Home » Eclipse Projects » Eclipse Platform » Eclipse "syntax error" captures spaces! How do I disable?
Eclipse "syntax error" captures spaces! How do I disable? [message #185053] |
Mon, 26 January 2004 15:22  |
Originally posted by: beads.beadsland.com
My apologies if this is not the appropriate group to post this question, but
I've tried searching in every possible forum, and nowhere have I been able
to find a discussion of simple usability issues with the editor.
Perhaps I've developed some bad habits using non-IDE style editors, but I'm
having a very frustrating time using the Eclipse Java editor.
It seems that every time I try to type a string containing more than one
words, I have to hit the space bar twice to get a single space. On the
first space, the editor flashes an error at the bottom of the window, and
throws away the space character. Thus, if I were to try to type:
String newString = "This is a string."
I would instead get:
String newString = "Thisisastring."
in Eclipse, with flashing errors at the bottom of the screen the whole way
(unless I explicity stop to type the space character a second time at each
word boundary).
I haven't even gotten far enough into my line of code to finish it off with
a semicolon, and already its wrong because the editor is getting in the way.
This does not exactly contribute to rapid code design.
I appreciate the fact that the system is trying to assist me by pointing out
problems in the code, but I'd appreciate it a whole lot more if I could
actually finish typing without having the tool throw away characters in the
process of warning me that things are quite perfect yet.
I've experienced problems like this using VBA editors on Microsoft tools --
hence my thought that perhaps I'm just thinking about the act of 'typing' in
a way that doesn't mesh with best practices for typing code in an IDE
environment. I'm from the old-school keyboarding method -- hit key, key
appears on screen, hit key, key appears on screen. If in fact the rules of
'typing' are different when working in IDEs, then please educate me.
In any event, how do I stop this from happening, so that I can actually type
my code without fighting the assistant the whole way.
I'm using Eclipse on a WinME machine, if that makes any difference.
- Beads
Re: Eclipse "syntax error" captures spaces! How do I disable? [message #185261 is a reply to message #185053] |
Tue, 27 January 2004 03:11   |
>word boundary).
What does the error say? To me this looks as if you bound Space to some
command. Reset the key bindings and try again. If this does not work,
check the .log for errors and file a bug report.
Dani
>- Beads
Re: Eclipse "syntax error" captures spaces! How do I disable? [message #185455 is a reply to message #185053] |
Tue, 27 January 2004 10:09   |
> word boundary).
You don't say what version of Eclipse you're using, but this is
definitely not normal behavior as far as I know. I'm not too familiar
with 3.0, so I could be wrong if that's the version you're using.
Sorry I can't offer any suggestions - the behavior you describe doesn't
even sound like Eclipse to me :-)
Eric
Eric Rizzo
Software Architect
Jibe, Inc.
http://www.jibeinc.com
Re: Eclipse "syntax error" captures spaces! How do I disable? [message #186951 is a reply to message #185261] |
Thu, 29 January 2004 22:08   |
"Daniel Megert" <daniel.megert@gmx.net> wrote in message
news:bv56cj$agi$1@eclipse.org...
It varies, just now I tried and it said "No completions available." Mind
you, I have to watch very closely as it disappears almost as quickly as it
appears.
I haven't set any key bindings. I wouldn't even know how. I literally
downloaded/installed Eclipse and starting typing a Hello World program and
found that every time I tried to type out a String I hit this problem where
I'd have to hit the space bar twice to get one space. The first space is
consistently thrown away.
- Beads
> Dani
with
way.
out
the
tools --
in
of
type
> >- Beads
Re: Eclipse "syntax error" captures spaces! How do I disable? [message #187029 is a reply to message #186951] |
Fri, 30 January 2004 03:13  |
>appears.
This sounds like incremental content assist got activated and you run
into bug
https://bugs.eclipse.org/bugs/show_bug.cgi?id=49265
I suggest to use I20040121 or newer.
Dani
>- Beads
>>Dani
>with
>way.
>out
>the
>tools --
>in
>of
>type
>>>- Beads
Current Time: Sun Jul 27 09:34:02 EDT 2025
Powered by FUDForum. Page generated in 0.04403 seconds
