Problem with Debugging in ADT (ABAP Development Tool) on Eclipse 2022-12 [message #1857730] |
Thu, 23 February 2023 02:32  |
I was using Eclipse 2022-09 and ADT Version 3.28. It was working fine for a long time and I was even able to debug the RFCs (moving from one SAP system to another).
However, yesterday I upgraded to Eclipse 2022-12 and ADT Version 3.32 (The JRE versin also upgraded to 17 in the process). Since, then while the debugger is working fine, while debugging RFC and moving into another system, the debugger fails and shows 'source not found'. (Please see attached screenshot).
I also tried doing 'Edit Source Lookup Path' and additing the other system as an ABAP project in the Lookup Path, but it still doesn't work.
It should not be a problem with the Backend SAP system itself, because it was working fine earlier. Please help find the issue.
FUDForum. Page generated in 0.07693 seconds
