FreezeColumn Nattable 2.0.2 not working [message #1852917] |
Fri, 10 June 2022 09:59  |
Hi Nattable supporters,
i have updated Nattable from 1.5.0 to 2.0.2 and since then there is a freezecolumn call that is not working anymore. In the new version in FreezeCommandHandler.java there is a new "if" came into.
public boolean doCommand(IFreezeCommand command) {
// need to convert for correct handling in scrolled state
// using ViewportLayer#getScrollableLayer() because the positions in the
// further processing are taking from the scrollable layer, which does
// not need to be the SelectionLayer in every case
if (command.convertToTargetLayer(this.viewportLayer.getScrollableLayer())) {
if (command instanceof FreezeColumnCommand) {
I mean the above if with this call command.convertToTargetLayer(this.viewportLayer.getScrollableLayer()) is always false. When I debug inside, I see that the this.viewportLayer.getScrollableLayer() gives back a selectionLayer whereas the command.convertToTarget(..) needs it to be the instance of my "custom wrapper" PLRCompositeFreezeLayer.
My code to freeze:
int column = 4;
CompositeFreezeLayer freezeLayer = getBodyLayerStack().getCompositeFreezeLayer(); //which is instance of my PLRCompositeFreezeLayer
final FreezeColumnCommand freezeColumnCommand = new FreezeColumnCommand(freezeLayer, column);
freezeLayer.doCommand(freezeColumnCommand);
Then there is this way of creating the layers which i think seems okay for me.
//from above getBodyLayerStack().getCompositeFreezeLayer()
this.viewportLayer = new ViewportLayer(this.selectionLayer);
this.freezeLayer = new FreezeLayer(this.selectionLayer);
this.compositeFreezeLayer = new PLRCompositeFreezeLayer(this.freezeLayer, this.viewportLayer, this.selectionLayer);
setUnderlyingLayer(this.compositeFreezeLayer);
I looked at and ran this example: https://git.eclipse.org/c/nattable/org.eclipse.nebula.widgets.nattable.git/tree/org.eclipse.nebula.widgets.nattable.examples/src/org/eclipse/nebula/widgets/nattable/examples/_500_Layers/_513_FreezeExample.java
but there there is no command.doCommand() but rather it is done through a user action ctr+sh+f
Is there something I am missing to get my code working?
I actually could have done that via the below change but I can't explain how and why it is correct
//in PLRCompositeFreezeLayer
public Collection<ILayer> getUnderlyingLayersByColumnPosition(int columnPosition) {
Collection<ILayer> underlyingLayers = new HashSet<ILayer>();
System.err.println(columnPosition);
if (columnPosition==4 /*or > 0 because only 0 makes problems*/) {
underlyingLayers.add(this.selectionLayer);
return underlyingLayers;
I appreciate any expertise!
Mokhtar
[Updated on: Fri, 10 June 2022 13:59] by Moderator
Re: FreezeColumn Nattable 2.0.2 not working [message #1852923 is a reply to message #1852919] |
Fri, 10 June 2022 14:09   |
yes my typo. It was the version 1.5.0 (e.g. org.eclipse.nebula.widgets.nattable.core-1.5.0.201703192131.jar).
Thank you!
The legacy PLRCompositeFreezeLayer I have got (anonymized a bit) is as follows. Actually it is just a wrapper of org.eclipse.nebula.widgets.nattable.freeze.CompositeFreezeLayer that will fraw a thicker freeze line..
The commentted out lines are what I added to get the freeze working and no column lost. I don't know how that ( my getUnderlyingLayersByColumnPosition() below ) solved the problem but i am sure it is not the correct one.
* Copyright: (C) Deutsche ...
* _____________________________________________________________________________
package com.foo.bar.common.ui.table.layers;
import java.util.Collection;
import java.util.HashSet;
import org.eclipse.nebula.widgets.nattable.config.IConfigRegistry;
import org.eclipse.nebula.widgets.nattable.freeze.CompositeFreezeLayer;
import org.eclipse.nebula.widgets.nattable.freeze.FreezeLayer;
import org.eclipse.nebula.widgets.nattable.freeze.FreezeConfigAttributes;
import org.eclipse.nebula.widgets.nattable.layer.ILayer;
import org.eclipse.nebula.widgets.nattable.painter.layer.ILayerPainter;
import org.eclipse.nebula.widgets.nattable.selection.SelectionLayer;
import org.eclipse.nebula.widgets.nattable.style.DisplayMode;
import org.eclipse.nebula.widgets.nattable.util.GUIHelper;
import org.eclipse.nebula.widgets.nattable.viewport.ViewportLayer;
import org.eclipse.swt.graphics.Color;
import org.eclipse.swt.graphics.GC;
import org.eclipse.swt.graphics.Rectangle;
* PLR-specific extension of CompositeFreezeLayer to implement PLR-specific
* issues
* @version $Revision$
* @author
* @since 07.02.2014
public class PLRCompositeFreezeLayer extends org.eclipse.nebula.widgets.nattable.freeze.CompositeFreezeLayer {
* Special layer painter to draw thicker freeze line
* @author $Author$
* @since 07.02.2014
class FreezableLayerPainter extends CompositeLayerPainter {
public void paintLayer(final ILayer natLayer, final GC gc, final int xOffset, final int yOffset,
final Rectangle rectangle,
final IConfigRegistry configRegistry) {
super.paintLayer(natLayer, gc, xOffset, yOffset, rectangle, configRegistry);
Color separatorColor = configRegistry.getConfigAttribute(FreezeConfigAttributes.SEPARATOR_COLOR,
DisplayMode.NORMAL);
if (separatorColor == null) {
separatorColor = GUIHelper.COLOR_BLUE;
gc.setClipping(rectangle);
Color oldFg = gc.getForeground();
gc.setForeground(separatorColor);
gc.setLineWidth(2);
final int freezeWidth = PLRCompositeFreezeLayer.this.freezeLayer.getWidth() - 1;
if (freezeWidth > 0) {
gc.drawLine(xOffset + freezeWidth, yOffset, xOffset + freezeWidth, yOffset + getHeight() - 1);
final int freezeHeight = PLRCompositeFreezeLayer.this.freezeLayer.getHeight() - 1;
if (freezeHeight > 0) {
gc.drawLine(xOffset, yOffset + freezeHeight, xOffset + getWidth() - 1, yOffset + freezeHeight);
gc.setForeground(oldFg);
private FreezeLayer freezeLayer;
private FreezableLayerPainter freezableLayerPainter = new FreezableLayerPainter();
//private SelectionLayer selectionLayer;
* Konstruktor
* @param freezeLayer
* @param viewportLayer
* @param selectionLayer
public PLRCompositeFreezeLayer(final FreezeLayer freezeLayer, final ViewportLayer viewportLayer,
final SelectionLayer selectionLayer) {
this(freezeLayer, viewportLayer, selectionLayer, true);
* Konstruktor
* @param useDefaultConfiguration
final SelectionLayer selectionLayer,
final boolean useDefaultConfiguration) {
super(freezeLayer, viewportLayer, selectionLayer, useDefaultConfiguration);
this.freezeLayer = freezeLayer;
//this.selectionLayer=selectionLayer;
public ILayerPainter getLayerPainter() {
return this.freezableLayerPainter;
// @Override
// public Collection<ILayer> getUnderlyingLayersByColumnPosition(int columnPosition) {
// Collection<ILayer> underlyingLayers = new HashSet<ILayer>();
// if (columnPosition > 0) {
// underlyingLayers.add(this.selectionLayer);
// return underlyingLayers;
Re: FreezeColumn Nattable 2.0.2 not working [message #1852934 is a reply to message #1852927] |
Sat, 11 June 2022 09:17   |
Oh, and one add question. At which time do you execute the command? If you call it at initialization BEFORE the rendering happened, the client area is not yet set, therefore the width of the viewport is 0 and the command is not processed. For the initialization use case you need to use a paint listener or try to operate on the layer api directly.
To be more precise with some code. If you want to programmatically freeze a column at initialization time, either use a PaintListener:
natTable.addPaintListener(new PaintListener() {
public void paintControl(PaintEvent e) {
int columnPosition = 2;
compositeFreezeLayer.doCommand(new FreezeColumnCommand(compositeFreezeLayer, columnPosition, false, true));
natTable.removePaintListener(this);
or via the FreezeHelper API:
IFreezeCoordinatesProvider coordinatesProvider =
new FreezeColumnStrategy(freezeLayer, viewportLayer, columnPosition);
FreezeHelper.freeze(
freezeLayer,
viewportLayer,
coordinatesProvider.getTopLeftPosition(),
coordinatesProvider.getBottomRightPosition());
IIRC the reason for the change in the FreezeCommandHandler were issues in some more complicated layer compositions.
[Updated on: Mon, 13 June 2022 01:21] by Moderator
Re: FreezeColumn Nattable 2.0.2 not working [message #1852969 is a reply to message #1852961] |
Mon, 13 June 2022 07:53  |
SOLUTION
The variant that worked for me now is the one with the PaintListener
public void freezeColumn(final int columnPosition) {
CompositeFreezeLayer compositeFreezeLayer = getBodyLayerStack().getCompositeFreezeLayer();
this.natTable.addPaintListener(new PaintListener() {
The one using the Helper API worked but the freezing column gets disappeared!
I will suffice with that for now.
Thank you very much!
Mokhtar
FUDForum. Page generated in 0.05037 seconds
