Home » Eclipse Projects » Eclipse Scout » [Solved] WAR files creation fail(Maven's mvn-clean-verify build failure for Scout Classic application)
[Solved] WAR files creation fail [message #1859227] |
Sun, 21 May 2023 10:42  |
Hi there everyone,
I'm having trouble building my project and creating the WAR files necessary for deployment into Apache Tomcat.
When I run mvn-clean-verify in the root directory of my project, it first starts to warn me about finding duplicate and different classes in commons-logging:commons-logging:1.2, org.slf4j:jcl-over-slf4j:2.0.4][
I don't have much experience with Maven and I would very, very much appreciate your help in resolving this issue and creating my WAR files.
My environment:
Eclipse Scout:
23.1.14
java -version:
openjdk version "17.0.7" 2023-04-18
OpenJDK Runtime Environment (build 17.0.7+7-Ubuntu-0ubuntu122.04.2)
OpenJDK 64-Bit Server VM (build 17.0.7+7-Ubuntu-0ubuntu122.04.2, mixed mode, sharing)
node --version:
v18.13.0
pnpm -v:
8.5.1
JD
jd@jd-ThinkPad-T440s:~/eclipse-scout-ygapp-workspace/ygapp$ mvn clean verify
[INFO] Scanning for projects...
[INFO] ------------------------------------------------------------------------
[INFO] Reactor Build Order:
[INFO]
[INFO] YGApp Root [pom]
[INFO] YGApp [pom]
[INFO] YGApp Shared [jar]
[INFO] YGApp Server [jar]
[INFO] YGApp Client [jar]
[INFO] YGApp Server Application [war]
[INFO] YGApp Server Application (Development) [war]
[INFO] YGApp HTML UI [jar]
[INFO] YGApp HTML UI Application [war]
[INFO] YGApp HTML UI Application (Development) [war]
[INFO]
[INFO] ----------------< org.eclipse.scout.apps:ygapp-root >----------------
[INFO] Building YGApp Root 1.0.0-SNAPSHOT [1/10]
[INFO] --------------------------------[ pom ]---------------------------------
[INFO]
[INFO] --- maven-clean-plugin:3.2.0:clean (default-clean) @ ygapp-root ---
[INFO]
[INFO] --- maven-enforcer-plugin:3.1.0:enforce (enforce-rules) @ ygapp-root ---
[INFO]
[INFO] --- jacoco-maven-plugin:0.8.8:prepare-agent (default) @ ygapp-root ---
[INFO] master_test_jacocoArgLine set to -javaagent:/home/jd/.m2/repository/org/jacoco/org.jacoco.agent/0.8.8/org.jacoco.agent-0.8.8-runtime.jar=destfile=/home/jd/eclipse-scout-ygapp-workspace/ygapp/../target/jacoco-all.exec
[INFO]
[INFO] --- maven-antrun-plugin:3.1.0:run (check-node-install) @ ygapp-root ---
[INFO] Executing tasks
[INFO] Executed tasks
[INFO]
[INFO] --- maven-antrun-plugin:3.1.0:run (check-npm-install-workspace) @ ygapp-root ---
[INFO] [touch] Creating /home/jd/eclipse-scout-ygapp-workspace/ygapp/target/npm_update.marker
[INFO]
[INFO] --- frontend-maven-plugin:1.12.1:install-node-and-npm (install-node-and-npm) @ ygapp-root ---
[INFO] Installing node version v18.12.1
[INFO] Unpacking /home/jd/.m2/repository/com/github/eirslett/node/18.12.1/node-18.12.1-linux-x64.tar.gz into /home/jd/eclipse-scout-ygapp-workspace/ygapp/target/node/../node/tmp
[INFO] Copying node binary from /home/jd/eclipse-scout-ygapp-workspace/ygapp/target/node/../node/tmp/node-v18.12.1-linux-x64/bin/node to /home/jd/eclipse-scout-ygapp-workspace/ygapp/target/node/../node/node
[INFO] Extracting NPM
[INFO] Installed node locally.
[INFO]
[INFO] --- exec-maven-plugin:3.1.0:exec (install-node-tools) @ ygapp-root ---
added 176 packages, removed 14 packages, changed 74 packages, and audited 399 packages in 30s
53 packages are looking for funding
run `npm fund` for details
1 high severity vulnerability
To address all issues, run:
npm audit fix
Run `npm audit` for details.
[INFO]
[INFO] --- exec-maven-plugin:3.1.0:exec (npm-run-version:snapshot:dependencies) @ ygapp-root ---
use given workspace root: /home/jd/eclipse-scout-ygapp-workspace/ygapp//..
updating version/dependency for module: @ygapp/root
updating version/dependency for module: undefined
updating version/dependency for module: @ygapp/ui
version:snapshot:dependencies done
[INFO]
[INFO] --- exec-maven-plugin:3.1.0:exec (npm-run-version:release:dependencies) @ ygapp-root ---
[INFO] skipping execute as per configuration
[INFO]
[INFO] --- exec-maven-plugin:3.1.0:exec (npm-run-version:release) @ ygapp-root ---
[INFO]
[INFO] --- exec-maven-plugin:3.1.0:exec (npm-update) @ ygapp-root ---
Scope: all 3 projects
ygapp/target/node | WARN Moving @eclipse-scout/releng that was installed by a different package manager to "node_modules/.ignored
ygapp/target/node | WARN Moving npm that was installed by a different package manager to "node_modules/.ignored
ygapp/target/node | WARN Moving pnpm that was installed by a different package manager to "node_modules/.ignored
ygapp/ygapp.ui.html | Progress: resolved 1, reused 0, downloaded 0, added 0
ygapp | Progress: resolved 1, reused 0, downloaded 0, added 0
ygapp/target/node | Progress: resolved 1, reused 0, downloaded 0, added 0
ygapp/ygapp.ui.html | Progress: resolved 5, reused 4, downloaded 0, added 0
ygapp | Progress: resolved 50, reused 2, downloaded 0, added 0
ygapp/target/node | Progress: resolved 2, reused 0, downloaded 0, added 0
ygapp/ygapp.ui.html | Progress: resolved 6, reused 5, downloaded 0, added 0
ygapp | Progress: resolved 113, reused 2, downloaded 0, added 0
ygapp/target/node | Progress: resolved 86, reused 38, downloaded 0, added 0
ygapp/ygapp.ui.html | Progress: resolved 6, reused 6, downloaded 0, added 0
ygapp | Progress: resolved 131, reused 130, downloaded 0, added 0
ygapp/target/node | Progress: resolved 140, reused 96, downloaded 0, added 0
ygapp | +7 -576 +--------------------------
Packages are hard linked from the content-addressable store to the virtual store.
Content-addressable store is at: /home/jd/.local/share/pnpm/store/v3
Virtual store is at: ygapp/target/node/node_modules/.pnpm
ygapp | Progress: resolved 131, reused 130, downloaded 0, added 7, done
ygapp/target/node | Progress: resolved 162, reused 125, downloaded 0, added 0
ygapp/target/node | Progress: resolved 163, reused 126, downloaded 0, added 0
ygapp/target/node | +177 ++++++++++++++++++
ygapp/target/node | Progress: resolved 177, reused 136, downloaded 0, added 177, done
ygapp/ygapp.ui.html | Progress: resolved 7, reused 6, downloaded 0, added 0
ygapp/ygapp.ui.html | Progress: resolved 217, reused 36, downloaded 0, added 0
ygapp/ygapp.ui.html | Progress: resolved 362, reused 248, downloaded 0, added 0
ygapp/ygapp.ui.html | Progress: resolved 517, reused 349, downloaded 0, added 0
ygapp/ygapp.ui.html | WARN deprecated stable@0.1.8
ygapp/ygapp.ui.html | Progress: resolved 658, reused 426, downloaded 0, added 0
ygapp/ygapp.ui.html | Progress: resolved 665, reused 433, downloaded 0, added 0
ygapp/ygapp.ui.html | +646 ++++++++++++++++++++++++++++++++
ygapp/ygapp.ui.html | Progress: resolved 668, reused 436, downloaded 0, added 0
ygapp/ygapp.ui.html | Progress: resolved 668, reused 436, downloaded 0, added 380
ygapp/ygapp.ui.html | Progress: resolved 668, reused 436, downloaded 0, added 646, done
Done in 15.8s
[INFO]
[INFO] --- exec-maven-plugin:3.1.0:exec (pnpm-list) @ ygapp-root ---
Legend: production dependency, optional only, dev only
@ygapp/root@1.0.0-SNAPSHOT /home/jd/eclipse-scout-ygapp-workspace/ygapp (PRIVATE)
dependencies:
@eclipse-scout/eslint-config 23.1.1
eslint 8.27.0
dependencies:
@eclipse-scout/releng 22.0.2
npm 9.6.7
pnpm 7.32.4
@ygapp/ui@1.0.0-SNAPSHOT /home/jd/eclipse-scout-ygapp-workspace/ygapp/ygapp.ui.html
dependencies:
@eclipse-scout/chart 23.1.14
@eclipse-scout/core 23.1.14
jquery 3.6.0
[INFO]
[INFO] --- exec-maven-plugin:3.1.0:exec (npm-run-version:snapshot) @ ygapp-root ---
[INFO]
[INFO] --- maven-jar-plugin:3.3.0:test-jar (attach-tests) @ ygapp-root ---
[INFO] Skipping packaging of the test-jar
[INFO]
[INFO] --- maven-source-plugin:3.2.1:jar-no-fork (attach-sources) @ ygapp-root ---
[INFO]
[INFO] --- maven-source-plugin:3.2.1:test-jar-no-fork (attach-test-sources) @ ygapp-root ---
[INFO]
[INFO] --- duplicate-finder-maven-plugin:1.5.1:check (default) @ ygapp-root ---
[INFO] Checking compile classpath
[INFO] Checking runtime classpath
[INFO] Checking test classpath
[INFO]
[INFO] ------------------< org.eclipse.scout.apps:ygapp >-------------------
[INFO] Building YGApp 1.0.0-SNAPSHOT [2/10]
[INFO]
[INFO] --- maven-clean-plugin:3.2.0:clean (default-clean) @ ygapp ---
[INFO]
[INFO] --- maven-enforcer-plugin:3.1.0:enforce (enforce-rules) @ ygapp ---
[INFO]
[INFO] --- jacoco-maven-plugin:0.8.8:prepare-agent (default) @ ygapp ---
[INFO] master_test_jacocoArgLine set to -javaagent:/home/jd/.m2/repository/org/jacoco/org.jacoco.agent/0.8.8/org.jacoco.agent-0.8.8-runtime.jar=destfile=/home/jd/eclipse-scout-ygapp-workspace/ygapp/ygapp/../target/jacoco-all.exec
[INFO]
[INFO] --- maven-jar-plugin:3.3.0:test-jar (attach-tests) @ ygapp ---
[INFO]
[INFO] --- maven-source-plugin:3.2.1:jar-no-fork (attach-sources) @ ygapp ---
[INFO]
[INFO] --- maven-source-plugin:3.2.1:test-jar-no-fork (attach-test-sources) @ ygapp ---
[INFO]
[INFO] --- duplicate-finder-maven-plugin:1.5.1:check (default) @ ygapp ---
[INFO]
[INFO] ---------------< org.eclipse.scout.apps:ygapp.shared >---------------
[INFO] Building YGApp Shared 1.0.0-SNAPSHOT [3/10]
[INFO] --------------------------------[ jar ]---------------------------------
[INFO]
[INFO] --- maven-clean-plugin:3.2.0:clean (default-clean) @ ygapp.shared ---
[INFO] Deleting /home/jd/eclipse-scout-ygapp-workspace/ygapp/ygapp.shared/target
[INFO]
[INFO] --- maven-enforcer-plugin:3.1.0:enforce (enforce-rules) @ ygapp.shared ---
[INFO]
[INFO] --- jacoco-maven-plugin:0.8.8:prepare-agent (default) @ ygapp.shared ---
[INFO] master_test_jacocoArgLine set to -javaagent:/home/jd/.m2/repository/org/jacoco/org.jacoco.agent/0.8.8/org.jacoco.agent-0.8.8-runtime.jar=destfile=/home/jd/eclipse-scout-ygapp-workspace/ygapp/ygapp.shared/../target/jacoco-all.exec
[INFO]
[INFO] --- build-helper-maven-plugin:3.3.0:add-source (add-source) @ ygapp.shared ---
[INFO] Source directory: /home/jd/eclipse-scout-ygapp-workspace/ygapp/ygapp.shared/src/generated/java added.
[INFO]
[INFO] --- maven-resources-plugin:3.3.0:resources (default-resources) @ ygapp.shared ---
[INFO] Copying 4 resources
[INFO]
[INFO] --- maven-compiler-plugin:3.10.1:compile (default-compile) @ ygapp.shared ---
[INFO] Changes detected - recompiling the module!
[INFO] Compiling 449 source files to /home/jd/eclipse-scout-ygapp-workspace/ygapp/ygapp.shared/target/classes
[INFO]
[INFO] --- jandex-maven-plugin:3.0.5:jandex (make-index) @ ygapp.shared ---
[INFO] Saving Jandex index: /home/jd/eclipse-scout-ygapp-workspace/ygapp/ygapp.shared/target/classes/META-INF/jandex.idx
[INFO]
[INFO] --- maven-resources-plugin:3.3.0:testResources (default-testResources) @ ygapp.shared ---
[INFO] Copying 1 resource
[INFO]
[INFO] --- maven-compiler-plugin:3.10.1:testCompile (default-testCompile) @ ygapp.shared ---
[INFO] No sources to compile
[INFO]
[INFO] --- maven-surefire-plugin:2.22.2:test (default-test) @ ygapp.shared ---
[INFO]
[INFO] --- maven-jar-plugin:3.3.0:jar (default-jar) @ ygapp.shared ---
[INFO] Building jar: /home/jd/eclipse-scout-ygapp-workspace/ygapp/ygapp.shared/target/ygapp.shared-1.0.0-SNAPSHOT.jar
[INFO]
[INFO] --- maven-jar-plugin:3.3.0:test-jar (attach-tests) @ ygapp.shared ---
[INFO] Building jar: /home/jd/eclipse-scout-ygapp-workspace/ygapp/ygapp.shared/target/ygapp.shared-1.0.0-SNAPSHOT-tests.jar
[INFO]
[INFO] --- maven-source-plugin:3.2.1:jar-no-fork (attach-sources) @ ygapp.shared ---
[INFO] Building jar: /home/jd/eclipse-scout-ygapp-workspace/ygapp/ygapp.shared/target/ygapp.shared-1.0.0-SNAPSHOT-sources.jar
[INFO]
[INFO] --- maven-source-plugin:3.2.1:test-jar-no-fork (attach-test-sources) @ ygapp.shared ---
[INFO] Building jar: /home/jd/eclipse-scout-ygapp-workspace/ygapp/ygapp.shared/target/ygapp.shared-1.0.0-SNAPSHOT-test-sources.jar
[INFO]
[INFO] --- duplicate-finder-maven-plugin:1.5.1:check (default) @ ygapp.shared ---
[WARNING] Found duplicate and different classes in [commons-logging:commons-logging:1.2, org.slf4j:jcl-over-slf4j:2.0.4]:
[WARNING] org.apache.commons.logging.Log
[WARNING] org.apache.commons.logging.LogConfigurationException
[WARNING] org.apache.commons.logging.LogFactory
[WARNING] org.apache.commons.logging.impl.NoOpLog
[WARNING] org.apache.commons.logging.impl.SimpleLog
[WARNING] Found duplicate classes/resources in compile classpath.
[WARNING] Found duplicate classes/resources in runtime classpath.
[WARNING] Found duplicate classes/resources in test classpath.
[INFO] Reactor Summary for YGApp Root 1.0.0-SNAPSHOT:
[INFO]
[INFO] YGApp Root ...................................... SUCCESS [ 55.222 s]
[INFO] YGApp ........................................... SUCCESS [ 0.067 s]
[INFO] YGApp Shared .................................... FAILURE [ 8.692 s]
[INFO] YGApp Server .................................... SKIPPED
[INFO] YGApp Client .................................... SKIPPED
[INFO] YGApp Server Application ........................ SKIPPED
[INFO] YGApp Server Application (Development) .......... SKIPPED
[INFO] YGApp HTML UI ................................... SKIPPED
[INFO] YGApp HTML UI Application ....................... SKIPPED
[INFO] YGApp HTML UI Application (Development) ......... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 01:04 min
[INFO] Finished at: 2023-05-21T16:10:05+02:00
[ERROR] Failed to execute goal org.basepom.maven:duplicate-finder-maven-plugin:1.5.1:check (default) on project ygapp.shared: Found duplicate classes/resources! -> [Help 1]
[ERROR]
[ERROR] To see the full stack trace of the errors, re-run Maven with the -e switch.
[ERROR] Re-run Maven using the -X switch to enable full debug logging.
[ERROR]
[ERROR] For more information about the errors and possible solutions, please read the following articles:
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/MojoExecutionException
[ERROR]
[ERROR] After correcting the problems, you can resume the build with the command
[ERROR] mvn <args> -rf :ygapp.shared
[Updated on: Thu, 25 May 2023 10:10] by Moderator
Current Time: Tue Jun 17 03:57:50 EDT 2025
Powered by FUDForum. Page generated in 0.24543 seconds
