Home » Modeling » MoDisco » Register XMI without ECORE source(How to navigate through an XMI that is not made out of an ecore mmodel)
Register XMI without ECORE source [message #854459] Mon, 23 April 2012 21:12 Go to next message
Hi, everyone.
I've been resolving a lot of issues here, and now I'm half way:
- after discovering a Java project by MoDisco Java Discoverer, how could I load the resultant XMI model in some XMIResource and navigate? I did so with an Ecore file.
What if I only have the XMI model?
ResourceSet resourceSet = new ResourceSetImpl();		resourceSet.getResourceFactoryRegistry().getExtensionToFactoryMap().put
			(Resource.Factory.Registry.DEFAULT_EXTENSION, new XMIResourceFactoryImpl());		resourceSet.getPackageRegistry().put(MyMModelPackage.eNS_URI,MyMModelPackage.eINSTANCE);
File file = new File("C:\\Users\\USER\\workspace\\mmodels\\MyMModel.ecore");
		//System.out.println(file);
		URI uri = URI.createFileURI(file.getAbsolutePath());
		//System.out.println(uri);
		Resource resource = resourceSet.getResource(uri, true);
The above code works fine, but without the Ecore file, I can't figure it out.
By the way, I got the code from MyMModel.ecore-->MyMModel.genmodel->generate test code->*tests folders; thanks to this forum.
Thank you.
Re: Register XMI without ECORE source [message #854692 is a reply to message #854459] Tue, 24 April 2012 02:50 Go to previous messageGo to next message
On 24/04/2012 3:12 AM, Juan Castel wrote:
> Hi, everyone.
> File file = new
You registrations are for reading instances of the generated model. Why
do you also need to read the original model into a resource? I'd expect
you to be reading instances at this point.
> it out.
> Thank you.
Re: Register XMI without ECORE source [message #855721 is a reply to message #854692] Tue, 24 April 2012 23:40 Go to previous messageGo to next message
Thank you, Ed.
I actually have advanced a lot: I already have the Enterprise Architect XMI exported file and know a way to navigate through its UML elements. I attach the code for reference. This file is one of two inputs.
On the other hand, I exported a JAR file containing the parsing of the entire Ecore metamodel so I can build metaclasses out of the Ecore. An XMI model will be constructed with information about the first input.
Now I have the XMI model conforming to Java metamodel, discovered by MoDisco toolbox, but I get this exception in a standalone:
Package with uri '...MoDisco/Java/0.2.incubation/java' not found. (file:/C:/Users/USER/workspace/Dc3AdminEJB/Dc3AdminEJB_java.xmi, 2, 208)
(The forum editor won't let me post links unless 25 messages posted by me.)
The file Dc3AdminEJB_java.xmi was the result of java discoverer by MoDisco.
I guess the question is how to register MoDisco java metamodel.
Thanks.
Re: Register XMI without ECORE source [message #1856476 is a reply to message #855721] Mon, 12 December 2022 13:59 Go to previous message
Hello,"
I have the same issue that you use to have. I have my XMI file and I need to load it and navigate but I have the same error "Package with uri '*' not found."
On every post I see people saying that I should register the package but I don't have the ecore model I just have the xmi file in a standalone java app.
I was wondering if you solved this problem ? Because it seems that nobody knows how to load an XMI model file in a standalone java app.
Thanks.
Previous Topic:Running Modisco Headless
Next Topic:Drops and Updates are now Builds
Current Time: Sat Jul 19 05:49:35 EDT 2025
Powered by FUDForum. Page generated in 0.45171 seconds
