Home » General (non-technical) » Eclipse Foundation » Eclipse 2022 installation error(Eclipse 2022 installation give error and stops)
Eclipse 2022 installation error [message #1851771] Fri, 15 April 2022 04:49 Go to next message
Hello
I would like to use latest Eclipse, but it's installation give error and stops
Error message is :
(SWT:247953): Gdk-ERROR **: 11:48:14.932: The program 'SWT' received an X Window System error.
This probably reflects a bug in the program.
The error was 'BadAlloc (insufficient resources for operation)'.
(Details: serial 23728 error_code 11 request_code 131 (MIT-SHM) minor_code 5)
(Note to programmers: normally, X errors are reported asynchronously;
that is, you will receive the error a while after causing it.
To debug your program, run it with the GDK_SYNCHRONIZE environment
variable to change this behavior. You can then get a meaningful
backtrace from your debugger if you break on the gdk_x_error() function.)
Can somebody help me ?
Raivo
Re: Eclipse 2022 installation error [message #1851782 is a reply to message #1851771] Fri, 15 April 2022 07:23 Go to previous messageGo to next message
You posted that here too:
https://www.eclipse.org/forums/index.php/mv/msg/1110591/1851745/#msg_1851745
Re: Eclipse 2022 installation error [message #1851787 is a reply to message #1851782] Fri, 15 April 2022 10:19 Go to previous message
No, I moved it there, which should have discouraged reposting it here, in a "(non-technical)" area.
Previous Topic:download plugins for offline desktops
Next Topic:Time to move into a new forum "infrastructure"
Current Time: Sun Jun 15 07:26:30 EDT 2025
Powered by FUDForum. Page generated in 0.03071 seconds
