStatement.executeQuery(PgPreparedStatement.java:134)
at jdk.internal.reflect.GeneratedMethodAccessor193.invoke(Unknown Source)
at org.postgresql.ds.PGPooledConnection$StatementHandler.invoke(PGPooledConnection.java:441)
at jdk.proxy74/jdk.proxy74.$Proxy655.executeQuery(Unknown Source)
at com.sun.gjc.spi.jdbc40.PreparedStatementWrapper40.executeQuery(PreparedStatementWrapper40.java:658)
at org.eclipse.persistence.internal.databaseaccess.DatabaseAccessor.executeSelect(DatabaseAccessor.java:1026)
at org.eclipse.persistence.internal.databaseaccess.DatabaseAccessor.basicExecuteCall(DatabaseAccessor.java:662)
... 59 more
Thank you very much for every hint to come around this issue!
Re: DatabaseException is always logged to server.log [message #1860167 is a reply to message #1860100] |
Thu, 20 July 2023 11:00   |
Hi Chris,
thank you very much for your comment.
The point here is the following: I could log the eclipselink exceptions into a separate file, but generally, I definitely WANT the exceptions to be logged in one place, so the overall-logging configuration fits quite well.
But what I find strange here is the thing, that this exception could not be catched (or more precisely, I COULD be catched, but it is "magically" logged to the main server.log).
It seems like this exception, even if catched, is handled like an uncatched exception, which is afterwards printed to server-log.
I have this settings in my persistsnce.xml file.
but it has absolutely no effect.
Is there perhaps another "pattern" to check for locks in a database with JPA? Because I think, this will be a common problem not only for me, that every hit against a lock pollutes the server log-file.
Thanks again for any hint/input/tip ;-)
[Updated on: Thu, 20 July 2023 11:00] by Moderator
Re: DatabaseException is always logged to server.log [message #1860198 is a reply to message #1860167] |
Fri, 21 July 2023 10:18  |
Sorry I wasn't clear.
This isn't an issue with how locks are checked in the DB - it is entirely an issue with your logging setup in your container.
<property name="eclipselink.logging.exceptions" value="false" /> in a persistence.xml is an EclipseLink logging setting. If you have configured EclipseLink to use a server logger, this setting doesn't apply - it and other eclipselink log settings ONLY apply to EclipseLink loggers (DefaultLogger).
Glassfish injects its own classes and logger into persistence units, much like it tries to handle DDL generation on its own. If you want to control logging, these will be glassfish logging options and settings. Happy to take a look if you want to post all your settings, but I'm not overly familiar with glassfish as I haven't had the opportunity to use it in a number of years.
[Updated on: Fri, 21 July 2023 10:19] by Moderator
Current Time: Sun Jul 20 18:28:17 EDT 2025
Powered by FUDForum. Page generated in 0.03250 seconds
