Build Failing at Ant Step for UI [message #1858960] |
Wed, 03 May 2023 08:22  |
Hi all,
Since i switched my Classic Scout 22 (Java 11) Projekt from SVN to git i cant build anymore.
I get the following Maven error:
[INFO] ------------------------------------------------------------------------
[INFO] Reactor Summary for PROJECT Parent Module 1.0.0-SNAPSHOT:
[INFO]
[INFO] PROJECT Parent Module ............................. SUCCESS [ 1.185 s]
[INFO] PROJECT Shared .................................... SUCCESS [ 19.652 s]
[INFO] PROJECT Server .................................... SUCCESS [ 10.878 s]
[INFO] PROJECT Client .................................... SUCCESS [ 39.780 s]
[INFO] PROJECT Server Application ........................ SUCCESS [ 4.399 s]
[INFO] PROJECT Server Application (Development) .......... SUCCESS [ 4.708 s]
[INFO] PROJECT HTML UI ................................... FAILURE [ 0.561 s]
[INFO] PROJECT HTML UI Application ....................... SKIPPED
[INFO] PROJECT HTML UI Application (Development) ......... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 01:21 min
[INFO] Finished at: 2023-05-03T13:44:54+02:00
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-antrun-plugin:3.0.0:run (check-npm-install-workspace) on project PROJECT.ui.html: An Ant BuildException has occured: Could not create C:\Programming\PROJECTStuff\PROJECT_Git\PROJECT\pom.xml\target\npm_update.marker
[ERROR] around Ant part ...<touch file="C:\Programming\PROJECTStuff\PROJECT_Git\PROJECT.ui.html\../PROJECT/pom.xml\target\npm_update.marker" mkdirs="true" />... @ 6:139 in C:\Programming\PROJECTStuff\PROJECT_Git\PROJECT.ui.html\target\antrun\build-main.xml: Das System kann den angegebenen Pfad nicht finden
[ERROR] -> [Help 1]
org.apache.maven.lifecycle.LifecycleExecutionException: Failed to execute goal org.apache.maven.plugins:maven-antrun-plugin:3.0.0:run (check-npm-install-workspace) on project PROJECT.ui.html: An Ant BuildException has occured: Could not create C:\Programming\PROJECTStuff\PROJECT_Git\PROJECT\pom.xml\target\npm_update.marker
at org.apache.maven.lifecycle.internal.MojoExecutor.execute (MojoExecutor.java:215)
at org.apache.maven.lifecycle.internal.MojoExecutor.execute (MojoExecutor.java:156)
at org.apache.maven.lifecycle.internal.MojoExecutor.execute (MojoExecutor.java:148)
at org.apache.maven.lifecycle.internal.LifecycleModuleBuilder.buildProject (LifecycleModuleBuilder.java:117)
at org.apache.maven.lifecycle.internal.LifecycleModuleBuilder.buildProject (LifecycleModuleBuilder.java:81)
at org.apache.maven.lifecycle.internal.builder.singlethreaded.SingleThreadedBuilder.build (SingleThreadedBuilder.java:56)
at org.apache.maven.lifecycle.internal.LifecycleStarter.execute (LifecycleStarter.java:128)
at org.apache.maven.DefaultMaven.doExecute (DefaultMaven.java:305)
at org.apache.maven.DefaultMaven.doExecute (DefaultMaven.java:192)
at org.apache.maven.DefaultMaven.execute (DefaultMaven.java:105)
at org.apache.maven.cli.MavenCli.execute (MavenCli.java:957)
at org.apache.maven.cli.MavenCli.doMain (MavenCli.java:289)
at org.apache.maven.cli.MavenCli.main (MavenCli.java:193)
at jdk.internal.reflect.NativeMethodAccessorImpl.invoke0 (Native Method)
at jdk.internal.reflect.NativeMethodAccessorImpl.invoke (NativeMethodAccessorImpl.java:62)
at jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke (DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke (Method.java:566)
at org.codehaus.plexus.classworlds.launcher.Launcher.launchEnhanced (Launcher.java:282)
at org.codehaus.plexus.classworlds.launcher.Launcher.launch (Launcher.java:225)
at org.codehaus.plexus.classworlds.launcher.Launcher.mainWithExitCode (Launcher.java:406)
at org.codehaus.plexus.classworlds.launcher.Launcher.main (Launcher.java:347)
at org.codehaus.classworlds.Launcher.main (Launcher.java:47)
Caused by: org.apache.maven.plugin.MojoExecutionException: An Ant BuildException has occured: Could not create C:\Programming\PROJECTStuff\PROJECT_Git\PROJECT\pom.xml\target\npm_update.marker
at org.apache.maven.plugins.antrun.AntRunMojo.execute (AntRunMojo.java:308)
at org.apache.maven.plugin.DefaultBuildPluginManager.executeMojo (DefaultBuildPluginManager.java:137)
at org.apache.maven.lifecycle.internal.MojoExecutor.execute (MojoExecutor.java:210)
Caused by: org.apache.tools.ant.BuildException: Could not create C:\Programming\PROJECTStuff\PROJECT_Git\PROJECT\pom.xml\target\npm_update.marker
at org.apache.tools.ant.taskdefs.Touch.touch (Touch.java:360)
at org.apache.tools.ant.taskdefs.Touch.touch (Touch.java:334)
at org.apache.tools.ant.taskdefs.Touch.touch (Touch.java:284)
at org.apache.tools.ant.taskdefs.Touch.execute (Touch.java:273)
at org.apache.tools.ant.UnknownElement.execute (UnknownElement.java:299)
at org.apache.tools.ant.dispatch.DispatchUtils.execute (DispatchUtils.java:99)
at org.apache.tools.ant.Task.perform (Task.java:350)
at org.apache.tools.ant.Target.execute (Target.java:449)
at org.apache.tools.ant.Target.performTasks (Target.java:470)
at org.apache.tools.ant.Project.executeSortedTargets (Project.java:1401)
at org.apache.tools.ant.Project.executeTarget (Project.java:1374)
at org.apache.maven.plugins.antrun.AntRunMojo.execute (AntRunMojo.java:287)
Caused by: java.io.IOException: Das System kann den angegebenen Pfad nicht finden
at java.io.WinNTFileSystem.createFileExclusively (Native Method)
at java.io.File.createNewFile (File.java:1035)
at org.apache.tools.ant.util.FileUtils.createNewFile (FileUtils.java:1224)
at org.apache.tools.ant.taskdefs.Touch.touch (Touch.java:357)
[ERROR]
[ERROR]
[ERROR] For more information about the errors and possible solutions, please read the following articles:
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/MojoExecutionException
[ERROR]
[ERROR] After correcting the problems, you can resume the build with the command
[ERROR] mvn <args> -rf :PROJECT.ui.html
Process finished with exit code 1
The PROJECT.ui.html/target/build-main.xml looks like this:
<project name="maven-antrun-" default="main">
<target name="main">
<available file="C:\Programming\PROJECTStuff\PROJECT_Git\PROJECT.ui.html\../PROJECT/pom.xml\target\node/node_modules/@eclipse-scout" property="master_skip_init_node" />
<available file="C:\Programming\PROJECTStuff\PROJECT_Git\PROJECT.ui.html\../PROJECT/pom.xml\target\npm_update.marker" property="master_skip_npm_update" />
</target>
</project>
Does anyone know why this happens?
EDIT: I think the problem is in the ant script. The path contains "pom.xml". That shoudnt be there.
[Updated on: Wed, 03 May 2023 08:28] by Moderator
FUDForum. Page generated in 0.04102 seconds
