Home » Eclipse Projects » Sirius » Usage of java services defined inside a different viewpoint - is that possible?
Usage of java services defined inside a different viewpoint - is that possible? [message #1853861] Wed, 20 July 2022 05:55 Go to next message
In this example of sirius specifier, we got a number of services that are defined under the viewpoint (Operational Analysis) (See attached picture).
Question: Can you call upon the functions /services of this viewpoint from a different viewpoint? How does that work?
Thank you.
Re: Usage of java services defined inside a different viewpoint - is that possible? [message #1853868 is a reply to message #1853861] Wed, 20 July 2022 08:47 Go to previous messageGo to next message
The services are not really defined under the viewpoint. They are register in it. So you can reuse it , by registering it in another viewpoint, by adding a Java extension. For more detail, you can read this documentation: https://www.eclipse.org/sirius/doc/specifier/general/Writing_Queries.html#service_methods
Laurent
Re: Usage of java services defined inside a different viewpoint - is that possible? [message #1853870 is a reply to message #1853868] Wed, 20 July 2022 09:13 Go to previous messageGo to next message
That's awesome. Thank you.
It seems the option to 'add a Java extension" is not available at all for "Property View Description" Am I wrong? (Without even talking about registering external services, just making my own java extension here, it does not seem to be possible for a property view description?)
[Updated on: Wed, 20 July 2022 09:26] by Moderator
Re: Usage of java services defined inside a different viewpoint - is that possible? [message #1853897 is a reply to message #1853870] Thu, 21 July 2022 11:07 Go to previous messageGo to next message
You're right. The "Property View Descriptions" reuse the java extensions defined in viewpoint.
Re: Usage of java services defined inside a different viewpoint - is that possible? [message #1854087 is a reply to message #1853897] Mon, 01 August 2022 03:41 Go to previous messageGo to next message
Hello Laurent,
But it does not seem to be working right, look at this image (attached).
I made the function NEW4(), and tried to assign the value returned ( string) to a variable that hold a string (context was changed correctly). yet nothing happens.
What is more alarming is that the function DOES NOT APPEAR when you do a CTRL+SPACE. That's kind of a ring flag, it indicates that it is not working as intended, Am I wrong?
Please verify this. I made this whole topic just because I felt the Property value description did not take the service the viewpoint in the end. Something is off. Could you investigate please?
best regards
Re: Usage of java services defined inside a different viewpoint - is that possible? [message #1854369 is a reply to message #1854087] Tue, 16 August 2022 07:58 Go to previous messageGo to next message
Up!
Still not working
Re: Usage of java services defined inside a different viewpoint - is that possible? [message #1854420 is a reply to message #1854369] Thu, 18 August 2022 03:10 Go to previous messageGo to next message
Your NEW4 Java service method is not valid. It does not follow the rules mentioned in the documentation, and in particular:
A service method must take at least one parameter, which should be an EMF type (i.e. EObject or a sub-type of EObject).
Re: Usage of java services defined inside a different viewpoint - is that possible? [message #1854462 is a reply to message #1854420] Fri, 19 August 2022 11:42 Go to previous message
Hello Pierre-Charles
Thank you so much!
This reminds me a bit of tables in the Sirius Specifier, you have to give it a Attribute that exists THEN you can change the context to anything you want. BUT You need to put an existing Attribute even if you don't want to use it.
In my java service, I had to add an Eobject as parameter as you suggested, then I CAN IGNORE that parameter and return whatever I want.
It's quite curious but it works somehow.
Thanks again
[Updated on: Fri, 19 August 2022 11:59] by Moderator
Previous Topic:Labeling Relation Edges
Next Topic:Adding a "Load Resources" tool to Sirius diagram viewpoint, unsure how to do so.
Current Time: Sat Jul 19 16:57:28 EDT 2025
Powered by FUDForum. Page generated in 0.46858 seconds
