Home » Eclipse Projects » EGit / JGit » Remote hung up unexpectedly on clone repository
Remote hung up unexpectedly on clone repository [message #1852598] Thu, 26 May 2022 06:19 Go to next message
I have clone problem of SSH repositories with newest JGit versions 6.1.0.202203080745-r and 5.13.0.202109080827-r.
Git.cloneRepository().setURI("ssh://...").call() always throws exception org.eclipse.jgit.api.errors.TransportException: ssh://...: remote hung up unexpectedly
JGit version 5.6.1.202002131546-r clones same repository without problems.
Command line "git clone ssh://..." with same repository completed successfully.
What is wrong?
Re: Remote hung up unexpectedly on clone repository [message #1852614 is a reply to message #1852598] Fri, 27 May 2022 05:57 Go to previous messageGo to next message
Impossible to say. Not enough information.
Possible duplicate of https://www.eclipse.org/forums/index.php?t=msg&th=1109789 . What kind of server is this cloning from?
Try adding setTagOption(TagOpt.FETCH_TAGS).
Re: Remote hung up unexpectedly on clone repository [message #1852616 is a reply to message #1852614] Fri, 27 May 2022 08:10 Go to previous messageGo to next message
bitbucket.org
ssh://git@bitbucket.org/...
result is same
Re: Remote hung up unexpectedly on clone repository [message #1852617 is a reply to message #1852616] Fri, 27 May 2022 08:18 Go to previous messageGo to next message
I suspected it might be Bitbucket Cloud. They have configured their SSH in a somewhat non-standard, restricted way. They only allow a single SSH channel to be opened in an SSH session. JGit sometimes uses two SSH channels sequentially.
The problem does not occur with command-line git because that delegates all SSH work to the external SSH executable, and thus creates two successive SSH sessions for that case.
Re: Remote hung up unexpectedly on clone repository [message #1852622 is a reply to message #1852617] Fri, 27 May 2022 10:33 Go to previous messageGo to next message
But the old version of JGit works well with BitBucket.
Can you make the new one work too?
Re: Remote hung up unexpectedly on clone repository [message #1852627 is a reply to message #1852622] Fri, 27 May 2022 16:37 Go to previous messageGo to next message
Hmmm... there was another problem with bitbucket if JGit used JSch for SSH caused by a bug in JSch. If you're using JSch, switch to using the Apache MINA sshd integration.
Re: Remote hung up unexpectedly on clone repository [message #1852635 is a reply to message #1852627] Sat, 28 May 2022 14:38 Go to previous messageGo to next message
Thank you.
As I understand, I must to call SshSessionFactory.setInstance() with alternative SshSessionFactory.
Where can I find sample of create SshSessionFactory for Apache MINE sshd?
Re: Remote hung up unexpectedly on clone repository [message #1852641 is a reply to message #1852635] Sun, 29 May 2022 08:33 Go to previous messageGo to next message
A very simple setup is in org.eclipse.jgit.pgm.TextBuiltIn.execute(). Other setups are shown in the org.eclipse.jgit.ssh.apache.test bundle. If you need to configure your factory in special ways, there is a SshdSessionFactoryBuilder that makes this somewhat easier.
Re: Remote hung up unexpectedly on clone repository [message #1852647 is a reply to message #1852641] Sun, 29 May 2022 15:02 Go to previous messageGo to next message
Thank you.
Clone bitbucket repository with Apache MINE sshd terminated successfully with some strange console messages.
getOrCreateProvider(BC) created instance of org.bouncycastle.jce.provider.BouncyCastleProvider
getOrCreateProvider(EdDSA) created instance of net.i2p.crypto.eddsa.EdDSASecurityProvider
No detected/configured IoServiceFactoryFactory using Nio2ServiceFactoryFactory
handleUnknownRequest(ClientConnectionService[JGitClientSession[git@bitbucket.org/104.192.141.1:22]]) unknown global request: keepalive@conker
Re: Remote hung up unexpectedly on clone repository [message #1852661 is a reply to message #1852647] Mon, 30 May 2022 10:29 Go to previous message
The first three messages are prefectly fine, just telling you what Apache MINA sshd uses as defaults.
The four handleUnknownRequets messages are probably https://issues.apache.org/jira/browse/SSHD-1237 . In any case they're harmless.
Previous Topic:Egit showing all .class file in unstaged changes after building workspace
Next Topic:Feature Wish: more descriptive Information instead of "Ours"/"Theirs"
Current Time: Sun Aug 31 02:28:41 EDT 2025
Powered by FUDForum. Page generated in 0.07741 seconds
